Like Tree1Likes
Old 11-13-2008, 10:33 PM   #1336
Do you reckon the rear cf damper stay would work with a noraml TT01 bulkhead if i cut off all the plastic shocktower??
Drift Demon is offline   Reply With Quote
Old 11-13-2008, 11:17 PM   #1337
rough512's Avatar
Originally Posted by kavadni View Post
It replaces the plastic ring that holds the spur gear in place.
Tamiya call it the spur gear stopper. Part number GB2 in the D Manual.
They wear away, and then the spur slops front to rear, and that wears away the tub.
Kevin
You don't need this. A drop of CA works better at keeping the spurgear in place and at preventing wobble that resuults when the plastic ring moves away from the gear.
The super glue can be easily chipped away with an exacto knife when the time comes for a spur gear replacement.
rough512 is offline   Reply With Quote
Old 11-17-2008, 06:36 AM   #1338
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
finished my spur adapter and it works. I will try to post pics and a write up of how it was made.
I also figured out the 64 pitch gear combos for the A, B, C, & D motor mount positions.
A 121 total teeth
B 123 total teeth
C 125 total teeth
D 127 total teeth
I will post more later
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|Associated B5M|TA05|TL01RA|TL01|F104 Pro|RM-01
f1larry is offline   Reply With Quote
Old 11-17-2008, 07:59 AM   #1339
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
larry, please include the parts number. thanks dude
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 11-17-2008, 12:29 PM   #1340
f1larry's Avatar
There really is not any part numbers.
Just a quick tease of materials needed:
3/8 inch stainless steel pipe from the hobby shop (piece cut in length equal to the thickness of the plastic washer)
(this pipe's outer diameter is equal to the inner diameter of spur gears. the pipe's inner diameter is also equal to the outer diameter of the 61t spur gear side where the pin goes in)
stock 61 tooth spur (teeth cut off)(this part would be awesome if someone can machine an aluminum version that the screw holes could be threaded, then you would not need the nuts and the clearance would be that much better)
couple of 3mm x 6mm flat head screws
couple of 3mm thin nuts
spur gear of choice with holes to put screws through counter sunk.
Pictures still to come, I have to take the car apart again to take pictures.
Larry
Old 11-18-2008, 02:40 AM   #1341
hey i have the hobbywing 60 a esc and i was just wondering can you run brushed motors on it aswell?
and also f1larry im really interested to see the pics of ur spur adapter as i really want to make 1 aswell .
scottwhat12 is offline   Reply With Quote
Old 11-18-2008, 02:52 AM   #1342
I pretty sure that you can run a brushed motor without any problems. Take a look at the hobbywing thread there was atleast one person on there that said it works with no issuse.
Jay
~ Jason Kennedy ~
~ Sweep Racing Tires ~
~ TQ Wire~Wire~
pyro18t is offline   Reply With Quote
Old 11-19-2008, 09:04 PM   #1343
f1larry's Avatar
here are a couple of pictures of the spur gear adapter I made.
remember the maximum number of teeth for spur/pinion are as follows
a - 121
b - 123
c - 125
d - 127
let me know if you have any questions
this one shows a slot you need to cut into the motor mount t be able to tighten the pinion.
Old 11-19-2008, 10:15 PM   #1344
THAT PINION IS HUGE!
What size is it? And what kind of speed do you think your running
Jay
~ Jason Kennedy ~
~ TQ Wire~Wire~
Old 11-19-2008, 10:18 PM   #1345
that thing must go crazy fast. does the front end hold out in the speed or does the car get extra twitchy? sweet fab job either way.
rexvirtue is offline   Reply With Quote
Old 11-19-2008, 10:44 PM   #1346
f1larry's Avatar
Jay
The car is set up for T/A(usvta) 4 cell 27T.
it is geared at 39 x 84 for a fdr of 5.6
Old 11-19-2008, 10:55 PM   #1347
Pretty cool. How do you like running 4 cells?
Jay
~ Jason Kennedy ~
~ TQ Wire~Wire~
Old 11-20-2008, 12:48 AM   #1348
Martinst's Avatar
Are the steering arms different on the TT01E ? I ask as I want to fit the TT01E topdeck to provide the top support for the steering posts, but want to ideally keep my alloy upgraded TT01 steering arms. I'm assuming having the posts supported top and bottom is a far better and efficient system.
Martinst is offline   Reply With Quote
Old 11-20-2008, 04:06 AM   #1349
f1larry's Avatar
Jay
The 4 cell class is the US Vintage Trans Am class see here U.S. Vintage Trans-Am Racing
I have not run this car in this class yet, I am building it for my son. I run my TB EVO III in this class and it is a blast.
Old 11-20-2008, 04:11 AM   #1350
f1larry's Avatar
The steering arms for the TT01E are plastic versions of the aluminum ones. what you describe is exactly how the upper deck works.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
