Like Tree48Likes
Old 07-11-2017, 08:43 AM   #1276
nubs's Avatar
Originally Posted by Schs2013 View Post
cool what Tooth count as im trying to figure out a good starting point
Nobody can tell you what ratio to use but in general people use a ratio around 4 for small to medium sized tracks. For medium to large tracks you want to use closer to 3.0 ratio. The ratio is highly dependent on your motor and should be adjusted based on the track layout. The more sharp turns higher your ratio should be. The more flowing and open the track, the lower your ratio should be.
The TA07 has an internal ratio of 2.05
Spur Gear of 55
Pinion of 28 = FDR 4.03
Pinion of 37 = FDR 3.05
So your pinions should be between 27 and 38 in most cases.
Johnn27 likes this.
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
nubs is online now   Reply With Quote
Old 07-11-2017, 08:00 PM   #1277
Schs2013's Avatar
TA07 is waiting for pickup at hobby shop! thank you for the help. looking forward to building it
VBC Lightning 10LM, WCICS spec M05v2, TA07 USGT 21.5
-Marc Gill
Schs2013 is online now   Reply With Quote
Old 07-12-2017, 03:38 PM   #1278
Schs2013's Avatar
Spur Gear of 55
Track during the winter is 5 rolls of Black carpet. layout changes every race day. normally leave it geared the same because the layout always changes expect for 3 day races/weekends where they stay the same.
be also using wrong ratio for gearing then as well i got to readjust the print out i have then.
-Marc Gill
Old 07-12-2017, 03:59 PM   #1279
nubs's Avatar
That sounds like a medium to large size track. Are there lots of tight turns?
Old 07-13-2017, 04:56 PM   #1280
Schs2013's Avatar
Like i said it changes from week to week.
-Marc Gill
Old 07-14-2017, 07:25 AM   #1281
Default Setup
Hi Need a bit of help, looking for a setup sheet for a TA-07 Pro on Tarmac
mjdennison is offline   Reply With Quote
Old 07-16-2017, 07:51 PM   #1282
First outing for my second-hand TA07 today, overall I'm super impressed. I haven't raced touring cars (aside from our Porsche spec class TA02s) since the brushed motor days and I can't believe how fast even USGT is!
The car came to me (and I ran it) mid-motor (most fwd position), silver springs in front white in rear, with a very thickly-fluided front diff and some HPI tires that were similar to the USGT spec ones. Track is black carpet. My initial job at sidewall gluing was not high enough and I had traction roll issues on top of the fact that I wasn't used to powering through corners with the thick front. First heat I lost a screw from the bottom of a C hub, second heat my servo saver screw backed out, but after some help I got everything sorted for the last two runs which were a blast. In those two I used SXT 3.0 on the rears only and found the car very nimble, rotating quickly under power. I gave the TA07 a heck of a beating today and aside from losing two screws it was no worse for wear.
Started at a 3.40 FDR and it was really fast but the motor seemed much hotter than my 17.5 buggy ever gets, so I took it down to 3.55. It performed okay but was noticeably running out of legs on the straights, might gear back up and add a fan (or take an actual temp measurement instead of being subjective) since it was still pretty darn hot that way too. And after I get the right tires on and see how that goes, I'll look at toning down the front diff.
altitudelow is online now   Reply With Quote
Old 07-16-2017, 07:58 PM   #1283
Core Creations's Avatar
Trader Rating: 94 (100%+)
Send a message via AIM to Core Creations
What motor were you running? The car looked good in your main!
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 07-16-2017, 08:11 PM   #1284
Thanks! Nice meeting you today.
I ran a trackstar 21.5 in the car. $28 worth of pure speed
Old 07-16-2017, 08:16 PM   #1285
We'll just as a reference I was running a Motiv 21.5 (older version and kind of weak) and I was at a 4.20. Temps were at 130 at the end of a run if that helps. I am at about 47 degrees timing.
Yes, good to meet you...glad to see so many TA07s out there today! We had at least 3.
Old 07-16-2017, 08:18 PM   #1286
Oh wow, I'll go that way and give it a shot. Thanks!
Old 07-18-2017, 09:03 PM   #1287
I was able to sneak back for practice tonight with the 07: FDR move from 3.55 (78/45) to 3.99 (78/40) brought the temps down from 'surface of the sun' to about 160, but I was at the absolute inner limit of the motor mount. Went up on the spur which put me at 4.40 and now the post-run temps were about 135. Next time round I'll work with the motor timing and see if I can find a sweet spot in between these gear extremes.
Also got the USGT spec tires on, and the car feels absolutely planted on black carpet. I'm very impressed by this kit.
Old 07-19-2017, 07:26 AM   #1288
JLock's Avatar
I use 48P with my USGT car. Less likely to strip. Easier to mesh. Less fine tuning capabilities.
Glad to see that I am not the only one running 48P gears in this car. My LHS doesn't carry the Tamiya-pitch gears and it seems to be a bear to get them in (if ordered).
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 07-19-2017, 07:45 AM   #1289
dougk's Avatar
I run 48P. Robinson Racing spurs work great.
I may be to old to cut the mustard, but I can still lick the jar.
dougk is offline   Reply With Quote
Old 07-19-2017, 07:46 AM   #1290
nubs's Avatar
I know of very few people that actually run tamiya gears. Most people use the standard 48 or 64 that I know. Although, there aren't many people running Tamiya where I race.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
WASPEEDRACER48
