Old 10-06-2016, 08:27 PM   #121
vlozity's Avatar
Originally Posted by Thrifty View Post
For those of y'all with a D4,... what offset wheels are you running?
I've just read a bit about wanting the gearing to be more toward top end speed with a larger pinion gear. I've having trouble getting my AuperD to actually drift. Just spins out. I have a 21p in there now but have ordered a set of larger ones to test...
Hopefully y'all can steer me in the right direction...
gearing should be a balance of torque and speed, do not tune just for speed.
tire choice really depends on what track your running on. in a smooth concrete tracks we use MST Silver dot tires... these has worked best. not sure what others use for carpet, we don't drift on one, sorry.
wheel offset are considered by the full lock you can get and the body you use. what i mean by full lock is you need to make sure there is no binding happening when you turn the car to the left or right, if the tire touches anything on the suspension it is like hitting the brakes and you will spin out.
3Racing Sakura D4 RWD & AWD converted to RWD
Tekin RS ESC Tekin Redline 13.5T BL Sensored Savox 1257TG Sanwa MT4
vlozity is offline   Reply With Quote
Old 10-06-2016, 08:30 PM   #122
vlozity's Avatar
Originally Posted by Skeet215 View Post
Wow those are some sick chassis Vlozity. I wish i had the time to dedicate more. Hopefully winter will keep me indoors and I'll build a dedicated drifter.
thanks! have fun on your build!
So I bought a set of YeahRacing rims and tires to beat around in a local school yard. Im actually pretty impressed with their handling on asphalt. I mean for a $15 set lol
i have not tried those, we use MST and Team Tetsujin super rims for wheels and MST silver dots for smooth concrete tracks.
Old 10-06-2016, 08:34 PM   #123
vlozity's Avatar
Originally Posted by ic-racer View Post
My drift cars are all 4wd. I have wondered, on 2wd, why not put grip tires in the front?
you do not want too much grip in front. drifting is all about balance, front grip is necessary for the car to steer properly and slide when initiated. the rear needs enough grip to move the car forward but also to slide when initiated.
another thing to consider is the tracks, if there is a spec tire, you need to practice with it and use it constantly. using rubber tires may ban you from running on that track as the compound leaves unwanted residue, etc.
Old 10-06-2016, 08:39 PM   #124
vlozity's Avatar
finally completed my TC-FD resurrection project and installed all the electronics. been tuning her the past weeks and she is drifting really good in slippery tiles, just need to test it outdoors and see how she performs.
here is how she looks now...
sorry for the large images, i use them for desktop wallpapers hehe
Old 10-06-2016, 08:44 PM   #125
vlozity's Avatar
oh and i made a video of her, just for kicks...
https://www.youtube.com/watch?v=8tBJWK0jkUQ
Old 10-07-2016, 09:08 PM   #126
Skeet215's Avatar
Nice video. If you have any of it drifting that would be awesome. Never seen one of those actually being used lol
Skeet215 is offline   Reply With Quote
Old 10-14-2016, 01:43 AM   #127
vlozity's Avatar
Thanks!
the closest drift track is outdoors and its been raining here a lot. i am planning on doing a video of it drifting soon. this is an old chassis, 2010 or 2011 release.
Old 10-30-2016, 08:51 PM   #128
Skeet215's Avatar
So I finally purchased a d4 rwd kit. Waiting for it to arrive. Anything special to look out for when building. This is my first kit btw. Is it pretty straight forward?
Old 10-31-2016, 04:03 AM   #129
It's a routine build. Just take your time. I've only built 2 kits so far. Both took around 6-8 total hours. For me it was around an hour a day before work. Afte thst started dropping it getting annoyed with small pieces.
Tires seem to be a major thing for RWD. I still haven't got my D4 to run right because of tires.
Billy Kelly is offline   Reply With Quote
Old 11-01-2016, 03:30 PM   #130
Skeet215's Avatar
Ok cool thx. Im gonna build up over the winter. After its built I'll look for a motor combo. Then a body after that. Slow process lol
Old 11-01-2016, 10:27 PM   #131
ThePanda's Avatar
Trader Rating: 64 (100%+)
don't forget the gyro
ThePanda is offline   Reply With Quote
Old 11-08-2016, 04:03 AM   #132
Skeet215's Avatar
What is the gyro for and where do I get it?
Old 11-08-2016, 06:56 AM   #133
Gyro are practically necessary for RWD stability. Without one, unless you're among the absolute best, you'll more often than not spin out. RWD are highly unstable without a little help from a gyro.
You can get them at almost any hobby shop. If they sell any type of helicopters, crawlers, drones or airplanes they'll definitely have them.
wareagle84 is offline   Reply With Quote
Old 11-14-2016, 06:45 AM   #134
vlozity's Avatar
check this vide out. it does not explain fully in words but shows what a gyro does to give stability...
https://www.youtube.com/watch?v=mBuQSZVOxac
Old 11-16-2016, 01:02 PM   #135
multi-bash's Avatar
No special tricks building the d4 RWD, except for one. The first editions of the kit had insane amounts of KPI. Bad bad bad geometry. Later kits have a revised front knuckle with less KPI. If your kit has the later, build it with low KPI setting. If the former, get new knuckles with low or zero KPI (and a longer turnbuckle).
I also flipped the front upper arm bulkheads to get lower caster (so I can run less toe, so I get more leading wheel contact patch).
Tamiya TRF shocks are always a good upgrade. I run TRF shaft/cylinder/orings with the D4 pink bits and top ball cup thingy.
https://www.instagram.com/p/BDe2pdpKmu_/
Raincity Raji Kon - hit me up to drift in the 206/425 -- RWD W.U.N. Nervis 2.0, RWD dlike RE-R Hybrid, RWD Sakura D4, 50:50 StreetJam OTA-R31, Slash 4x4, Slash 2wd, Subaru Brat Scaler, Emaxx dual brushed motors lol
WTT: my HPI MRS4 with exotex and more
multi-bash is offline   Reply With Quote
