Like Tree1Likes
Old 01-25-2009, 11:52 PM   #1426
monkeyracing's Avatar
Does anyone happen to have a copy of the instructions for assembly of a TT-01E? Looking for the E version so I can figure out the steering linkage.
Thanks,
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 01-26-2009, 11:19 AM   #1427
JonesyCGY's Avatar
Too bad you hadn't asked me yesterday because I had it there at the races.
I won't be there next Sat, but if you don't have one by the following week I will bring it then for you.
If I remember tommorow I'll bring it to work and scan it into PDF
JonesyCGY is offline   Reply With Quote
Old 01-26-2009, 06:34 PM   #1428
No worries. I fired up the ol' brain today and figured it out. Thanks for your offer, though.
Just a note for everyone else. If you are adding the TT-01E style upper chassis brace to your TT-01, you will have to shave a little off the top of the front mounting points on the chassis. Other than that, it's a bolt on.
Jim
Stab it and steer.
Old 01-27-2009, 12:45 AM   #1429
Bullz's Avatar
Smile Nissan GT-R R35 LED TT-01 Type E with Ezrun 5.5T brushless
Hi guys, i just bought a Tamiya Nissan GT-R R35 LED TT-01 Type E and planning to install a Ezrun 5.5T brushless into it. Will it cause problem? As a new player i am not sure should i go ahead and install the 5.5T brushless or not. Please advice. Thanks in advance.
Bullz is offline   Reply With Quote
Old 01-28-2009, 03:55 AM   #1430
fat500's Avatar
Trader Rating: 29 (100%+)
I am running a tt01 in a 2 hour enduro in south florida and was told the stock chassis will heat up too much allowing the motor to shift and stripping the spur gear due to the plastic tamiya uses on the tt01. Can anyone confirm this? i would love to finish the race. Any input helps Marc
fat500 is offline   Reply With Quote
Old 01-28-2009, 08:05 AM   #1431
depressedbunny's Avatar
ive never had that problem
TT-01 (with mods),
TB-02,
old skool
Tamiya hornet
FF
depressedbunny is offline   Reply With Quote
Old 01-31-2009, 05:19 AM   #1432
Originally Posted by depressedbunny View Post
im running a 58/24 setup with a 21T motor,
TEU-302BK ESC,
7.2 v 3300 NiMH,
upper carbon deck,
Aluminium Motor Heat Sink,
Aluminium Racing Steering Set,
Front & Rear Stabilizer Set,
Adjustable Upper Arm Set,
Tamiya Aluminium Dampers 4WD/FWD & Rally Car,
Aluminium Prop Shaft,
GPM Titanium Middle Shaft Joint Set,
Bearing Set and
50476 Tamiya Rally Block Tyre.
not changed much
still running a 21T motor but now 55/25
and drift tyres
and hpi front wheels, tamiya rears
only thing is i keep smashing up my rear wheels
TT-01 (with mods),
TB-02,
old skool
Tamiya hornet
FF
Old 01-31-2009, 06:10 AM   #1433
Thanks,
Jim
Here.
stocker is offline   Reply With Quote
Old 01-31-2009, 10:58 AM   #1434
Originally Posted by stocker View Post
Thanks! I got it put together, but did have to modify one part a little tiny bit to get the front part of the upper chassis brace to sit down properly.
Jim
Stab it and steer.
Old 02-07-2009, 11:56 AM   #1435
what set of trf shocks i should get
and what item number should i pick
thanks for any help i can get on this
CHROMETWANKIES is offline   Reply With Quote
Old 02-08-2009, 06:11 AM   #1436
kavadni's Avatar
42102 or 53571
kavadni is offline   Reply With Quote
Old 02-08-2009, 12:34 PM   #1437
whitrzac's Avatar
Trader Rating: 94 (100%+)
I just picked up a TT-01D for $40 I'v never had or even looked at an onroad before...
I was thinking of using it as a VTA car, are there any needed upgrades?
any hits, etc that I should know?
whitrzac is offline   Reply With Quote
Old 02-08-2009, 01:23 PM   #1438
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
My RTR TT-01 Type E is on ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=270341970398
SerpentCT4S is offline   Reply With Quote
Old 02-08-2009, 07:52 PM   #1439
gto0209's Avatar
Zack, bring your sedan if you come to rcp wednesday night. I can help you sort out some stuff such as ride height, gearing and camber. I have a body and a set of tires you can have. I would recomend using this to practice and see if you like sedans or not.
Charlie
long live f-1
gto0209 is offline   Reply With Quote
Old 02-09-2009, 05:01 AM   #1440
whitrzac's Avatar
Charlie
thanks, IDK if I will have it by then, he's going to ship it today...
I'll be down there on wed. though to race my slash.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
