    Hide Wikipost
Old 11-21-2016, 06:09 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Serpent Project 4-X
Last edit by: WagwanBumba
Introduction
This is a wiki page for the new and very interesting concept 4-X from Serpent. This is wiki is meant to develop and grow as more is understood about the car.
Serpent's Product Page - http://www.serpent.com/product/400030
The 4-X Development Story - Here
Manual - Here
Spring Chart
SOFTEST
  • 401705 Spring white C4.4 4X (2)
  • 401706 Spring yellow C4.9 4X (2)
  • 401707 Spring orange C5.5 4X (2) = kit
  • 401708 Spring red C6.3 4X (2)
  • 401709 Spring pink C6.9 4X (2)
  • 401710 Spring blue C7.6 4X (2)
  • 401711 Spring purple C8.4 4X (2) = kit
  • 401712 Spring greenC9.5 4X (2)
  • 401713 Spring grey C10.9 4X (2)
  • 401714 Spring black C12 4X (2)
HARDEST
Build Tips
RCBuilds.net Build, tip guide and youtube video - http://www.rcbuilds.net/builds/onroa...nt-project-4x/
Heave + Roll Damper Build Tips
Pivot Ball Nut Tip
Setups
Setup Tips
Ride Height Adjustment
Adjusting tweak with roll damper
Usage of washer on lower arm
Tuning ARS
Option Parts List
Social Media
Facebook 4-X Group
Print Wikipost
Like Tree57Likes
Old 06-21-2017, 09:24 AM   #286
dan_vector's Avatar
Trader Rating: 27 (100%+)
Just some slightly thicker o-rings sorted the heave damper leakage issue for me. That's in mod racing too.
You guys have gotta try the new parts. The VTD, linear pullrods and the short RRS links. Together with the much harder roll damper oil (2 hole with 12k oil or no hole 2k oil). This has made a tremendous difference to my car on asphalt. I no longer have the unpredictable rear end! Very happy!
erchn and Antimullet like this.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 06-21-2017, 11:55 PM   #287
New parts for my 4X are waiting for me at my LHS but I tried some of the new roll damper/centre philosophy from Wilcks setup recently and agree ... best change ever!
Zero hole roll damper and 2mm shims instead of 3 for roll center. Super easy to drive out of the corners - I could get on throttle way earlier and punch my way out.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 06-22-2017, 03:03 AM   #288
dan_vector's Avatar
Definately turned a corner on the setup of this platform. I'm still totally convinced that there is so much more to come as well!!
Old 06-22-2017, 09:42 AM   #289
where are you guys ordering the parts from?
mstrfahrenheit is offline   Reply With Quote
Old 06-22-2017, 11:22 AM   #290
dan_vector's Avatar
Desoto or RCMarket (they seem to get stuff first as I guess they are nearest the factory).
Old 06-24-2017, 06:47 AM   #291
I mainly run on high grip carpet. If I wanted to go with the VTD, is it best cut the centerspline or have people left the spline intact?
rusch49 is offline   Reply With Quote
Old 06-24-2017, 07:41 AM   #292
dan_vector's Avatar
You need to have the centre spline cut or run the new short front part only (401746) The VTD is designed that way. Viktor has been running with both H bracket stiffeners removed as well with the VTD installed.
Old 06-27-2017, 11:17 AM   #293
RC MARKET's Avatar
Thankyou !
RC MARKET is offline   Reply With Quote
Old 07-03-2017, 02:35 PM   #294
Airwave's Avatar
I just ordered some parts from RC market, many years after my last order, which was quite deceiving in term of availability...
Everybody deserves a second chance :-)
Airwave is offline   Reply With Quote
Old 07-03-2017, 03:16 PM   #295
Trader Rating: 44 (100%+)
RcJaz is a great site that sells serpent. Hong Kong based. Lots of 4x parts.
Shipping was only 3 bucks to the US for the linear suspension set.
Aaron Moore
Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 07-07-2017, 03:10 PM   #296
Airwave's Avatar
I'm looking for some feed-backs about the new parts...
From what I understand, the 401742 has been designed to provide linear feeling from the shocks, that's quite clear.
But what about the new steering rack (401745)? I suppose that it will modify the ackermann of the car, did somebody already try that?
What's the point with the new bumper top plate (401716)?
And the new roll damper support (401717), with 7mm instead of 8mm, I suppose it will make the roll part harder.
And Right servo plate (401718)? seriously?
Please, don't become Awesomatix!
Old 07-07-2017, 05:01 PM   #297
Only one I can comment on is the front bumper support. It's so the body posts don't go through the crease on some bodies. Like the Is-200 that I use on my stock car. The posts come right through the corner of the "hood" area. As for the other parts i'm not much help there as I haven't used them yet.
zeiler14 is offline   Reply With Quote
Old 07-08-2017, 01:43 AM   #298
dan_vector's Avatar
The 3 main updates to the car which are definately worth adding and make a tremendous difference is the VTD, RRS links and the linear pull rods. For now forget the rest as I don't believe make a huge difference.
401716 as above to narrow the body posts as some bodies don't fit the existing wide configuration very well.
401717 - I don't think this was ever released. Never seen it or heard anyone talk about it within the team.
401745 - I believe this was cancelled and never made/released.
401718 - hasn't been released yet but it just improves the way the servo mounts and influences flex.
Updates to a car is natural as the platform matures. I wouldn't be surprised if a 4x Evo 2 appears by the end of the year but for now I've added the main performance influencing parts to my car VTD, RRS, Short pull rods and the car is amazing.
chiefj48 and erchn like this.
Old 07-08-2017, 09:45 AM   #299
I just cut some mock 401717s and threw them on.
Substantially stiffer roll. Going to try them tomorrow.
Aaron Moore
Old 07-08-2017, 07:40 PM   #300
Benzaah's Avatar
Trader Rating: 21 (96%+)
What do you mean don't become Awesomatix?
I think the right servo plate will be for those who want to run a shorty battery and mount the servo on the battery side. The new bumper plate is in the latest kits and I would assume we will see the kits rolling out with the new linear mounts standard and maybe the RRS link plates. I don't think the top deck will be a kit item. Interested to hear your thoughts on the short roll supports. My cars been amazing since I installed the new parts.
dan_vector likes this.
Benzaah is offline   Reply With Quote
