Like Tree1Likes
Old 01-02-2009, 08:26 PM   #1411
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
Originally Posted by function>form View Post
i got my yeah pack in there by loosening up the screws that the battery strap clips go into,think it was about one turn on each and it was snug...
i went for a SMC 4100 that will do double duty in the CR as well. trim gussets in 1/2 and she drops in perfect. i could eventually get an orion that could also play nice in the f103, but $ and no1 local had any--have to wait for online.
maiden voyage for this TT (my 6th) in senior spec 2mrw, see how she goes. need to find some 5mm shims and fast, or else traction rolling abound i'm told. ugh
R
UltegraSTI is offline   Reply With Quote
Old 01-03-2009, 07:38 AM   #1412
rccardr's Avatar
I have yet to run into a traction rolling problem at The C, either with kit treaded radials (slicks might be a problem, especially if used without an insert) or X Patterns (I use the Pro compound belted, but the D compound or Pro unbelted might deform more- like the slicks mentioned above- and cause a problem), both of which are mounted on zero offset wheels. I do not use spacers or 6mm hex drives, so my car's a little on the narrow side. Works great.
Setup is 4.5mm ride height all around, TRF shocks with 2 hole plastic (not teflon) pistons, 40 wt Losi oil, and short blue springs. Cheapo Futaba 3004 servo, too. Runs like a champ.
Give it a little setup time (mine took a few weeks to figure out) and you'll be flying!
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 01-03-2009, 07:44 PM   #1413
RielTime Racing's Avatar
What are your thoughts or opionions on the topic of gearbox ratio's Gear Box Ratio's
RielTime Racing is offline   Reply With Quote
Old 01-04-2009, 10:54 AM   #1414
Registered User
UltegraSTI's Avatar
doc, when #11 is not on fire, its fast. wonderin if there's somethin wrong in my drivetrain causin the heat. granted going back n 4th with josh M for 2nd fastest car behind ray seemed to dispell that somewhat. i rolled alot when grip came up and tires were no longer new in rd3. had 2/2 shims wise and it does help. idiot me though forgot had 2mm height spacers in front and rear. took those out, no roll. still not quick enuff for rayK, he can still pip a 13.0 (usually 13.2s are his best) once in a bit while i'm stuck at 13.4. not bad for a fresh car and a rusty driver.
R
Old 01-04-2009, 06:58 PM   #1415
rccardr's Avatar
Could be it needs a Special Cleaning, but I also hear that once you went through the drivetrain again it got somewhat more free. I think it takes a couple weeks for the drivetrain on these cars to bed in and get aligned.
Ray sent me four of the slightly tired motors and they got rejuvenated this past week. Will be fun to see how things look next Saturday.
Welcome to the club!
I've never lost.
Old 01-06-2009, 09:08 AM   #1416
chef88's Avatar
Trader Rating: 48 (100%+)
Does anyone know what is the internal gear ratio of the TT01?
Thanks.
chef88 is offline   Reply With Quote
Old 01-06-2009, 09:18 AM   #1417
chef88's Avatar
R
You drove too fast... that what was wrong with your drive train
Ok, I was lazy The ratio is 2.6
Old 01-06-2009, 06:03 PM   #1418
superior1's Avatar
Smile TT01 Gearing ???
Hi,
I'm have a TT01D use for touring, with a HobbyWing 9turn brushless motor, 35Amp ESC (combo set)
Like to know how to match the gear ratio ???
Using a stock 61turn spur gear, can i use a 24/25 pinion gear ???
Will this config. fry the ESC... ???
Kindly PM me with an answer.
Thank you all in advance.
Hope to hear soonest
Eric (superior1)
superior1 is offline   Reply With Quote
Old 01-07-2009, 12:39 AM   #1419
sporadicidiocy's Avatar
Largest pinion for stock spur is 22T
This is my bible for proper mesh and gear ratios.
Credits to whoever posted... I forget.
90% Sakura Zero: Reventon S V3.0 10.5T
Sakura Ultimate: GTB2 17.5T
F104 Pro: SXX V2 Trackstar 21.5T
F103 Chevronmodels 6-wheel conversion
sporadicidiocy is offline   Reply With Quote
Old 01-07-2009, 10:29 AM   #1420
IndyRC_Racer's Avatar
Here is a better version of the gear chart which includes more pinion options for the F201 gear.
IndyRC_Racer is offline   Reply With Quote
Old 01-19-2009, 06:50 PM   #1421
depressedbunny's Avatar
what mods are needed to run the highest gearing setup
TT-01 (with mods),
TB-02,
old skool
Tamiya hornet
FF
depressedbunny is offline   Reply With Quote
Old 01-22-2009, 09:43 PM   #1422
monkeyracing's Avatar
Heya, I picked up a TT-01 recently, and now want to upgrade a bit. I see that the TT-01E has some improved parts on it that will help with the sloppy steering a bit. Can I just buy those parts (A & D for TT-01 E) or is there some other fundamental difference between the two that I've missed?
BTW: Dont mention anything about any alloy, bearings or whatever. We're running spec. That means that you can only use parts that came with the TT-01, TT-01D or TT-01E.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 01-22-2009, 09:57 PM   #1423
TT01D has full ball bearings, motor heatsink, and adjustable camber arms.
Yes, you can buy those parts. Bear in mind, you need 2 pieces of part A5, or modify the existing part by sanding/grinding.
stocker is offline   Reply With Quote
Old 01-23-2009, 06:32 PM   #1424
JonesyCGY's Avatar
Jim
Hi Jim,
Am I misunderstanding the rules at Karz, because it does say in the rules that you can upgrade the following:
Upgrades to the cars are limited to:
*bearings
*oil dampers & springs
*adjustable upper wishbones
*upper reinforcement plate
*clamp style axle nuts (5mm)
I just bought a TT-01E and plan on putting bearings in and TRF Shocks later down the road.
Ian
JonesyCGY is offline   Reply With Quote
Old 01-23-2009, 08:21 PM   #1425
It's true that the only stated upgrades are bearings, etc. but since the TT-01E parts I'm interested in are part of an approved TT-01 kit, then they are eligible to be put on to my existing TT-01.
Really the only kit part not eligible is the black can motor from the TT-01D. (or any of the parts unique to the TT01R)
Another interesting and unstated upgrade are the wheels and axles from the Ferrari Enzo kit. They have a different offset and use a slightly wider axle.
Jim
Stab it and steer.
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
Tags
drift
