Like Tree8Likes
Old 06-10-2016, 05:06 PM   #61
EDWARD2003's Avatar
Originally Posted by Racermac73 View Post
You guys had me believing the yokomo was the car for me... that many smart racers unable to decipher a manual means I'll be leaving that car in Japan
日本語を勉強。
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 06-10-2016, 06:19 PM   #62
I'm pretty sure that you could figure out what to do with a Yok. Besides, once you get a chance to try driving mine, you may not even want anything more to do with a sliding kingpin.
vafactor is offline   Reply With Quote
Old 06-10-2016, 06:41 PM   #63
JimmyMac's Avatar
Ok, here's a dumb thought. Maybe the bulkhead shims are actually droop shims. Shim the bulkheads up more for more droop. Less shims equal less droop. Adjust the push rod for ride height.... No?
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 06-10-2016, 06:49 PM   #64
Racermac73's Avatar
I'd be shipping it right back to Japan for my buddy Edward to assemble
TEAM SCREAM, McFACTORY, TQ WIRE, 360 RACEWAY, XENON-USA.COM, SANWA, DESOTO RACING, JFT TIRES, HOBBYWING, EAM, DESTINY USA, DRIVE RC, TOP USA
Racermac73 is offline   Reply With Quote
Old 06-10-2016, 06:57 PM   #65
Probably not before first cutting a trick alloy chassis plate
Old 06-10-2016, 08:58 PM   #66
OriginalDonk's Avatar
Trader Rating: 38 (100%+)
Originally Posted by EDWARD2003 View Post
日本語を勉強。
I entered this into Google Translate to see if Edward was calling us idiots or having a little fun with the North American crew.
Looks like it means "studying Japanese" in Japanese. Well played Edward. Well played.
OriginalDonk is offline   Reply With Quote
Old 06-11-2016, 07:21 AM   #67
EDWARD2003's Avatar
Thanks, OriginalDonk. I can't hate on the N/A crew, because that's 99% of my YouTube audience. Lol
Looking at the manual and speaking with a sponsored Yokomo driver. The ride height is adjusted by the shins underneath the blocks (standard setup with most 1/12ths) and the droop/preload is adjusted by the friction damper rod. Adjusting the nut on the rod will adjust the droop/preload. Simple and effective, I like it!
tkge likes this.
                 VBC 12M - D08 - FX
Old 06-11-2016, 11:52 AM   #68
JimmyMac's Avatar
Awesome, thanks for checking in!
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 06-16-2016, 09:14 AM   #69
I'm curious as to how much this car weights. The R12C3 was a bit on the heavy side, what about this one?
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 06-16-2016, 08:44 PM   #70
JimmyMac's Avatar
I would say stock out of the box with the same motor, battery, esc, rx, (different servo) as my Roche.... it would be about 10grams heavier. Now my Roche had the Ti/Al screw kit and Xenon hard plastics with Xenon pivot balls in the frontend. The servo was a Futaba 9650. Not the lightest of servos but light enough. I could easily come in at or under 730g. The Yokomo with same body would come in around 742g. Servo in the Yok is Sanwa SRG-HR. A little smaller and lighter than the 9650. I also have Ti steering tie rods. That saved 2grams vs the steel ones. I should lose more moving to Ti/Al screws. I could lose 8grams from dumping the bell crank steering if I wanted. I could lose well over 10grams from a motor swap. But no dice on that. I run R1 motors. They come in at 170g for 17.5. Reedy comes in around 172g. Everything else is about 10~15g lighter.
Anyways, sorry I can't compare to the C3. But it is possible to hit weight or go under depending on your running gear.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 06-16-2016, 09:56 PM   #71
Thanks. I never could get my R12C3 under 750, and that was with aluminum and titanium screws and turnbuckles. The front end was particularly heavy.
Martin Paradis
Old 06-16-2016, 10:14 PM   #72
EDWARD2003's Avatar
Electronics play a key role in the cars overall weight.
Old 06-17-2016, 01:48 AM   #73
BardSmith's Avatar
Trader Rating: 61 (98%+)
This is what I ended up with... 734. But I used a bunch of Ti hardware also.
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 06-17-2016, 10:37 PM   #74
JimmyMac's Avatar
Are you having issues running the SMC 1s esc? I'm thinking about getting that esc, but I notice you have a booster or something soldered in?
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 06-17-2016, 10:45 PM   #75
JimmyMac's Avatar
One other question, are you running the XRay rear hub screws? I noticed you can't run BSR/CRC wheels in the rear with the kit screws.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
