Schumacher Mi6/Mi6 EVO
#303
#306
Agreed with this concept. I did it to my USGT for the Stock Wars.
However I am running the blink on my USGT now and finds the car work better on low grip track. Its give the car more rear traction and makes the car push on sweeper. Never had a gear mess issue with this setup.
I ran it in the Mi6 and took it right out.
#307
This will happen if you run 1 degree of camber if you run 2 degree camber the will push a little more in the corner. A little lazy for tight turns but really good on high speed sweepers. I also added a weight behind the battery to keep the car balance when I run the blinky mount.
#308
Super Moderator
#309
#311
The motor mount is the big change. It moves the motor in towards the center of the car and is shorter allowing more rear chassis flex. The chassis is also shaped different to allow more flex.
#312
I'm just hoping the aluminum chassis is ready for the launch of the car. I plan to start my early testing on black carpet.
Cant wait to start testing.
#315
