Old 06-15-2012, 08:55 AM   #1936
Originally Posted by Kaifd3s View Post
My Yok's, just had to add my Goose in the pic too....LOL...I love these cars...
Still need to paint a couple of bodies..
Jealous! look at those chassis! :drool:
PlayingDirty is offline   Reply With Quote
Old 06-20-2012, 12:26 PM   #1937
transplantlife's Avatar
Trader Rating: 43 (98%+)
Question for the pro's want to get into drifting was looking at the tamiya tb03vds or the xray t3r . ANy suggestions shaft vs belt when it comes to drifting? Also what do you guys set your ride height at while drifting and any droop if any? I want to get into comps with drifting..
thanks for the help
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 06-20-2012, 03:37 PM   #1938
thanks for the help
from belt or shaft its really all preference, my yokomo type c is shaft and its more than capable also less maintenance as far as not having a belt. we typically don't run droop screws but some do depending on surface but mainly no need to. the tamiya vds is a great car and so is the t3r, its all up to your parts availability and of course if your gonna want to do a counter steer mod
Team-Powers/Dischargerc.com
derbrylac is offline   Reply With Quote
Old 06-20-2012, 05:46 PM   #1939
thanx for the tip
Old 06-20-2012, 11:28 PM   #1940
Default Vdf gold
Harlow everyone.need help in setting a tamiya
VDF gold edition for drifting.currently m using a stock
Vdf which has nt yet install e cs kit.running on 4wd.
So wats e best set up etc:camber,ride height,suspension etc....
Using Hobbywing Justock esc 45A n 10.5t bl motor.
Hope anyone cn give me advise on e set up.
Thxxxx
joecikano is offline   Reply With Quote
Old 06-25-2012, 10:03 PM   #1941
sliding_josh's Avatar
Trader Rating: 21 (92%+)
+ YouTube Video
FaceBook>>> RC Drift Machines
sliding_josh is offline   Reply With Quote
Old 06-28-2012, 03:09 PM   #1942
Send a message via MSN to DORIYAA!
New wiring Tell us What you think! (crappy phone pics :/) And yes thats real black 14awg wire, not heatshrink
DORIYAA! is offline   Reply With Quote
Old 07-03-2012, 11:18 AM   #1943
Mxer59's Avatar
Trader Rating: 114 (100%+)
I'm getting into drifting so I can mess around in front of my house and maybe every now and then race it Oval. I'm going to get the Xray T3R and I was curious if you guys could help me out with a few questions? (I've been mostly sct 4x4 and 1/8 off road racer)
-I notice that it says 190mm bodies but most nice tuner car bodies I've seen are 200mm?
-What are some good tires and black rims that will fit good with 200mm if the 200mm bodies will work curious as I have noticed a lot of different offsets?
-What is a good brushless motor setup for drifting? Is sensor Esc important for drifting?
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 07-04-2012, 07:33 AM   #1944
Aprila's Avatar
I have a yokomo dib with full hop ups, but hey guys a little help here on the ecu, engine and servo setup for an aggressive driver. Any recommendations?
P.S: Using Sanwa mt4
Aprila is offline   Reply With Quote
Old 07-06-2012, 04:36 PM   #1945
multi-bash's Avatar
The Xray will drift, but it's not ideal - too stiff overall. I ran a t2009 for a year, spent many hours modding expensive CVDs to get more steering lock and eventually sold it off for a proper drifter. For 50:50, it really doesn't matter what you get, so long as it has camber/caster/toe adjustment. If you want to run CS in the future; massive steering lock (45-50* is ideal, front/midship motor placement is ideal).
I prefer a belt drive - nicer sound, no torque steer and more options for CS ratios. With the exception of HPI Sprint, all belts are identical pitch/width (Spring is 5mm width, standard is 3mm width).
OTA-R31
Yokomo DRB/DIB
Tamiya TA-05/VDF
MST FS-01/MS-01
etc...
Checkout broadtech.hk for eagle racing parts - very cost effective carbon conversions etc.. You can easily build a VDF clone for under $200 this way (use the TA-05 conversion set, add arms, shocks etc..)
For wheels, I like R2hobbies.com - lots of selection and resonable shipping for an overseas place. Their t-drift knockoffs are a good value, but not as sticky if you're drifting on polished concrete.
RE width - most chassis are 190mm width. You can easily run a 200mm body by running wheels with bigger offset (generally 6mm front, 9mm rear) or just use a wider hub hex.
RE sensored - definately reccomended. You want smooth power at all ranges. I like to run Novak gear - made and designed in the USA! Awesome warranty to boot. I have GTB2 and 8.5t ballistic, never gets warm and I'm geared down to 4.0 with ~%60CS. 8.5t-13.5t is a good range. Smaller turn motor if you run on larger tracks with long sweepers.
Raincity Raji Kon - hit me up to drift in the 206/425 -- RWD W.U.N. Nervis 2.0, RWD dlike RE-R Hybrid, RWD Sakura D4, 50:50 StreetJam OTA-R31, Slash 4x4, Slash 2wd, Subaru Brat Scaler, Emaxx dual brushed motors lol
WTT: my HPI MRS4 with exotex and more
multi-bash is offline   Reply With Quote
Old 07-06-2012, 09:02 PM   #1946
Mxer59's Avatar
OTA-R31
Yokomo DRB/DIB
Tamiya TA-05/VDF
MST FS-01/MS-01
etc...
Thanks what car would you recommend for drift part time little oval maybe?
- also a good place to get one?
I use to run all Novak aswell
Futaba 4pls
Team Chase 2015
Old 07-06-2012, 11:23 PM   #1947
Chiefy 707's Avatar
I'd say a standard TA-05. With batteries on one side and electrics on the other, it makes an excellent oval car. At least that's what I'd like to think. My buddies cousin has one and it's not too bad at drifting.
"It looks like a [insert car here]. It's just another [insert car here] clone!"
"Why did [insert manufacturer here] go with such a radical design? [insert manufacturer here] needs to stick with what works!" Shhhh, please.
HB/LRP/KO Propo/Protek/Associated/Tekno
Chiefy 707 is offline   Reply With Quote
Old 07-09-2012, 09:36 PM   #1948
Mxer59's Avatar
Are the HPI Sprint 2 Flux with different tires pretty decent cars?
Futaba 4pls
Team Chase 2015
Old 07-10-2012, 11:47 PM   #1949
Chiefy 707's Avatar
Yes. Or so I've heard. Sorry I can't be more help but the drift thread here is kinda not happening. But yah, more people seem to prefer the Sprint over the E10.
Old 07-15-2012, 07:33 AM   #1950
Lock the rear diff and experiment with what tires work best on the surface you're running on - id suggest a hard compound tire, try streetjam if t drifts dont work out
Sg Official Drift Thread!!! AndrewJCH Singapore R/C Racers 188 08-05-2011 09:02 AM
Official Drift Thread Ginsu Electric On-Road 8 10-23-2007 02:36 AM
official drift thread streetracer745 Electric On-Road 3 10-24-2006 09:07 PM
The Official Drift Thread anthony390 Nitro On-Road 0 12-25-2005 10:46 PM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
