    Hide Wikipost
Old 11-21-2016, 06:09 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Serpent Project 4-X
Last edit by: WagwanBumba
Introduction
This is a wiki page for the new and very interesting concept 4-X from Serpent. This is wiki is meant to develop and grow as more is understood about the car.
Serpent's Product Page - http://www.serpent.com/product/400030
The 4-X Development Story - Here
Manual - Here
Spring Chart
SOFTEST
  • 401705 Spring white C4.4 4X (2)
  • 401706 Spring yellow C4.9 4X (2)
  • 401707 Spring orange C5.5 4X (2) = kit
  • 401708 Spring red C6.3 4X (2)
  • 401709 Spring pink C6.9 4X (2)
  • 401710 Spring blue C7.6 4X (2)
  • 401711 Spring purple C8.4 4X (2) = kit
  • 401712 Spring greenC9.5 4X (2)
  • 401713 Spring grey C10.9 4X (2)
  • 401714 Spring black C12 4X (2)
HARDEST
Build Tips
RCBuilds.net Build, tip guide and youtube video - http://www.rcbuilds.net/builds/onroa...nt-project-4x/
Heave + Roll Damper Build Tips
Pivot Ball Nut Tip
Setups
Setup Tips
Ride Height Adjustment
Adjusting tweak with roll damper
Usage of washer on lower arm
Tuning ARS
Option Parts List
Social Media
Facebook 4-X Group
Print Wikipost
Like Tree57Likes
Old 07-14-2017, 04:16 AM   #316
The Teacher's Avatar
Trader Rating: 48 (100%+)
Anybody know where you can find the Vertical Top Deck for the 4x...? Can't find this anywhere in stock
The Teacher is offline   Reply With Quote
Old 07-14-2017, 06:41 AM   #317
dan_vector's Avatar
Trader Rating: 27 (100%+)
There's quite a few options in Europe that have stock but a quick search in the US turned a bit of a blank.
RCLAB on Facebook has them (in HK).
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 07-14-2017, 09:21 AM   #318
Default Vertical Top Deck
We have it instock!
Antimullet and dan_vector like this.
Rclabhk is offline   Reply With Quote
Old 07-14-2017, 09:57 AM   #319
dan_vector's Avatar
Thumbs up
Originally Posted by Rclabhk View Post
We have it instock!
Very reliable outfit guys. They also do these really neat front and rear bulkhead stiffeners....
Antimullet likes this.
Old 07-14-2017, 02:02 PM   #320
corallyman's Avatar
Trader Rating: 99 (100%+)
Dan, are you using the hard arms and blocks, etc.
corallyman is offline   Reply With Quote
Old 07-14-2017, 06:04 PM   #321
How do you order from RC Lab, can't find the site?
Old 07-15-2017, 03:06 AM   #322
dan_vector's Avatar
PM them on RCTech or PM via Facebook....
https://www.facebook.com/stephen.ip.503
Old 07-15-2017, 03:07 AM   #323
dan_vector's Avatar
Upper and Lower HARD arms and all the new parts VTD, RRS, Linear pullrods, short front stiffener, alu front stiffener plate (under steering rack). The car is fantastic.
Old 07-31-2017, 03:09 PM   #324
Airwave's Avatar
Hi guys, what's the neutral setting to have no toe variation on the rear? 0mm inside and outside?
Airwave is offline   Reply With Quote
Old 07-31-2017, 03:12 PM   #325
erchn's Avatar
It depends on the amount of rear caster, in general, at ride height the toe link should be as level as possible, with stock settings that should be ~2mm on the outside, zero inner.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 08-02-2017, 06:17 AM   #326
Airwave's Avatar
thx.
Old 08-02-2017, 11:53 AM   #327
dan_vector's Avatar
Seems these are now available.
Serpent Model Racing Cars - Product - Roll damper support -7mm carbon 4-X (2)
Short rolldamper support conversion:
The optional slightly shorter rolldamper support plates - 7mm are made for the front rolldamper. They change the motion ratio for the front rolldamper, and thus give a more responsive car under most conditions.
Old 08-02-2017, 02:43 PM   #328
Airwave's Avatar
So they were planned... Let's see if they have the proper part number (401717) lol
Old 08-02-2017, 08:11 PM   #329
Trader Rating: 45 (100%+)
I made some in 7 and 9mm and tested both. I still am undecided on which ones I like better. Going to do back to back testing with 7, 8, and 9mm this weekend.
Pro-Line/Protoform, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 08-03-2017, 10:08 AM   #330
RC MARKET's Avatar
Serpent New Option Parts
RC MARKET is offline   Reply With Quote
