Old 12-21-2005, 07:10 PM   #1
Default Battery Voltage and ESC's
Khan48 is offline   Reply With Quote
Old 12-21-2005, 07:14 PM   #2
Charlie O's Avatar
It will handle it no problem, and a 6 turn mod to boot!
Charlie O is offline   Reply With Quote
Old 12-21-2005, 10:35 PM   #3
fjm9898's Avatar
no not a lipo pack. i dont have one so i am only 99.99999999% sure that its cant use lipo because lipo is different then a 6cell pack.
and your question of 7.2v if you look at ur charger (if you have one with a readout) when a pack peaks it peaks usually over 9v even one from a few years ago. but lipo runs differently so they take special ESCs
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 12-22-2005, 12:14 AM   #4
FrankW's Avatar
Lipolys don't need a special kind of ESC. Lipoly cells are fully charged at 4.2 volts per cell. 8.4 volts peak for a 2S pack. Any ESC that's designed for 6 Nicd/Nihm cells should be able to handle that voltage without a problem. Most Nickel cells peak at about 1.5 volts (9 volts for a 6 cell pack).
However, what you won't have with a esc that's not designed specifically for lipolys is a low voltage cutoff. Lipolys don't like to be discharged much below 3 volts per cell. 2.7 volts per cell is about the lowest you can go before you start damaging them. It's not so much the esc you have to worry about ruining, but the batteries.
FrankW is offline   Reply With Quote
max battery voltage? joe of loath Rookie Zone 3 05-27-2007 05:18 AM
Battery voltage maskedrider Nitro On-Road 8 01-29-2006 06:49 AM
Battery Voltage? dragster Australian Racing 26 12-26-2003 03:14 AM
Battery voltage shortyzz Rookie Zone 2 11-21-2003 12:12 PM
Battery Voltage Loss. ProRacer03 Electric On-Road 0 09-16-2001 02:04 PM
SEO by vBSEO 3.5.0
