Like Tree1Likes
Old 06-26-2006, 06:45 AM   #121
rays_tt's Avatar
Trader Rating: 26 (100%+)
yeah whoever you got that off stooged you bad, its a TL-01 not TT-01
rays_tt is offline   Reply With Quote
Old 06-26-2006, 10:55 AM   #122
Default TL-01
It may be a TL-01 but it's still a pretty good car. You are limited in your gearing choices and hop-ups but it can still be quite competitive if you wish to race it. Another bonus with this car is that it shares some parts with the Tamiya M-03 chassis and TA-03 drive train (ie: ball diffs) as well.
Enjoy it!
hudsong is offline   Reply With Quote
Old 06-29-2006, 06:01 AM   #123
Trader Rating: 8 (83%+)
i just ordered my 4th tt01
its the new NISMO R34 Z-TUNE
im gonna have it painted metalic blue and its gonna look really nice
ill post pics when it gets here
i730 is offline   Reply With Quote
Old 07-10-2006, 10:59 PM   #124
nino_pohan's Avatar
Where can i get pinion gear 26T and 27T, have tamiya made that pinion?
nino_pohan is offline   Reply With Quote
Old 07-11-2006, 12:20 AM   #125
so has anyone figured out how to get rid off some of the suspension slop? i spaced the shocks with tb02 shock spacers and i hope that cleaned abit of it up, but theres still plenty of slop left. has anyone tried wraping the wheel axle(the thing that fits into the cup) with a layer of electrical tape? im thinking electric tape will be relatively tough and hopefully slick enough to not cause too much friction. thoughts on this?
SSJChar is offline   Reply With Quote
Old 07-11-2006, 12:36 AM   #126
peter p's Avatar
teflon tape is what your looking for.i had a tt 01 and it works fine
peter p is offline   Reply With Quote
Old 07-11-2006, 05:16 AM   #127
The plastic used on this car wears really fast, try getting parts for the car when they start to wear.
Juan Aveytia is offline   Reply With Quote
Old 07-11-2006, 10:04 AM   #128
alright thanks for the help guys. i couldn't find any telfon tape around the house, so i guess we used it all, so ill go buy some in abit. ill also clean off and relube all the friction areas.
Old 07-12-2006, 01:42 AM   #129
hey folks.
Wow... I remember starting a TT01 thread about a year ago that really grew. Glad to see the chassis is still popular.
I've turned my TT01 into a drift car, and using a TB02 for racing.
I have a bit of a problem though. I don't have the gearing chart for the TT01 for using a 58T spur gear. Can anyone tell me which mounting holes (A, B, C or D) is to be used for a 58T spur, 21T pinion?
Thanks!
dugrant153 is offline   Reply With Quote
Old 07-12-2006, 02:12 AM   #130
shift's Avatar
you cant use the 21 pinion with that spur the smallest you can go is the 22 pinion in hole A
shift is offline   Reply With Quote
Old 07-12-2006, 02:20 AM   #131
rays_tt's Avatar
here u go enjoy =) i found that the 58t spur goes really well with the 23t pinion for racing, but i drift with tt01 now so i found that stock gearing is just fine as you need the torque
www.melbRC.org
Old 07-12-2006, 10:37 AM   #132
billjacobs's Avatar
Trader Rating: 54 (100%+)
Default differences between a tt01 and a tt01-r
Many have asked the differences between the tt01 and tt01-r kit. A lot of the answers have been incomplete and were based only on tamiya's description which is also incomplete. I have both kits, and here are the differences:
1) what does the regular tt01 have that the r doesn't:
a) body
b) electronic speed controller
c) silver can motor
2) what does the tt01-r have that the regular 01 doesn't
a) 25t tuned motor
b) 4 super mini oil filled shocks
c) full ball bearings
d) aluminum drive shaft
e) aluminum drive shaft pickups
f) metal dogbones and cups front and rear
g) adjustable upper arms
h) new a-arms with droop adjustment
i) all aluminum turnbuckles and shock mounts
j) 3 different spur gears
k) toe in rear uprights
l) softer tires
The cost difference is:
tt01 89.99, tt01r 134.99
The best hop ups for the tt01 are:
oil shocks $28
ball bearings $19
toe in rear uprights $11
front steering turnbuckles $6
Total for tt01 is $154.
For the tt01r, you need to add a body and a speed controller. The speed controller that comes with the tt01 is about $30 and the body is also $30. This makes the tt01r $195. For the $40 dollars difference you get a much stronger drive train, aluminum drive shaft, and fully adjustable suspension.
Hope this helps.
billjacobs is offline   Reply With Quote
Old 07-12-2006, 02:57 PM   #133
thanks for the gearing chart. That really helps alot!!!
when I bought the TT01, they were just talking about an R version of the car. I'm surprised they've upgraded it so much, but after running my TT01, I realize that those upgrades are needed. I have the old upper and lower suspension arms and they suck. the driveshafts are pretty okay (they've popped out on one occasion), but the steel ones would be better.
Old 07-12-2006, 08:13 PM   #134
nino_pohan's Avatar
Anyone have tried gear from tobbe craft :
42530 TT01-01 A high ratio gear & pinion gear set
you can see the web http://www3.kcn.ne.jp/~tobee/tt01%20english.htm and http://www3.kcn.ne.jp/~tobee/English.htm
Old 07-12-2006, 08:22 PM   #135
nino_pohan's Avatar
rays_tt, where can i get pinion 26-28T, because i play 23T motor so gear must under 6.20. Can i use 0.6 pinion gear for 55T? please help me...
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
Tags
drift
