Like Tree1Likes
Old 09-05-2008, 07:24 AM   #1201
RaceBucks's Avatar
Originally Posted by brrrrm View Post
Did you use the small steel plates that go into the chassis slots? The grub screws bottom out on these. I had to glue them in so I would not lose them on the track, but they were effective.
Without the steel plates the screws bottom out on the plastic which is no good indeed.
Yep, I glued them in as well. The whole thing was just way too soft. It's alright though, I'm just using the car now as a silver can racer.
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
RaceBucks is offline   Reply With Quote
Old 09-07-2008, 01:02 AM   #1202
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Build still in progress thanks to all of you who have been working on the gearing aspect for this car. Right now its geared with a 65 spur 39 pinion. Its not been on the track but I am looking forward to getting it out there.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP Cirtix Stock/Novak 25.5
Exotek F1R/Savox 1251/Tekin RS/21.5
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 09-10-2008, 07:52 AM   #1203
hey i have just bought a xenon 23t vs sport motor for my tt-01 thats bone stock at and the guy i bought it off said i should use 68 27 gearing to go fast. does this sound right to u guys and will it fit ?
scottwhat12 is offline   Reply With Quote
Old 09-11-2008, 05:51 AM   #1204
fat500's Avatar
Trader Rating: 27 (100%+)
Default blk or silver
Guys, how much of a difference will I notice between the silver can motor and the black sport tuned in my TT01 geared at 55/25. Big difference in top speed or not enough to bother. Thanks,
fat500 is offline   Reply With Quote
Old 09-11-2008, 06:58 AM   #1205
raffaelli's Avatar
The black can is faster. On our track it is about 2 laps faster. However, the black can heats up quickly and fail. We replace them just about every 2-3 race days.
24ITA
raffaelli is offline   Reply With Quote
Old 09-11-2008, 07:27 AM   #1206
i recently purchased a used novak gtb w/5.5 BL motor combo from some guy in here. i will be putting it in my tt-01E...i running 28/52 gearing right now. do i need to change my gearing to a taller one???
jun_1.8T is offline   Reply With Quote
Old 09-11-2008, 08:12 AM   #1207
RaceBucks's Avatar
As said, the Black Can's are much faster but they introduce a lot of heat. In a stock TT-01 plastic motor mounts can warp, fans and heat sinks are a must, and drive shafts flex under the extra torque/speed. By the way I was running the 52 spur.
I ran my TT-01 in TCS with a silver can and it was great, but when I tried going to a Black Can for their finals there was so much that had to be done to the car that I stopped.
Old 09-14-2008, 09:35 AM   #1208
Aluma's Avatar
Originally Posted by dfiantii View Post
RaceBucks,
I agree with you on the droop issue. I think the only way your going to get the effect of droop at all is to upgrade to the 3racing carbon fiber chasis. Which is what I did. I am waiting in the mail for my new gearing as well using 48p kawada gearing with the HPI adapter. Thanks to you and brrrrm for your gearing research. And to everyone else I did not mention. I have a Team Losi Type R and I was ready to give up on my Tamiya and make it into a drifter. Now I am going to let the Losi sit for a while and rebuild the TT-01 see what I do with it on the track.
Ummm, why dont you guys just use spacers INSIDE the shocks to limit droop like in the "old days"? I'm sure its a little more work, but if it gets you the win, why not?
Aluma is offline   Reply With Quote
Old 09-14-2008, 03:09 PM   #1209
edhchoe's Avatar
Trader Rating: 41 (100%+)
Default Ordered a TT01.
My 7 year old son started to understand RC car racing and he's gotten so good with the TT01 that I am having a hard time catching him with my F103GT on my tight course that is set up in the driveway. I have succumbed and ordered TT01 for myself. I was debating between a TT01E and TT01 and I went with the $40 cheaper TT01 with the BMW Z4M body. $123 shipped. I ordered an aluminum shaft, carbon upper plate, bearings, type b tires, and motor heatsink the same day.
http://www.youtube.com/watch?v=TF1ZxARp_e0
edhchoe is offline   Reply With Quote
Old 09-15-2008, 09:39 AM   #1210
Default RC NEWBIE
I purchased my first RC Kit last month (a TT-01 2006 DTM Mercedes
Finished Body Tamiya #58379) and really enjoyed the build. I got the
controls for the kit last week and got it running. My problems now are
traction (or lack of it), handling (the car just doesnt seem to turn right
when it is running at full throttle) and speed (I am using the silver can
that came with the kit). What would be recommended in terms of simple
hop-ups or settings (if any with this kit) to solve the issues above? I
dont plan on racing the car, I just enjoy running it at the local grocery
store parking lot.
Thanks in advance
Alfo is offline   Reply With Quote
Old 09-15-2008, 11:03 AM   #1211
Aluma's Avatar
a spring set would be a good thing to get for tuning the "turning". Swaybars help too. You could just try to mess with the shock position aswell...makes a pretty good difference. SPEED: switch to the smallest plastic spur with the biggest pinion, it'll take a while to get to top speed, but you'll get there.
Theres also a hotter motor, but that all depends on what you race. If you,re just bashing, well, you could have fun with a hot brushless setup, but you'll have to upgrade everything to handle it....driveshafts, cvd's, heatsinks, fans, stock up on extra parts that you'll break when you hit curbs...arms, hubs, etc...
Old 09-20-2008, 08:07 AM   #1212
Low_E's Avatar
Send a message via MSN to Low_E
guys, I'm sorry if I have missed it somewhere (I must have) but is there somewhere a link, .. or does someone have a link to some setup-sheets for the TT01?
I have looked through this thread but as said, might have missed it.
I am starting to compeed with my TT01E in a local Tamiya-competition. The TT01 has to be stock, only oil-shocks alowed, a max of 55-25 spur/pinion, all parts Tamiya offcourse.
Could anyone help me with a good general setup for Carpet and asphalt? for this car.
Actually, it's on a Asphalt circuit tomorrow so I could use that very quickly.
thx in advance
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 09-20-2008, 09:06 AM   #1213
dfiantii's Avatar
Find out what setup everyone is running and use that as your starting point. You already know the pinion and spur requirements. Now you need to figure out what weight oil for your shocks your going to use and what your camber and toe setting should be. You get get that from other drivers you drive their car there. At my track I run 40 weight oil in the front 30 in the rear with stronger springs in the front to cut down front weight transfer and I have 3 degrees negative toe in the rear
Old 09-21-2008, 02:35 AM   #1214
edhchoe's Avatar
Default new video!
+ YouTube Video
Old 09-22-2008, 08:55 PM   #1215
edhchoe's Avatar
Default Universal shafts
I bought universal shafts for TT-01 and the seller shipped me the ones for M03/M04 chassis. Are they the same?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
