The Drift Thread
#31
im gonna try to get some pics 2day of me drifting and post them up 2marrow
#32
once i get everything done (mid jan) ill post some pics of my car driftin and still shots
#33
so i know alot of people who dont wana get into drifting b/c they think its gona cost a lot
so can some1 make a list of:
what you NEED
what would be NICE TO HAVE
and so on and so forth
what you NEED
#34
what you NEED
what you NEED
all you need is a pvc or abs pipe that will fit around your rims and then put them on either stretch them on with a heat gun or you can simply use super glue
oh ya and just your regular tools for changing your set up
#35
yer u dont need any special parts or cars like the yokomo drift kits i had a complete spare TC3 just incase i killed me main one for back up all i did was add rubber tyres and its driftorama time im hopin to go for a new years drift cause everywheres shut so ill get some pix theni hope aslong as i dont freeze to death as i am doing now
#36
has anyone used hpi's tires
i herd they suck really bad
#37
#38
#39
what you NEED
what you NEED
To drift you need:
car(no need for the latest and greatest)
batteries(Epic 3000 stick packs work great)
motor(27-19 turn, or brushless)
esc(whatever you want that will handle your motor)
servo(I'm using a standard servo)
radio(AM radios work fine)
drift tires(pick the tire that suits your style and needs)(abs, taped, drift tire)
Buying a rtr will provide you with most of the stuff needed for drifting. Hope this helps.
#40
Originally Posted by 20%nitro
Drifting is very cheap to get into. I'm using a tt-01, some 3000mah stick packs, Airtronics 94102 servo, Airtronics MX-A controller, Mtroniks esc, and a Reedy MVP stock motor. Most of it is budget stuff. The tt-01 is tough as nails and easily handles the impacts brought on by new drifters. The only upgrades that I have on mine are aluminum center shaft, ball bearings, associated motor heatsink, and new spurs and pinion gears. After drifting and driving for a year, I'm just considering getting a new car. And that's mainly because an electric onroad track is supposed to open up soon near me.
To drift you need:
To drift you need:
not sure if he mentioned it but the easiest to drift with is a 4wd car unless if you can get a car with a FR layout drivetrain but since mostly the rc car world likes it to be midship then 4wd is the best choice
#41
what you NEED
what you NEED
Another fun aspect of drifting is making replica cars. People seem to like buying their favorite cars giving them cool paint jobs, lights, rims, etc...
Check out the following link for cool drift videos:
http://us.driftrcentral.com/video.html
#42
RC Drifting Getting Serious
Check this out:
http://www.groovydrift.com/phpBB2/index.php
Read up on the Yokomo 2006 R/C Drifting Point Series. There will be prizes at each 6 events and the grand prize winner will get a ticket to Japan to compete against those drifters.
If we all do our part in spreading the word, then rc drifting can catch like wildfire and hobby shop owners can potentially have another source of sales. To all the guys reading this thread that run a track and/or run a shop, think of it. It's cheaper than racing, run times are longer which make it more appealing to the younger crowd. Also, people in rc drifting come back for more stuff like bodies, rims, LEDs, etc... Since the chassis people use to drift are also used in racing (I use a TC3 and also have a Yoke SD Black, CGM) the cross over from racing to drifting and vice versa can only be good for the hobby.
#43
aye Henry you got PM
#44
hey guys good to see some more drifters around i had a tt01 but got sick of replacing axels and stuff so bought myself a 415ms it is a pleasure to drift although alot heavier on the pocket
i thought i would share a few pics with you:
it is running a kyosho 22x1 motor or a johnson 540. I am about to upgrade to maybe a tamiya tz as i have heard they are very torquey and good to drift. i have a nosram patriot 7turn limit esc currently in but also have a lrp running reverse (i think) esc and a teu-101bk which are back ups or other friends are borrowing them. i have 1 yokomo 180sx, s13, v35, persuit ute and s6 rx7 shells and im using yokomo stage d drift tyres.
#45
i actually made some drifting tires that worked better than the normal ones because mine was with tape on the out site of the tires but no tape on the indside so when i was running strait then because of the camber i had alot of grip and when cornering the it ran sidewards
