    Hide Wikipost
Old 11-21-2016, 06:09 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Serpent Project 4-X
Last edit by: WagwanBumba
Introduction
This is a wiki page for the new and very interesting concept 4-X from Serpent. This is wiki is meant to develop and grow as more is understood about the car.
Serpent's Product Page - http://www.serpent.com/product/400030
The 4-X Development Story - Here
Manual - Here
Spring Chart
SOFTEST
  • 401705 Spring white C4.4 4X (2)
  • 401706 Spring yellow C4.9 4X (2)
  • 401707 Spring orange C5.5 4X (2) = kit
  • 401708 Spring red C6.3 4X (2)
  • 401709 Spring pink C6.9 4X (2)
  • 401710 Spring blue C7.6 4X (2)
  • 401711 Spring purple C8.4 4X (2) = kit
  • 401712 Spring greenC9.5 4X (2)
  • 401713 Spring grey C10.9 4X (2)
  • 401714 Spring black C12 4X (2)
HARDEST
Build Tips
RCBuilds.net Build, tip guide and youtube video - http://www.rcbuilds.net/builds/onroa...nt-project-4x/
Heave + Roll Damper Build Tips
Pivot Ball Nut Tip
Setups
Setup Tips
Ride Height Adjustment
Adjusting tweak with roll damper
Usage of washer on lower arm
Tuning ARS
Option Parts List
Social Media
Facebook 4-X Group
Print Wikipost
Like Tree57Likes
Old 02-22-2017, 08:25 AM   #226
Trader Rating: 37 (100%+)
Originally Posted by performula View Post
Is the Spur and Motor easy to remove? I'd like to try and get two classes out of the car. I'm done having a car for each class.
As most have stated...one of the easiest spurs to remove on a TC
Originally Posted by nubs View Post
I'm also interested in the Serpent 4x, but I want to know what setup for tracks is like compared to Tamiya cars... is it more complicated?
I would not say it's complicated. It's just different.
Originally Posted by SoLost View Post
I love mine! It's 'tricky' to setup because the platform is new and there are fewer setup sheets for one to copy.
Once you get a hang of it though, the car is great.
What worries is a little now is that Team Serpent don't seem to be having much luck with the car on the intl competition level. They just did poorly in Thailand. I worry it will suffer the same fate as the SRX4 (original innovative design) and give way to the 'standard' design like the SDX4.
TITC was crazy for sure. Felix Law did awesome in 13.5 Boosted consistently being in the top 10. Stick King from Asia was up there early on as well.
I owned an Xray T4 prior to this car and it worked very well. Almost set and forget. My first packs on the 4x I could tell there was a definitive difference in handling. The 4x just handled the entry and exit of corners so much better. Why...I'm not sure, but I was more comfortable with the 4x.
Now that a lot of guys are running we are seeing more and more setups. If you are running black CRC carpet just copy one of Paul Ciccerllos/Jeff Dayger setups and you should be good to go
I'd also follow the Facebook page if you use FB. Way more Serpent users active on there.
https://www.facebook.com/groups/SerpentProject4X/
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 02-22-2017, 09:15 AM   #227
performula's Avatar
Picked one up! Just can't find the starter kit in the US.
performula is offline   Reply With Quote
Old 02-22-2017, 10:11 AM   #228
nubs's Avatar
If I get one it will be from Rcmart since they are significantly cheaper.
teddymp9 likes this.
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
nubs is offline   Reply With Quote
Old 02-22-2017, 01:45 PM   #229
performula's Avatar
Absolute was $55 off.
Old 02-22-2017, 02:29 PM   #230
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Anybody run one of these in VTA racing?
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 02-22-2017, 08:44 PM   #231
performula's Avatar
Any Starter kits in the US, anyone, Bueller?
Old 02-22-2017, 08:48 PM   #232
erchn's Avatar
I haven't seen one in quite a while. Get some upper and lower arms, o-rings and option springs. Everything else has been solid. To be clear, I haven't broken an arm, but it's an obvious spare to have. Maybe a pair of hubs.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 02-22-2017, 09:34 PM   #233
performula's Avatar
Which O-Rings and Springs? I'm pretty sure it's "HD Ozite Carpet" something like that. Probably will try asphalt too.
Do they make protective film anymore for chassis' or maybe a recommended spray to minimize wear/marring from asphalt?
The upper and lower arms, and hubs are all symmetrical/compatible front and rear correct? Now, I haven't looked, but are all the parts symmetrical, from left to right?
Old 02-22-2017, 09:45 PM   #234
performula's Avatar
Also, is 111oz tq./w a .13 sec. speed servo enough power for this car? I don't need a ton of speed since I seem to overreact.
Old 02-22-2017, 09:46 PM   #235
erchn's Avatar
Look at petitrc and serpent's site for setups, plenty of examples. I'd get a couple sets of blue, pink, red and one set of green as a starter.
Protective, no ideas.
Yes, everything is symmetric.
Old 02-22-2017, 09:55 PM   #236
corallyman's Avatar
Trader Rating: 99 (100%+)
The lower and upper arms are the same front to back and left to right. The steering blocks are the same front to back but there is a left and a right on those parts. Its a great designed car
Steve
corallyman is offline   Reply With Quote
Old 02-22-2017, 10:27 PM   #237
performula's Avatar
Where can I order these parts? I can't find shops with any stock.
Also, which O-Rings, the shock O-Rings?
Did you all see my servo post? Sufficient, mediocre, weak?
Old 02-22-2017, 10:31 PM   #238
erchn's Avatar
SerpentAmerica has some parts, more will be rolling out soon, I'm sure.
Yes, shock o-rings, it's not critical. Some also use kyosho orange x-rings.
Servo should be fine.
You're welcome.
Old 02-22-2017, 10:38 PM   #239
performula's Avatar
You're welcome.
Haha I wasn't being rude!
Old 02-28-2017, 09:18 PM   #240
Benzaah's Avatar
Trader Rating: 21 (96%+)
Steve
Where are the markings that specify left and right knuckles? I cannot find any and you have me wondering about this.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
