Like Tree1Likes
Old 11-04-2008, 05:20 PM   #1306
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
yep, couldnt agree more...
great info guys
mok is offline   Reply With Quote
Old 11-04-2008, 06:51 PM   #1307
kavadni's Avatar
Originally Posted by f1larry View Post
I have been able to make a spur gear adapter for the TT01, Now I just need to know if anyone has an idea of combonations that will work for 64 pitch gears. trying to get fdr's to be able to use a 21.5 in T/A.
Larry,
If your still running a plastic tub, the problem you will find is that the 4 mounting points on the motor mount move such that each increment is 1 tooth on 06 module (AV) pinion or 3 teeth on the spur.
64 pitch or even 04 module s going to be tricky to work out what meshes if you have plastic tub .. trial and error.
If you have the 3Racing CF upgrade and sliding motor mount, your'll be ok.
Just calculate using a 2.6 internal ratio.
Cheers
Kevin
kavadni is offline   Reply With Quote
Old 11-05-2008, 03:41 AM   #1308
Knights Cross's Avatar
Originally Posted by kavadni View Post
It replaces the plastic ring that holds the spur gear in place.
Tamiya call it the spur gear stopper. Part number GB2 in the D Manual.
They wear away, and then the spur slops front to rear, and that wears away the tub.
Kevin
Ok, thanks Will definitely get this part since i'm on a 9.5T brushless now. Anyway I had some good runs recently. I solve the traction roll issue by having a front red short spring (very hard) and white short spring (hard) at rear from my serpent 960. Also loosen the rear ball diff 30mins from tight position and front still maintain fully tight. Track width is still at 175mm and no droop adjustment... i was playing on a smooth cement basketball court and the car handled really well By the way, this is just a temporary solution, getting the arm with droop setting is better.
Pix shows the basketball court turned to makeshift track, the front and rear spring..fitted in just nice.
TT-01 Forum-a02112008750.jpg   TT-01 Forum-a05112008753.jpg   TT-01 Forum-a05112008754.jpg
Knights Cross is offline   Reply With Quote
Old 11-05-2008, 03:53 AM   #1309
kavadni's Avatar
Are they the E Diff housings? If so, how many shock mount points do the shock towers have?
Old 11-05-2008, 03:58 AM   #1310
kavadni's Avatar
Originally Posted by KREATOR1 View Post
Hi,
Does the TB-02 spur gear same like the TT-01? they look the same , only the part number is different. Any of you tried ?
Larry show us some picture of your spur adapter
I have read that you can use the 52T, and that it allows you to use a 28T pinion in position A - (I presume 29 to 31T also).
But I have never tried it.
Kevin
Old 11-05-2008, 05:54 AM   #1311
mok
mok's Avatar
Yeah our TT-01's rolled badly the first week we raced them .. they were stock.
Treaded Tyres on carpet
An 80g left-2-right weight imbalance
But yes still a load of fun.
Kevin
as does everyone who rocks up with a brand new tt-01 complete with subaru imprezza body and treaded tyres :P
...interesting though, havent seen one of these at the track for a while?
Old 11-05-2008, 05:54 AM   #1312
those are the Tamiya CF shock towers, Front = 4 slots, Rear = 3 slots (on TRF damper, = 2 slots on M Chasis damper). I m using the M chasis damper as the front CF shocktower sits lower than the original plastic from kit.
The original E chasis plastic shocktower have 3 slots (1 slot at centre for body post) holes on both F & R.
Old 11-06-2008, 07:01 AM   #1313
I thought I would post some pics of my TT01: The spur destroyer.
Nothing too fancy except for the fact I had to replace a few screws I needed to replace them straight away. I don't care, it was second hand and its going to be turned into a parts car anyway.
I've upgraded it with a alloy shaft and ball bearings, I race in 27T Stock with this
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 11-06-2008, 07:45 AM   #1314
Your servo saver looks interesting, Is it the Square one? thanks!
stocker is offline   Reply With Quote
Old 11-06-2008, 07:55 AM   #1315
raffaelli's Avatar
Nice GT40! Who makes it?
24ITA
raffaelli is offline   Reply With Quote
Old 11-06-2008, 08:01 AM   #1316
xxSLiMxx's Avatar
I beleve HPI makes one.
xxSLiMxx is offline   Reply With Quote
Old 11-06-2008, 10:23 AM   #1317
yep, u r right, its from square just some bling-bling on the car
Old 11-06-2008, 10:50 AM   #1318
I have not break any of my 55, 58 or 61 spurs. Your breakage could be due to wrong A,B,C or D motor slot, worn out chasis motor mount slot or worn out motor mount cap.
Old 11-06-2008, 10:57 AM   #1319
any of you crazy enuff race againts the 416 in the stock 23 turn class?
Any setup you might wanna share?
Has beaten some 416 and cyclones on fun race getting crazy and planning to enter this car on a stock class open race soon
if i suceed, will post setup
Old 11-06-2008, 04:19 PM   #1320
Thanks!! IIRC, it's quite costly?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
