    Hide Wikipost
Old 11-21-2016, 06:09 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Serpent Project 4-X
Last edit by: WagwanBumba
Introduction
This is a wiki page for the new and very interesting concept 4-X from Serpent. This is wiki is meant to develop and grow as more is understood about the car.
Serpent's Product Page - http://www.serpent.com/product/400030
The 4-X Development Story - Here
Manual - Here
Spring Chart
SOFTEST
  • 401705 Spring white C4.4 4X (2)
  • 401706 Spring yellow C4.9 4X (2)
  • 401707 Spring orange C5.5 4X (2) = kit
  • 401708 Spring red C6.3 4X (2)
  • 401709 Spring pink C6.9 4X (2)
  • 401710 Spring blue C7.6 4X (2)
  • 401711 Spring purple C8.4 4X (2) = kit
  • 401712 Spring greenC9.5 4X (2)
  • 401713 Spring grey C10.9 4X (2)
  • 401714 Spring black C12 4X (2)
HARDEST
Build Tips
RCBuilds.net Build, tip guide and youtube video - http://www.rcbuilds.net/builds/onroa...nt-project-4x/
Heave + Roll Damper Build Tips
Pivot Ball Nut Tip
Setups
Setup Tips
Ride Height Adjustment
Adjusting tweak with roll damper
Usage of washer on lower arm
Tuning ARS
Option Parts List
Social Media
Facebook 4-X Group
Print Wikipost
Like Tree57Likes
Old 10-25-2016, 04:36 PM   #31
The Teacher's Avatar
Trader Rating: 48 (100%+)
OVA, I thought the same thing about all the moving parts but after driving my car a few times I could see that it was actually very durable. The only issue I had was with the front belt popping off. I think it was because I didn't run the front brace....
The Teacher is offline   Reply With Quote
Old 10-25-2016, 04:46 PM   #32
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
I have a question for you...I know there is a damper the move side to side..do you have to change the oil to slow the side motion or the mono shock slow it down?
thanks
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 10-25-2016, 07:09 PM   #33
nexxus's Avatar
Trader Rating: 302 (100%+)
Originally Posted by dan_vector View Post
Can we find out why? There was alot of good info in that thread that's now lost. However the Facebook group has a much better following for the 4x anyway...
You will have to contact site admin for that, I don't know any more than you do.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 10-25-2016, 07:33 PM   #34
thanks
You can use thicker oil to slow the action or change for harder springs for more roll stiffness in the roll damper. Quite revolutionary IMO.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 10-25-2016, 07:34 PM   #35
And how might we do that?
Old 10-25-2016, 09:36 PM   #36
OVA
OVA's Avatar
That's was I thought ...So you have to take those damper assy part out to change the oil thickness every time when the track grip is high or low and hopefully those damper last a long time before need for rebuilt.....
Old 10-25-2016, 09:44 PM   #37
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
One of my locals has one. Its not that hard to work on and do really. I was super surprised after looking it over last week.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-25-2016, 10:18 PM   #38
OVA
OVA's Avatar
EA
Hi Eric
Well I am going to wait and see how people like them...
Old 10-26-2016, 12:02 AM   #39
You do - but the car is actually very easy to work on, despite it's overengineered look.
For roll damper, it's actually designed so that it can be dropped in/out so it should be straight forward enough (when the spares become more available) to build sets of not only roll dampers but heave dampers with different oil thicknesses and springs in them that can be changed WAY more quickly than a spring or roll bar change on a more conventional chassis.
So far dampers are looking good!!
I did also forget to mention that Serpent do provide different pistons for the roll and heave dampers, blank, single and double holes but all setups so far seem to use the default single hole.
Old 10-26-2016, 03:56 AM   #40
OVA
OVA's Avatar
it is good to know...Thanks
Old 10-26-2016, 07:45 AM   #41
what was the reason of making option top deck,what is wrong with the box stock top deck?
by looking at this 4X I see a lot of small suspension movement parts. kinda remind me ,the more part you have the more thing can go wrong after you tap the pipes ..just my .02
your one had a top desk from the box?
Mind don't
dragontuneak is offline   Reply With Quote
Old 10-26-2016, 01:28 PM   #42
Trader Rating: 148 (100%+)
Yea they don't come with a top deck, that's an option part!
jeff jenkins sr is offline   Reply With Quote
Old 10-27-2016, 11:55 AM   #43
Byronf1's Avatar
what are your Impressions on the track ??
Serpent Project 4X - 748-TQ -S811 Be 2.1
Byronf1 is offline   Reply With Quote
Old 10-27-2016, 12:56 PM   #44
Thunderbunny's Avatar
Trader Rating: 24 (100%+)
I've only had one outing with mine, and it was pretty good constidering that I had no parts or spring options. The first thing that I noticed was that the car carried a lot of speed throught the corners. Durability seemed to be on par. Having been out of electric TC for about 1 1/2 years, I was able to take third place in a double A-main (one second,one third) event against some pretty good competition. Only gripe was that it was a little chubby in respects to ROAR's new lower min. weight. Since then, I have replaced most of the screws with Ti and aluminium. As of now, I'm sitting at 1357g
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
Team ARC l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 10-30-2016, 08:22 PM   #45
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
Drove one yesterday for a pack and was impressed with the car. Stock setup seems like it's only a couple of adjustments from being perfect but still very easy to drive and very predictable. I have decided to sell off my A800 to get me one of these now so looking forward to when I can get one on the track. Good work serpent , make a truly different car and actually have it work is impressive. At least in today's standards.
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
