Corally SP12M
#91
12G3 Setup for Asphalt and/or Carpet
Hi all
Does anyone have setups for the G3? The only one I found is from 2000 Markus Mobers.
Rear Suspension :Graphite 2.1mm T-Bar No additional shock absorber
Corally Soft Orange Damper syrup (#80000)
Rear Tyres : Corally Green 52mm
Front Suspension :Aluminium A/R Frontbeam
Caster: 8 degrees
Camber: 1 degree
1.0mm Front Springs
Front Tyres Compound : Corally Silver 45mm
How do I set the car up for 8 degree camber? Any suggestions cause on asphalt I ran Extra Heavy damper syrup, center shock and had a lot of high speed push. Thanks
Caster: 8 degrees
Camber: 1 degree
1.0mm Front Springs
