Like Tree138Likes
Old 04-20-2017, 08:02 AM   #346
Trader Rating: 42 (100%+)
Originally Posted by J Lee View Post
Mine is almost done.
I'm going to run for the first time at 360 raceway tonight.
I also found few fitting issue on the front suspension, somebody needs to make that ball outta Aluminium IMO. until then I filed them down then polished them. moving well now.
Few tips I can share while I'm doing that is, I pulled out my old trick to popped the balls in and out easily without damage them. as shown above
Also, even though it shared same part # there is 2 different part as shown bottom of the pic
And that manual!!
Question: how do you achieve 3.8mm RH in the rear? mine seating at 4.2 with -1mm Rear ball bearing housing. maybe because of the brand new tire?
Happy Motoring!
In these type of designs I just use a rat-tail( circular) file and slightly open each hole on the a-arms until the ball and cup can literally just slide in. That frees the ball up. Then I just glue the cup to the arms and put the oring on just for added security although not necessary.
When you need to change them out just use a little debonder on them to remove the ca.
J Lee likes this.
Aaron Moore
McFactory Motorsports, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 04-21-2017, 05:04 AM   #347
JustWill75's Avatar
Send a message via AIM to JustWill75
What's a better battery choice for The F6? LP 3900, 3600 or should I look at the standard size shorty 4400 and up? I'm looking to get some fresh packs for this car.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 04-21-2017, 08:40 AM   #348
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
DARKSIDE, hobbyten, Dapmc3 and 2 others like this.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 04-21-2017, 03:41 PM   #349
CraigH's Avatar
Does the car require low profile shorties or regular ones like we use in the b6/b64?
AE TC7.1
AE B6d
AE B64d
CraigH is offline   Reply With Quote
Old 04-21-2017, 04:26 PM   #350
Regular one is fine.
Old 04-21-2017, 06:37 PM   #351
Motor/esc ordered today. Went with the Reedy 25.5 system.
Billy Kelly is offline   Reply With Quote
Old 04-21-2017, 06:51 PM   #352
4
On your ride ht .? The axle inserts that came in the kit should lower your ride height to the setting you need. If its not exactly the same amount just try it and adjust higher or lower depending on what you need from you're testing
Bubonic-X is offline   Reply With Quote
Old 04-22-2017, 06:14 AM   #353
Originally Posted by Bubonic-X View Post
4
I think you meant this for J Lee.
Aaron Moore
Old 04-22-2017, 01:50 PM   #354
Default Anondize
Early release photos showed the aluminum pieces different shades of blue. Curious if all the blue pieces are the same color and not a shade off? It's like AE blue to JConcepts blue if that makes sense
daveb is offline   Reply With Quote
Old 04-22-2017, 04:08 PM   #355
spring71's Avatar
Smile
We just received RC10F6 spare and hopup parts.
https://www.tqrcracing.com/shop/prod...keyword=RC10F6
FYI, Thanks.
liljohn1064 likes this.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 04-22-2017, 04:28 PM   #356
What length sensor wire are we using assuming recommended location? Also is there a kit for the forward servo setup? Parts seem pricey when you get them seperatly.
Old 04-24-2017, 04:03 PM   #357
Nego's Avatar
Trader Rating: 71 (100%+)
Pic of mi F6, took it to the track yesterday I must say a lot of guys liked the way it Handel! Just need to adjust ride height in the front,need help on that one.
Project X 1/10 pancar,17.5GT,BMI,yokomo,Associted F6.
Nego is offline   Reply With Quote
Old 04-24-2017, 05:39 PM   #358
All same color. Just a guess but could have the early photos been CGI. I've learned that is used far more then I ever thought.
Motor system arrived today.
Old 04-24-2017, 05:46 PM   #359
trixter91's Avatar
What motor is that
trixter91 is offline   Reply With Quote
Old 04-24-2017, 06:08 PM   #360
Regional Moderator
disaster999's Avatar
Originally Posted by trixter91 View Post
What motor is that
Hobbywing V10
disaster999 is online now   Reply With Quote
