Help with comm lathes
#46
i never need to move the uprights on my integy auto lathe.i spent about 1/2
hour setting it up to my liking and have never needed to touch it since.
all i do is shim the arm with motor shims and im set.all lathes need to have your endpoint stop adjusted for every different comm.they are all different.even 2 motors of the same wind and manufacturer.if you decide to go with a diamond bit,always double check your endstop so you dont hit the tabs.that will be the end of your bit.
#47
Does anyone just use their finger on one side of the armature to keep it from moving? Seems to work just fine in a pinch.
#48
There are many here who use the finger technique. It works fine too.
#49
i used to use my finger but it burns after a while. no need to shim the arms to fit the blocks, use a pinion and lock the arm in place.
#51
I am looking to buy a Hudy lathe. Can you plug these directly into your power supply? Also, how many cuts do you get on a carbide bit vs a diamond? Anyone know the difference between Hudy 101001 and Hudy 101401? This will be my first lathe so I was wondering if I would be able to see a considerable difference.
#52
hudy advance comm lathe or orion quick set lathe?? which is better?
#53
orion lathe
i decided on the orion for my first lathe,i am very satisfied so far.can somene tell me where to get a diamond bit for it??the shop where i got the lathe acted like its impossible to get!! thx in advance
#54
Yes,you can plug it directly into your P/S IF you have a adjustable voltage P/S,the two lathes your looking at are the advanced lathe and the tech lathe,the tech lathe has a middle shaft to prevent transfer of motor vibrations to your arm while your cutting,I have the tech lathe and it is very nice,as soon as I get my fantom lathe in I will be selling my tech lathe.Always get a diamond bit and V-blocks when buying any lathe,the diamond bit will last you probably the life of the lathe and it can be repaired if you chip the bit.I recently had a buddy throw his away thinking it was ruined.
#56
Hyper,
Thanks for your help. You wouldn't want to get rid of that lathe a little early would you?
#57
Topher,
I would if I knew when the fantom was going to come in.Apparently they are in the process of making a new batch.
