Like Tree8Likes
Old 08-10-2017, 07:08 AM   #271
tkge's Avatar
Trader Rating: 97 (100%+)
Just FYI, the JR servo fits in both locations without any issues.
Tim Dunn
Tekno | Pro-Line | Maclan | DialedRCHobbies
tkge is offline   Reply With Quote
Old 08-10-2017, 07:08 PM   #272
TOM MAR's Avatar
Anyone know where a chassis plate can be found for C3 version?
TOM MAR is offline   Reply With Quote
Old 08-10-2017, 08:27 PM   #273
Mibosport.com
vafactor is offline   Reply With Quote
Old 08-14-2017, 07:55 AM   #274
neallewis's Avatar
How are people consistently setting the caster? Setup sheets have been filled in with a degree measurement, so say 6deg, and not a measurement in length, which is what the setup sheet shows. how are you measuring the slider to get the 6 degrees caster?
Trying to measure the caster with a 12th setup station is a bit hit and miss for my liking.
YZ-2 | B-MAX4III | 2x B-MAX2 MR | Cougar KF | RC10 | RC10WC | Supastox GT
neallewis is offline   Reply With Quote
Old 08-14-2017, 12:24 PM   #275
JimmyMac's Avatar
I don't worry about it. I just set it until the car feels about where I want it. I think Slapmaster has a setup tool that's more accurate for reading caster alone. Not sure if it'll fit the Yok though. I'll have to dig back through my information, but there was something that told how many millimeters equaled a certain degree on the blocks. Then you could go off of that to get a quesstimation. It should be listed somewhere that told the min and max caster you could set.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 08-14-2017, 12:34 PM   #276
TOADYY's Avatar
Send a message via AIM to TOADYY
See this post:
R/C Tech Forums - View Single Post - Yokomo YRX12
Originally Posted by antlockyer View Post
minimum caster approx 0.3 degrees, maximum approximately 8 degrees
3mm will give you 5 degress
I have the Slapmaster camber gauges and they do not work with the YRX. The kingpins are 2.5mm for the YRX and the Slapmaster gauge takes 3mm.
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
Old 08-14-2017, 01:43 PM   #277
JimmyMac's Avatar
Toadyy beat me to it with measurements. And good to know about the Slapmaster gauge.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 08-14-2017, 04:23 PM   #278
neallewis's Avatar
Originally Posted by TOADYY View Post
See this post:
Awesome thanks for all the replies. I was at 3.10mm, and haven't really changed from this since I've been running the car. That's what I guessed as 5 degrees with my cheapo hobbyking 12th setup station, so wasn't far off.
Car is awesome though, been running standard car for the last few months. My last proper 12th scale was an RC12L in the early 90's, then GT12 racing in more recent years. It tracks so well and is so precise, such a pleasure and rewarding to drive.
Is it worth springing for the yokomo alloy chassis? opinions please.
Old 08-14-2017, 04:37 PM   #279
TOADYY's Avatar
Only if running on the black carpet or where traction is very high.
Old 08-14-2017, 08:29 PM   #280
neallewis's Avatar
I run 13.5 blinky on black carpet on JFT A foams. Others run S foams or Hagbergs, but I've not tried them yet.
Old Yesterday, 12:43 AM   #281
antlockyer's Avatar
Probably not the same black carpet. UK (ETS) is much lower grip than CRC from what I understand.
antlockyer is offline   Reply With Quote
