Old 03-07-2012, 02:06 PM   #1786
Captcha's Avatar
What is a good servo for drifting? Speed or trq? Gonna be drifting 3 chassis.
Losi xxxs g+ bless setup
Hpi e10 rtr setup
And tamiya tt01-d setup.
Captcha is offline   Reply With Quote
Old 03-08-2012, 04:38 PM   #1787
Theibault's Avatar
So I just got into drifting. Here's my first day out, documented for all to see. I'll keep adding videos as I progress. Please subscribe to my channel!
+ YouTube Video
Theibault is offline   Reply With Quote
Old 03-08-2012, 06:14 PM   #1788
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
+ YouTube Video
it looks likje you are running the Tamiya drift tires. Switch to the HPI tires. You will notice a big difference.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 03-08-2012, 08:59 PM   #1789
Theibault's Avatar
Those are HPI A Drifts. I have T Drifts but I left them at home next to my other camera and tripod. I was kinda really excited to run with the nice weather today .
Old 03-09-2012, 03:07 PM   #1790
I can tell by how abrupt your drifts are. T drifts are much better. BTW, here is some eye candy. and yes, this is my rc.
Old 03-10-2012, 03:27 AM   #1791
Send a message via MSN to DORIYAA!
i have the same rims as you, very nice shell dude , ill post up my vdf when the forum will let me post image links hahaha
DORIYAA! is offline   Reply With Quote
Old 03-10-2012, 03:35 AM   #1792
Anyways, Heres my setup with the slight removal of pics for the time being
Make: Tamiya
Model: VDF
Track surface: Polished Concrete
Tire: Drifterstreet CS-F2 / square medium / raikou dxpe / streetjam hard
Motor & ESC: Xerun 10.5
Servo: Savox 1258TG
Front
Camber: -7
Toe:0
Caster hubs: Stock 4 Deg
Kickup: 4mm
Caster: 8 Deg
Ride height: 10mm
Oil: #600 Muchmore
Springs:Stock VDF chrome
Bumper weight: 60G
Other: Aluminium C hubs + Aluminium Knuckles + Steering mod
Rear
Camber: -6
Kickup:0.5mm
Toe: 0
Ride height: 8mm
Oil:CS300 Team Caster
Springs: Stock VDF chrome
Drive Train
Front: 39 TA06
Center: 13/21 Jet Racing
Rear: 32 Tamiya TA04
Ketsukaki:96%
Spur: 96T 48DP
Pinion: 26T 48DP
Old 03-10-2012, 06:51 AM   #1793
hey everyone. I just picked up a HPI Sprint 2 Drift yesturday and i am going to learn with this before i really start getting to serious lol. My first question is Tires? It seems like i slide out way to easy maybe its what it is supposed to do. Also can i adjust camber or do as other talk about and lock out front wheels or make rear bias? I am super new so if i am asking dumb questions just let me know. Also i hear some people say brushless or not i thought that mine is brushless?
Thanks,
Chris
Fleshlight is offline   Reply With Quote
Old 03-10-2012, 08:32 AM   #1794
Make: Tamiya
Model: VDF
Servo: Savox 1258TG
Front
Camber: -7
Toe:0
Kickup: 4mm
Caster: 8 Deg
Ride height: 10mm
Oil: #600 Muchmore
Bumper weight: 60G
Rear
Camber: -6
Kickup:0.5mm
Toe: 0
Ride height: 8mm
Drive Train
Front: 39 TA06
Ketsukaki:96%
Spur: 96T 48DP
Pinion: 26T 48DP
Try a lower weight shock oil (to about 45) and drop that car! that ride height of 10mm is adding bodyroll and unstability.
Old 03-10-2012, 08:33 AM   #1795
Thanks,
Chris
to adjust toe and camber you need adjustable turnbuckles. if you do not have them, theyre rather cheap.
Define "too much". Many newbies have a tendency to mash and hold the throttle. Drifting is constant on/off throttle.
Old 03-10-2012, 08:52 AM   #1796
I most likely am mashing lol. I am still trying to learn to CONTROL the drift and not just sliding around. What tires do you recommend? Did I choose a good starter drift car? I have also been reading up on different batteries lasting longer or making the car faster. And trying to find a charger to charge faster then 6 hours lol.
Thanks for the help,
Chris
Old 03-10-2012, 03:32 PM   #1797
I get that response quite a bit hahaha, i raised the front so when on power the weight will transfer to the rear.
Old 03-10-2012, 03:45 PM   #1798
Chris
Keep in mind, be cautious when you play around with camber - it can change how your car drives quite a bit. Go for a hard compound tire such as HPI Tdrifts or some Streetjam Hard tires - both can be purchased at rc-race-and-drift.com (under the drift section) As for a charger, buy an imax B6 and a few 5000mah lipos from hobbyking, that would keep you going for a long time = more practice for you
Old 03-11-2012, 10:35 AM   #1799
i agree. I read so many posts that say "I run 8* camber, its mad JDM bro" and they not only run through tires every few runs but they have stability issues. Countersteer is the only reason why people should consider 8* camber/10* caster. but the benefits of being conservative with your setup completely out weighs the coolness factor. Ask anyone who countersteers REGULARLY how often they go through motors, or can never get gearing right, or have esc/motor temp issues...
Old 03-11-2012, 12:57 PM   #1800
atl darrick's Avatar
Trader Rating: 36 (100%+)
my ta05 vdf cs
MUGEN ECO/BCE/TEKIN RX8/TEKIN 1900KV/JR9100S
CONTROLLED BY KO PROPO EX10 EURUS
atl darrick is offline   Reply With Quote
Sg Official Drift Thread!!! AndrewJCH Singapore R/C Racers 188 08-05-2011 10:02 AM
Official Drift Thread Ginsu Electric On-Road 8 10-23-2007 03:36 AM
official drift thread streetracer745 Electric On-Road 3 10-24-2006 10:07 PM
The Official Drift Thread anthony390 Nitro On-Road 0 12-25-2005 11:46 PM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 04:09 PM
SEO by vBSEO 3.5.0
