Old 07-30-2016, 12:33 PM   #31
Can I setup TT01-E with 30mm rear wheels?
I'm planning to order the Xceed Enneti 32\37 shore.
In front will install the 26mm.
CrAzYoNi is offline   Reply With Quote
Old 03-04-2017, 04:34 AM   #32
Quick question.
I've got the Tamiya TT01-E Running, took me ages to paint the body ;-)
The car with original setup comes with Pinion 19T and spur 61T.
It is very VERY slow! (at top speed).
I've changed the spur to 3Racing 55T but the 19T pinion cannot get to thew Spur now.
The TT01-E comes with a motor mount to set the distance of the pinion from the spur.
In the manual there's options to set it up to pinion with 22T, what am I missing?
Thanks in advnace!
Old 03-04-2017, 07:24 AM   #33
sosidge's Avatar
The 55 spur meshes with pinions from 25 to 28 teeth. Just be careful before you gear the motor too high as you might cause the motor to overheat.
