Like Tree1Likes
Old 08-20-2008, 08:12 PM   #1171
I run 4.1 in my TT-01 carbon fibre chasis and run it on asphalt. That FDR does not fit the bath tub chasis. A listing of FDRs for TT-01 is on p. 28 post 835.
brrrrm is offline   Reply With Quote
Old 08-20-2008, 10:23 PM   #1172
Thanks Brrrrm, that is extremely helpful!!! I'm inspired to work on my TT-01 again!
stocker is offline   Reply With Quote
Old 08-21-2008, 03:39 PM   #1173
No problems, that is what we are here for. Have fun!
Old 08-25-2008, 05:12 AM   #1174
barts71m's Avatar
Trader Rating: 34 (100%+)
hey guys, just bought a TT01E for an upcoming tamiya race, putting it together and seem to be missing the P Parts from my kit...51005...anyone else had this issue or did I miss something in the destructions??? yes ive looked and looked for the parts...cant put it together any further without em.
barts71m is offline   Reply With Quote
Old 08-25-2008, 05:45 PM   #1175
With the lowest FDR potentially 5.11 with the 55T, it would probably be sub-optimal to run a 17.5. But a 13.5 would be OK with the 28/55T?
Old 08-27-2008, 12:40 PM   #1176
hi there everybody.
new to this thread as i've just bought a TT-01E last week and finished putting it together yesterday. the only upgrade i did to it was the ball bearings. evrything else is pretty much stock. i've been reading a lot in this thread and came across "droop settings". my question is what are the parts i need in order to have droop settings in my car??? by the way...i've also installed the adjustable upper arms for both front and rear. if you guys can provide part numbers too...it would be greatly appreciated.
thanks!
jun_1.8T is offline   Reply With Quote
Old 08-27-2008, 04:03 PM   #1177
RaceBucks's Avatar
Originally Posted by jun_1.8T View Post
...my question is what are the parts i need in order to have droop settings in my car???
(edit: my bad, it was the D kit that had the arms that I'm discussing below)
I'm pretty sure the TT-01D comes with the droop arms and screws; I have the original TT-01 and ordered the TT-01D spare arms/parts and tried to install them on my regular car. In short, I was pretty disappointed. The regular TT-01's outdrive interfere with the droop screws (you won't have that problem) but also the plastic is so soft on the bottom plate that turning the droop screws just bends the bottom plate and doesn't really control droop. The TT-01D's bottom plate has an extra support ridge and a small metal plate for the droop screw to hit, but they are ineffective in my opinion.
I really wanted that droop kit to work, lack of droop is the only feature in the TT-01 that I wish it had, but when I got it I think it's implementation was weak.
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
RaceBucks is offline   Reply With Quote
Old 08-27-2008, 04:32 PM   #1178
peetiewonder's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to peetiewonder
either my tt01e didnt come with droop screws, or im missing something, dont matter cuz im using it as a rally car anyways.
Got a tax policy that'll break ya neck BYAAAAAAH!
Buy my stuff.
peetiewonder is offline   Reply With Quote
Old 08-27-2008, 04:33 PM   #1179
kavadni's Avatar
hi there everybody.
thanks!
Have a look at http://www.tamiya.com/english/rc/rcmanual/tt01d.pdf
It lists the parts required and has diagrams
kavadni is offline   Reply With Quote
Old 08-27-2008, 05:34 PM   #1180
the 01R has the stuck on metal plate and droop adjustment, as it is using the metal drive shafts. The 01D has the adjustable arms but do not use the droop screws, 01D is using the plastic thick drive shafts. The o1E is the same as the regular 01, no adjustable arms, no droop adjustments, plastic thick drive shafts.
Old 08-27-2008, 10:59 PM   #1181
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
RaceBucks,
I agree with you on the droop issue. I think the only way your going to get the effect of droop at all is to upgrade to the 3racing carbon fiber chasis. Which is what I did. I am waiting in the mail for my new gearing as well using 48p kawada gearing with the HPI adapter. Thanks to you and brrrrm for your gearing research. And to everyone else I did not mention. I have a Team Losi Type R and I was ready to give up on my Tamiya and make it into a drifter. Now I am going to let the Losi sit for a while and rebuild the TT-01 see what I do with it on the track.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 08-28-2008, 07:15 AM   #1182
thanks a lot guys....i guess ill just have to make and do with what i have instead of converting to c/f chassis.
one more thing to ask....what will be the easiest way fit the 52T spur. looking at the table that racebucks had...i cant seem to figure out what mods has to be done with the spur(sorry...newbie here). im trying to achieve an FDR of between 4.83-4.36.....will this cut short my run time???
thanks again guys!
Old 08-28-2008, 09:05 AM   #1183
thanks again guys!
for a 4.83 gear ratio, run the 52t spur, mounted normally on the propellor shaft. i think the 52t will only mesh with a 28t pinion. mount the motor on the top right and bottom left holes on the motor mount (roughly 2 oclock and 8 oclock holes if that makes more sense). no other mods should be needed. thats a pretty crazy gear. let us know how it goes.
im not super good with gear ratios, but i think that ratio will give you a crazy top speed, and maybe put a big load on the motor while accelerating. someone please correct me if im wrong.
rexvirtue is offline   Reply With Quote
Old 08-28-2008, 10:31 AM   #1184
reenmachine's Avatar
Trader Rating: 26 (100%+)
Yes and no -- it all depends on what motor he's running and what he's doing with it. If it's a 13.5BL, for example, an FDR of 4.5-4.6 is totally normal. If he's running on a large, sweeping track he could probably run a silver can with that FDR. If it's a tight, technical track he'd probably never reach top speed and may even let the smoke out of a silver can in the process.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 08-29-2008, 01:39 AM   #1185
ok guys....i tested the car today on the track. im running the 25/55 for an FDR of 5.72. im running the black can motor with the car. wow....what a difference from running 19/61 w/ silver can. my concern is now...the motor got very hot. i went and used my temp gun and it read 155F-158F this is after about 5 mins of run time in the track. will this temp be ok for the motor??? will a heat sink help somehow???
thanks!
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
