Like Tree1Likes
Old 08-29-2008, 09:24 AM   #1186
reenmachine's Avatar
Trader Rating: 26 (100%+)
Originally Posted by jun_1.8T View Post
ok guys....i tested the car today on the track. im running the 25/55 for an FDR of 5.72. im running the black can motor with the car. wow....what a difference from running 19/61 w/ silver can. my concern is now...the motor got very hot. i went and used my temp gun and it read 155F-158F this is after about 5 mins of run time in the track. will this temp be ok for the motor??? will a heat sink help somehow???
thanks!
A heat sink is always a good thing -- lower temps are always better, but those temps aren't anything to be afraid of. I don't like to go much higher than that, but you're OK. Pop on a cheap heat sink and you'll be in the barrel.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 08-29-2008, 02:32 PM   #1187
#88driver's Avatar
thanks!
A heat sink will help some, but not a whole lot. I would guess with a heat sink the motor would be about 130 or something like that.
Colton Jaynes
*RC America*Hudy*Xray*Jaco*KO Propo*SMC*EA Motorsports*
rchobbiesstore.com
#88driver is offline   Reply With Quote
Old 08-29-2008, 02:36 PM   #1188
25 isn't a whole lot??
Pete Waydo
Old 08-29-2008, 05:47 PM   #1189
fat500's Avatar
Trader Rating: 29 (100%+)
I would like to trade my ta05r for a tt01 with hop ups. seee my post in the for sale area
fat500 is offline   Reply With Quote
Old 08-29-2008, 07:06 PM   #1190
#88driver's Avatar
sorry just an educated guess
Colton Jaynes
rchobbiesstore.com
Old 08-30-2008, 06:19 AM   #1191
fat500's Avatar
after having owned both a tt01 and a ta05r I perfer the ease of driving and the stability of the TT01. Very easy and kudos to Tamiya
Thanks for all the info you guys provide on this fourm
My son and I both Thank you for the time you guys put in to this hobby
Old 08-30-2008, 04:04 PM   #1192
hi, just bought a tb-02 and wanted to know if i could use standard wheels and tires from pro sedans on this car, im new to onroad ive raced carpet oval since 1990. any help would be appreiciated
MiniMike is offline   Reply With Quote
Old 08-30-2008, 04:22 PM   #1193
Yes. The 12mm hex is pretty standard industry-wide now.
Here's the TB-02 thread:
Tamiya TB-02
Pete Waydo
Old 08-30-2008, 10:37 PM   #1194
Hey RaceBucks, I bought the TT-01D suspension arms some time ago (http://www.rcmart.com/catalog/rc-tt0...th=595_744_708). I believe they came with droop adjustment. The kit included droop screws, stiffer lower arms (than the standard ones) with extra shock absorber mounting holes. The front/rear chassis extensions have special slots in them that fit small steel plates which contact the droop screws.
I have not really used droop control, because I run the C/F chassis and have adjusted the shock arms to give me ride a height of 4mm rear and 3mm front.
Originally Posted by RaceBucks View Post
I really wanted that droop kit to work, lack of droop is the only feature in the TT-01 that I wish it had, but when I got it I think it's implementation was weak.
brrrrm is offline   Reply With Quote
Old 08-30-2008, 10:43 PM   #1195
Go to post 805.
...i cant seem to figure out what mods has to be done with the spur(sorry...newbie here). im trying to achieve an FDR of between 4.83-4.36.....
Old 08-31-2008, 08:04 AM   #1196
RaceBucks's Avatar
Your right, my bad, it was the TT-01D arm's not the TT-01E arm's that have droop. I forgot, but it was the TT-01D's parts that I tried; too soft to be effective so I just put the standard arms back.
(I just edited post #1177 to fix my mistake)
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
RaceBucks is offline   Reply With Quote
Old 08-31-2008, 11:52 AM   #1197
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Brrrrm,
What did you have to do to give you that ride height option for the TT-01?
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 09-01-2008, 06:53 PM   #1198
... too soft to be effective so I just put the standard arms back.
Did you use the small steel plates that go into the chassis slots? The grub screws bottom out on these. I had to glue them in so I would not lose them on the track, but they were effective.
Without the steel plates the screws bottom out on the plastic which is no good indeed.
Old 09-01-2008, 06:59 PM   #1199
Originally Posted by dfiantii View Post
Brrrrm,
I screwed in the ball ends to get the required shock arm length and the required ride height. It is a bit of trial and error. You don't get any droop with this method, but with the very stiff setup that I have it is not much of an issue.
Alternatively, you could put a red rubber O-ring under the piston.
Old 09-05-2008, 12:19 AM   #1200
Anyone uses the stock 01 "racing slick" tyres? It doesn't come with any inserts, is it worthwhile to buy some inserts for it and perhaps do some bashing with it?
stocker is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
