Old 12-17-2008, 06:18 AM   #1381
xxSLiMxx's Avatar
I just finished this body for my TT01, its now a shelf queen. Thought id share. Enjoy!
xxSLiMxx is offline   Reply With Quote
Old 12-17-2008, 08:26 AM   #1382
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
need to find out what lipos fit in the tt01. my YR4000 does not w/o trimming the gussets outta the tray. dont want to do that if i can avoid it. suggestions thx
R
UltegraSTI is offline   Reply With Quote
Old 12-17-2008, 10:04 AM   #1383
Registered User
UltegraSTI's Avatar
well this build has been rough, well the build itself is technically a non-event. sad 20yrs, over 70 cars, 25 tamiyas, 6th TT and i cant get past page 1. why?
chassis mold is incorrect. cant get teh bearing in front of the spur down into its slot. the slot is too small, u can push it down in there but it pops back up. amusing. that and the rear prop shaft isnt not fitted correctly. when built the ring cant go back on the spur fully. so even on a good chassis which i picked up last nite (tamiya is sendin me another chassis as well), it still rubs the spur on the chassis. remove the pin and all installs fine naturally. so tamiya is sendin me a prop joint w/the chassis.
outta curiousity i pulled some arms outta the bag and put them into their guides to check the arms. this chassis coulda been a pan car b/c u could not rotate the arms. in fact pulling 1 of them out required needle nose. toss that lot. new chassis here, but need to source a prop joint. hopefully tam gets 1 here in the mail 2day, perhaps 2mrw. no shops around with 1. ugh.
equally rough tryin to get a human on phone at tamiya. econony i'm sure...
R
also need to find a lipo that fits, same goes for f103RM, but at least i have that to look 4ward too. w00t
Old 12-17-2008, 10:54 AM   #1384
xxSLiMxx's Avatar
Im running 3200/3600mah Yeah Raceing lipos and they fit fine.
Old 12-17-2008, 10:43 PM   #1385
mr crawly's Avatar
Originally Posted by xxSLiMxx View Post
25pinion and 55spur will give you the most speed, unless you custom fit a higher gearing. Also a higher Kv rated motor will get you more speed.
thanks figers thats what i need but was a little confused, thanks may i ask how fast your car goes, im military and i work with metal, making parts and tools so ill try that to
DANNY
mr crawly is offline   Reply With Quote
Old 12-17-2008, 10:47 PM   #1386
xxSLiMxx's Avatar
Iv toped mine out at 78.3KpH (GPS Tested) with 25/55 gearing and my 9T brushless and 2S lipo. It was fun for a speed run but motor/esc got too hot.
Old 12-18-2008, 05:36 AM   #1387
rccardr's Avatar
Ulti- As you know, Ray and I have built quite a few TT01's over the past several months and we have seen a number of them with the arm-clearance problem. We've tried sanding down the arm pegs but you have to be careful because the problem molds are done with some sort of reinforced plastic that gets all hairy when sanded with coarse paper (I wound up using a sanding drum on a Dremel). Best choice might be to ream the holders, but I don't have a reamer that size on my bench, so we sanded instead. The bearing thing is a new one, haven't seen that with either a regular or E car, but there you have it.
Gonna join us in Senior Spec?
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 12-18-2008, 07:08 AM   #1388
Registered User
UltegraSTI's Avatar
that was the plan doc, still waitin on the parts :/ might have to bum a car if this keeps up.
R
Old 12-18-2008, 04:49 PM   #1389
mr crawly's Avatar
sweet thanks im gona make a gear box to make it faster, i know my car will be all over the place but i can drive it , suspension will be a problem but o well ill see what hapens
DANNY
Old 12-18-2008, 04:54 PM   #1390
mr crawly's Avatar
my car but it needs some work
DANNY
Old 12-18-2008, 06:41 PM   #1391
rccardr's Avatar
Don't hesitate to ask for a loaner if your parts don't come on time. The loaners even TQ from time to time...
I've never lost.
Old 12-18-2008, 10:16 PM   #1392
#88driver's Avatar
R
The Core-RC 3250 mAh will fit in it without trimming the knotches on the chassis
Colton Jaynes
*RC America*Hudy*Xray*Jaco*KO Propo*SMC*EA Motorsports*
rchobbiesstore.com
#88driver is offline   Reply With Quote
Old 12-19-2008, 06:03 AM   #1393
Registered User
UltegraSTI's Avatar
warranty parts came in. chassis was incorrectly molded at the bearing guide and the rear prop joint had its crosspin hold drilled incorrectly by just over 1mm. now i can build the car finally!!!
R
Old 12-19-2008, 03:29 PM   #1394
Registered User
UltegraSTI's Avatar
update
did tamiya have a bad run of molds? this tt01 i just got direct from them (the 75$ benz--my 6th TT) is the worst kit i've ever dealt with in terms of QC. the chassis and rear prop joint were already warrantied successfully. but the upper arm holders and both main bulkheads are in horrible shape in terms of their tolerance. even after checkin and scoring for all flash. i can still set my car at ride height without shocks!!!! complete with a 4200 sittin the car.
alas, more work to be done. granted now if i glue em in and make it a pan car, i wont have to worry bout down travel lol.
R
Old 12-23-2008, 06:11 PM   #1395
mr crawly's Avatar
need help i ordered a 55t spur and it did not fit
DANNY
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
Tags
drift
