    Hide Wikipost
Old 11-21-2016, 06:09 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Serpent Project 4-X
Last edit by: WagwanBumba
Introduction
This is a wiki page for the new and very interesting concept 4-X from Serpent. This is wiki is meant to develop and grow as more is understood about the car.
Serpent's Product Page - http://www.serpent.com/product/400030
The 4-X Development Story - Here
Manual - Here
Spring Chart
SOFTEST
  • 401705 Spring white C4.4 4X (2)
  • 401706 Spring yellow C4.9 4X (2)
  • 401707 Spring orange C5.5 4X (2) = kit
  • 401708 Spring red C6.3 4X (2)
  • 401709 Spring pink C6.9 4X (2)
  • 401710 Spring blue C7.6 4X (2)
  • 401711 Spring purple C8.4 4X (2) = kit
  • 401712 Spring greenC9.5 4X (2)
  • 401713 Spring grey C10.9 4X (2)
  • 401714 Spring black C12 4X (2)
HARDEST
Build Tips
RCBuilds.net Build, tip guide and youtube video - http://www.rcbuilds.net/builds/onroa...nt-project-4x/
Heave + Roll Damper Build Tips
Pivot Ball Nut Tip
Setups
Setup Tips
Ride Height Adjustment
Adjusting tweak with roll damper
Usage of washer on lower arm
Tuning ARS
Option Parts List
Social Media
Facebook 4-X Group
Print Wikipost
Like Tree49Likes
Old 11-06-2016, 05:34 PM   #61
Trader Rating: 148 (100%+)
You really only need to remove the 2 bottom screws and remove 1 of the upper arm pins and you can pop the diff right out in about 2 minutes.
jeff jenkins sr is offline   Reply With Quote
Old 11-06-2016, 05:59 PM   #62
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
Hey Senior
Two minutes to take the diff out...Hmmmm
mostly TC out there take 30 sec or less...just giving you a hard times
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 11-06-2016, 06:53 PM   #63
I usually remove both of the upper arm pins
OVA - how about a belt change on a "normal" TC?
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 11-06-2016, 07:30 PM   #64
OVA
OVA's Avatar
Funny..I don't own normal TC ,mine is the A700 shaft ,A800 only have one screw the hold the belt pulley...."Get some of the"
Old 11-14-2016, 08:30 AM   #65
Byronf1's Avatar
Does anyone try it on asphalt yet? low grip.... any setup?
Serpent Project 4X - 748-TQ -S811 Be 2.1
Byronf1 is offline   Reply With Quote
Old 11-14-2016, 11:54 PM   #66
Holmenkollen's Avatar
There will come some new bits that will make it a bit easier and faster.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 11-15-2016, 03:20 PM   #67
Byronf1's Avatar
Can someone explain me how to raise the car...
Connecting rods are those that are connectes to the upper arm correct?
I already put a 1mm spacer on the heave damper (main shock), on the rear I do not have that problem but on the forward is too low... on the H (high) position I got 7mm height... thanks for your support....
Old 11-15-2016, 04:25 PM   #68
Schwarta's Avatar
So you've put a spacer on the front heave shock? You could shorten the connecting turnbuckles to the upper arm.
Schwarta is offline   Reply With Quote
Old 11-16-2016, 06:54 AM   #69
Byronf1's Avatar
Thanks that works!
Old 11-17-2016, 05:14 AM   #70
BardSmith's Avatar
Trader Rating: 61 (98%+)
This is such a great car for me and so I've decided to put a lot of work into getting a good set up. I mainly race on CRC black carpet in the US in the 17.5 class. I finally got to a really good setup that works on very high grip conditions, it's attached. Let me know how it works for you.
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 11-17-2016, 03:15 PM   #71
Jochim_18's Avatar
Whooa I'm a confused just looking at the setup I guess till I get my car and play with it will enlighten me how to work with the car...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 11-17-2016, 10:49 PM   #72
Does the removal of the brace not affect the torsional flex of the car?
I was thinking of doing the same, but using loads of washers to replace the brace
Old 11-17-2016, 11:30 PM   #73
BardSmith's Avatar
You can add two 3mm shims (4 total) to compensate or install the top deck. I actually chose to do both because I want to get it as stiff as possible.
"Bard"
On-Road Only!
Old 11-18-2016, 12:10 AM   #74
What´s the reason for very high roll centers? I would think lower roll centers would be better for high grip situations.
Old 11-18-2016, 02:21 AM   #75
Schwarta's Avatar
Is your droop settings orh or measured like the setup sheet?
