What stock motor brushes are you guys useing now?
#61
...Putnam Green and Blue Combination win again at the US Open Wheel Champs...
In the last month we've won the following:
-Cleveland Indoor Champs
-UK National Champs
-Australian National Champs
-US Open Wheel Champs
Hope this helps...
-UK National Champs
Hope this helps...
#62
Originally Posted by MR JOLLY
forgot
USA guy`s love the heavy spring load on there stocks ie;purple/purple
but in the uk
if your car is setup so it carries a `LOT` of corner speed then you can get away with purple/purple ,but if your a point & squirt merchant ? then forget it ,motor be so hot after 5 min it would glow
we run softer setup`s really
heavy springs = more friction,more torque,less top speed ,more heat
lighter springs= less torque,less heat ,less friction,more top speed
1/12th cars love green/green spring setup (no need for pulling power ,cars weigh as much as a box of matche`s)
1/10th little different
if you run lighter springs then bed the brushe`s in @2-3 volt 1 minute
to get the brush bed in with out causing brush bounce (bad thing) when you go onto track
also bumby track with light springs does not mix either
but in the uk
#63
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by R/C Anonymous
why are some motor companies saying lighter springs give you more torque...which is the opposite u just mentioned?
i`m with the `others` then
every one is diffirent (including me)
so your saying then is green/green springs will produce more torque then purple/purple springs
(with splitting hairs on what brush is in use at the time )
#64
only some
#65
#66
Lighter springs produce more torque.....Heavier, more RPM.....I know it sounds weird, but thats the facts.....Todd Putnam will tell you the same...
Later EddieO
Later EddieO
#68
Later EddieO
Later EddieO
I'll be hittin the dyno hard tonight to try out a few more weird things.
#69
so i got it arse about face
but i was close
but i was close
#71
Originally Posted by Jeff Cuffs
2004 cleveland stock touring 2nd
2005 snowbirds stock touring Tq and 1st
2005 snowbirds 19t touring 1st
2005 vegas stock touring 1st
2005 cleveland stock touring TQ and 2nd
TRINITY 4499's E brush
#72
still going with
`They are All good` in there right (brushe`s that is)
