The Drift Thread
#1996
Hey guys, I'm normally into racing off with my short course but have recently been given a ta04. I have set it up for drift and have ordered a novak 13.5t drift spec combo from amain. I have two questions:-
1 What final ratio should a be aiming for and with what combination of gearing in 48p?
2 Can I use a one way drive gear in place of a one way diff?
as i have found this to be cheaper and more readily avalible.
Thanks guys, look foward to your opinons.
#1997
Its in great condition no scratches on it at all just 1 and I do meen 1 wear mark on the rear of the lower chassis plate. And 1 stripped spur gear in the front tranny. But I think found the replacement gear on Ebay. And now Im just trying to decide on wether to drift it or make it a spec series racer. so undecided but ohwell. So if anyone can help me on what to buy to make this a drifter let me know
#1998
I visit D1RC or CSJunkies when I'm really looking for something.
#1999
TA03 Thread D1RC
You'll find alot of killer setups in this thread. I know I was drooling over the stuff I was looking at when I was attempting to build up my 03F. Problem is alot of that stuff is basically non-existant. It's out there somewhere, and if it is for sale it probably cost more than what I would be willing to pay.
#2000
Hi there drifters. Im planning to buy a drift kit but when I search for images on the net, there are different types of chassis that appear. One with the belt thingy and others are shaft. and also the location of the motor in the chassis. Im new to drifting and got bored with my buggy. Will you recommend the one with the belt over the others or the other way around? Im currently looking at tamiya tt01 and TEH R31 drift kits.
#2001
Me personally would go with a drift specific chassis. They can go from under $100 to "costs hella". Right now I have a $440 Tamiya VDF that I spent almost that much on hop up parts. I'll soon be complimenting that with a $120 Sakura D3.
You don't have to go with a high end kit or some exotic kit available only in Japan. The TT01 is a great car. The TEH R31 is a good car too. Just do your research and good luck!
#2002
I'm going to start back into the hobby with a Sakura Zero S and some upgraded parts like alum bulk heads f/r, vertical motor mount, upper plate, spool and 19t pulley with shaft. Just going to start of with an ezrun 9t 35a combo for now but really I loved the ezruns systems before and think it's just drifting so dont really need a high dollar. Not sure if all that is needed really for drifting but I just read 100+ pages on the chassis and thought I would like to start this build off right. Now Back before I quit this awesome hobby I had a sprint 2 and just 50/50 drifted but would like to set this 3racing chassis up for CS if I could. Would do I need to do? Also since I sold everything when I left I need it all back so I need to get some lipos. what is the size that fits? Also need pinions so what should I start with?
Thanks guys and look forward to getting back at it soon as it's back in stock with TQ.
#2003
Do you already have a Zero S? Have you seen the 3Racing Sakura D3? CS out of the box with the motor in front of the front axle. Did I mention it'll be around $120!?
#2004
Alot of people hold the TA03F iin high regard as a drift car. I have a Pro in pieces that I've been buying bits for the past 2 years. The car is easy to setup for countersteer and it's layout is arguably the best for drifting. Parts are becoming very hard to get now though. I like to think of the chassis as the AE86 of the RC world.
#2005
Um maybe because even though i do have an 03F it's still in pieces so I'm in no position to tell you a countersteer setup. I figured I'd refer you to a site that has alot of info on the chassis and maybe you'd be able to get something from it. No it's not my site and hell no I didn't pay $5 just to join a forum.
The point of my link was that I can't help you but at least they can. CSjunkies and D1RC are some of the better drift specific forums on the web. Straight up general RC forums like RC Tech, URC, or Radio Control Zone straight up blow when it comes to specific drift chassis info.
#2006
No I dont have yet, waiting for it to be back in stock and I have seen the D3 but don't like the idea of the motor upfront and also would rather stay with a TC so if I decide later to switch I can, not stuck with a chassis just for drifting.
#2007
#2008
#2009
#2010
No worrries!
When I first came across my 03F Pro, some guy gave it to my LHS owner for free. I knew what the chassis was but at the time I didn't care for drift. (This was 4 years ago) We were racing mini's at the time and I knew that the 03's ball diffs fit the M03 and M05. So I ruthlessly tore it apart for it's diffs Couple of years later I got the drift bug and surfing the interwebs read how legendary the 03F was. Called my LHS owner buddy as asked about the car and it turned out it had been sitting on the side of the house with some other trash that was to be thrown away! So I came up on it for free.
Not sure if I'll ever get it together again though. Got really disillusioned when i was hunting parts for it. Granted I already have everything needed to get it running but alot of the plastics look like crap now as well as alot off the metal hardware looks like it's been sitting outside for a bit. I was eyeballing the TA03F Pro drift spec I've been eyeballing on eBay and using that as a base instead for all the goodies I've been stockpiling.
