Old 05-17-2016, 06:22 AM   #1
Questions?? New engine and ESC to Tamiya TT-01E
Hi all,
I'm new to On-Road models.
I've just came back from a vacation abroad with Tamiya TT-01E kit (VW Scirocco model).
I've bought the blue aluminium drive shaft & ball bears for upgrade.
I want to convert the kit straight-forward to Lipo set, was thinking about the
HOBBYWING Quicrun 10.5T 3650SD Brushless Motor 10BL60A ESC SPE Controller, what do you think about it? I plan to drive it with 2S LIPO, I think 3S might be too much for it.
Also, which servo should I equipped it with?
In the future will consider to purchase one of the Yeah Racing aluminium kit upgrades for it (the red seems to be pretty!!) and will hook it up with some unique body of a real VW Golf MK7 R32 look!
Thanks in advance.
CrAzYoNi is offline   Reply With Quote
Old 05-17-2016, 12:06 PM   #2
funked1's Avatar
Is this for racing or just play?
How about this one? http://www.hobbyking.com/hobbyking/s...bo_13_5T_.html
IMHO the best cheap servo:
http://www.hobbyking.com/hobbyking/s...08sec_45g.html
Streetjam SJF01 / M05 Ver.II R / Spec-R S1 VTA / Speedworld Raceway
funked1 is offline   Reply With Quote
Old 05-17-2016, 12:19 PM   #3
@Funked1, thanks for your reply!
This RC is for fun play!
What are the main diffs (besides the price) for the system you recommended against the one I've was thinking about?
Old 05-17-2016, 12:20 PM   #4
funked1's Avatar
And get some 500,000 cst oil for the front diff. This will help you minimize power oversteer with that much power.
Old 05-17-2016, 12:23 PM   #5
funked1's Avatar
10.5 gives you a little more power than 13.5. But the Hobbyking stuff is ROAR approved in case you want to go racing. And for that chassis, 13.5 is going to be PLENTY of power unless you mod the car a lot. Hobbywing has a better reputation for quality, but in my experience both brands have been reliable. The Hobbywing does come with a programming box which will cost your $10 extra if you get the Hobbyking stuff.
http://www.hobbyking.com/hobbyking/s...mming_Box.html
Old 05-20-2016, 04:24 AM   #6
Dear Funked1, sorry for my delayed reply.
Does upgrading the Tamiya TT-01E with the Yeah Racing red\blue aluminium counted as moding a lot of the car?
Because I do plan to do so in the next year.
Thanks!
Old 05-21-2016, 11:24 AM   #7
funked1's Avatar
That kit would help, definitely. I have some of those parts on my TT02.
Old 05-21-2016, 10:49 PM   #8
Funked1, what I meant was, should I continue with your recommendation for ESC & motor or with mine once when I'm definitely going to upgrade the car kit chassis?
Old 05-22-2016, 09:54 AM   #9
funked1's Avatar
Either ESC/motor combo will be fine. It will be overpowered but it will be fun. I think using 500k oil in the front diff will be enough to make it drivable.
Old 05-22-2016, 10:18 AM   #10
Which oil do you recommend for the back diff?
Old 05-22-2016, 02:17 PM   #11
funked1's Avatar
For the rear, just use the grease that comes with the kit, as per the instruction manual.
Old 05-23-2016, 09:31 AM   #12
If I understand correctly, a setup for On-Road with 2 differentials, while the back comes with Grease only and the front with 500K oil is for Drift purpose, isn't it?
I'm going to use it for touring mostly and on-road racing, does setup is good for it as well?
Thanks!
Old 05-23-2016, 09:44 AM   #13
funked1's Avatar
It will work great for touring / racing.
Check out this site: http://www.thercracer.com/2014/08/ta...-and-tips.html
This info is for a TT02, but TT01 is very similar.
Old 05-23-2016, 09:47 AM   #14
funked1's Avatar
Also check out these threads:
TT-01 Forum
Tamiya TT02 Thread
Old 05-23-2016, 10:12 AM   #15
Funked1, thank you very much for those resource.
