Old 04-20-2016, 01:07 PM   #16
It won't let me post my logs but I'll give you the number comparisons between the two!
XLX /XL2
Voltage: 33.2/31.9
Ripple: 1.32/2.45
Current: 188.7A/226.7A
Watts: 5056/5777
RPM: 60,226/61,682
Throttle in: 1.887/1.965
Power out: 85.5%/100%
As you can see there's quite a difference! This was also testing the two esc's back to back, XLX first XL2 second with the same batteries!
MallenP30 is offline   Reply With Quote
Old 04-20-2016, 02:58 PM   #17
XLX /XL2
Voltage: 33.2/31.9
Ripple: 1.32/2.45
Watts: 5056/5777
RPM: 60,226/61,682
Pretty big difference but not quite as big as mine. From your test vids it looked and sounded like night and day. I found that a lot of times how it feels and sounds tells whats going on much more accurately than the logs.
tc4basher is offline   Reply With Quote
Old 04-20-2016, 03:50 PM   #18
I agree! It seems like these logs are hit and miss as far as accuracy goes!
Old 04-20-2016, 06:43 PM   #19
XLX /XL2
Voltage: 33.2/31.9
Ripple: 1.32/2.45
Watts: 5056/5777
RPM: 60,226/61,682
Thanks for the info. The current and ripple aren't that high which makes this even more concerning. Hopefully Castle releases an update soon.
0verkill is offline   Reply With Quote
Old 04-22-2016, 02:09 AM   #20
I doubt any firmware update that may or may not come out will restore the 80% power difference (2 hp vs 10 hp) that I experienced between the 2 ESCs. They are just buying time by saying they may come out with a power restoring update.
An unlock button that voids the warranty would work. Anything is better than this gutless POS XLX I got tricked into buying.
I am hoping for the best. In the meantime I am going to look into other ESCs.
What is a good upgrade comparable to a Castle XL2 that does not cost an arm and a leg?
drivejumpfly is offline   Reply With Quote
Old 04-22-2016, 04:14 AM   #21
The only other 1/5 scale esc that comes to mind is the Hobbywing but I don't know anybody who's tried it for speed runs! Other than that there's always Castle's heli esc's, only downside is there's pretty much no brakes or reverse and you also have to mess with throttle to get them to see 0 at neutral and not 50
Old 04-22-2016, 09:20 AM   #22
The Hobbywing Max 5 200a ESC is also A POS. If you try running more than 1000kv on 8s or 1600kv on 6s the throttle will cut out after 1 or 2 seconds of WOT. Hobbywing told me this is a safty mode it goes into. Did manage 113 mph one time with it on the same setup exact setup I went 134 mph with a XL2. Dont waste your money on Hobbywing either. Only good 1/5 option for speed is XL2 but they are all gone now.
Old 04-22-2016, 11:16 AM   #23
rc_user's Avatar
Toro beast 200a
http://www.skyrc.com/index.php?route...product_id=209
rc_user is offline   Reply With Quote
Old 04-22-2016, 12:10 PM   #24
Originally Posted by rc_user View Post
A friend of mine fried one of these the first time he ran 8s. Sent it in for warranty and the exact same thing happened again with the replacement.
Old 04-22-2016, 12:29 PM   #25
rc_user's Avatar
ok how about mgm
http://www.mgm-controllers.com/cars/...ntrollers-escs
Tekin claims the RX8 is rated for 220 continuous amps. it seems almost magical that an esc that small and light can handle more current that the toro brick.
Old 04-22-2016, 02:16 PM   #26
ok how about mgm
I've heard good and bad things about MGM, I believe they also have fail safes in place, not to mention they're expensive as shit
Old 04-22-2016, 02:29 PM   #27
Anybody tried the Turnigy Fat boy? 300A / 380A burst
Old 04-22-2016, 07:23 PM   #28
I have a,xlx, and I am also extremely disappointed in your findings. I have only done one test run on 3s. I found a few places online that still have xl2 in stock. My question is does this de tune effect these older stock xl2 ecs? Any feedback would be great.
bugetbasher is offline   Reply With Quote
Old 04-23-2016, 07:37 AM   #29
phildoggg's Avatar
Trader Rating: 24 (100%+)
the older xl2 would be fine still i just wouldn't update them.
phildoggg is offline   Reply With Quote
Old 04-23-2016, 10:50 AM   #30
Thank you Mr.phildogg, not happy about situation, first build for speed run and now this. Think I will break down and buy xl2, come to far to turn back now. Are there any other big ESC that anyone has had luck with? Seen many options, 300/400 amp, most are for heli or boat. Alien? Vxp? Any suggestions or opinions would be great.
