Like Tree1Likes
Old 09-30-2008, 04:57 PM   #1246
rcmarek's Avatar
You asked for "must have" items. Your list is more "nice to have", maybe with the exception of the adjustable upper arms. I don't have ball diff, one way or sway bar and I'm still able to race (and occasionally win) against more expensive cars (540 class). Make sure that the car is as much free rolling as possible.
Originally Posted by KandyRedCoi View Post
how about:
adj upper arms
ball diff
one way
sway bars
thanx!!!
Marek | SMA | M03 | TC5R | F104
rcmarek is offline   Reply With Quote
Old 09-30-2008, 04:59 PM   #1247
rcmarek's Avatar
Default gearing
one more thing ... you'll probably want to change the gearing
Old 09-30-2008, 05:02 PM   #1248
xxSLiMxx's Avatar
Oil shock, good tires, and a fast motor. Thats the "must have" to win races anyways....eveything else is how will you drive!
xxSLiMxx is offline   Reply With Quote
Old 10-01-2008, 12:49 AM   #1249
KandyRedCoi's Avatar
Send a message via AIM to KandyRedCoi
LOL, thanx guys, ill start with the basics and go from there
unfortunately noone around here runs silver can on the tt-01 or 1/10 scale sedans only on Mini chassis
so 27turn/17.5bl is the basic motor to run
will end up going against a ton of tc5, jrxs, and ta05 cars...ill need all the help i can get LOL
btw: heres my tt-01
https://www.facebook.com/ctdesigns09
KandyRedCoi is offline   Reply With Quote
Old 10-01-2008, 11:09 PM   #1250
edhchoe's Avatar
Trader Rating: 41 (100%+)
Why does my son's TT-01 go faster in reverse? His car has the Tamiya ESC. I did the setup following the instruction manual. My TT-01 goes faster forward. Hmm...
edhchoe is offline   Reply With Quote
Old 10-02-2008, 08:04 AM   #1251
xxSLiMxx's Avatar
I cant remeber if you can do this with the stock ESC, but turn off the reverse if you can and it will go faster.
Old 10-03-2008, 02:41 PM   #1252
edhchoe's Avatar
I think I figured it out.... I will have to go home and test it but I have an idea in my head now.
I must have put the diffs the wrong way. I will go switch both diffs around.
Old 10-03-2008, 06:41 PM   #1253
terryh1313's Avatar
just put a 19t vemon in my tt-01, WOW make it seem like a whole new car
handle the business, before the busines handles you
terryh1313 is offline   Reply With Quote
Old 10-03-2008, 06:52 PM   #1254
rccardr's Avatar
It's probably not the diffs- I don't think you can install them backwards due to the internal shape of the diff housings. However, you may have plugged in the motor backwards (yellow on motor and orange on ESC= positive, green on motor and blue on ESC= negative) or you may have to reverse the throttle on your radio.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 10-04-2008, 05:19 PM   #1255
edhchoe's Avatar
I turned the diffs around and it is faster forward now. And it is also quieter. When the teeth get worn it would worth a try to switch the front and back gears...so that they can be meshed on the other side of the teeth.
Old 10-11-2008, 10:05 PM   #1256
hey guys ive just put a reedy 12x2 brushed into my tt01 and it has extremely fast top speed but it takes it quite a while to get up there . atm im running gearing on 58 : 24 what should i change it to so that i have more acceleartion?
scottwhat12 is offline   Reply With Quote
Old 10-12-2008, 06:09 AM   #1257
xxSLiMxx's Avatar
Try useing a smaller pinoion like a 23 or 22 tooth.
Old 10-12-2008, 06:33 AM   #1258
terryh1313's Avatar
Hello all,has anyone raced your tt-01 in Trans-am class?
Old 10-12-2008, 07:46 AM   #1259
oh man i put the stock 61/19 gearing back in and this car is an absolute beast !!!!!!!! it flys along like its on crack so much fun
Old 10-12-2008, 09:59 AM   #1260
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
any1 know where a tt01e manual can be found online?
R
UltegraSTI is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
