Like Tree1Likes
Old 08-15-2008, 10:06 PM   #1156
im ripping the gpm alloy gear box/susp mount on the front. makes the shocks mad stiffer. adds some weight, but the durability is worth it for my rally car.
rexvirtue is offline   Reply With Quote
Old 08-15-2008, 10:08 PM   #1157
i did try the upper deck from the tt-01e, but still ran into problems, even with the "e" motor mount. i think there was an issue with the mounting holes in the upper suspension arm holder things. know what i mean?
Old 08-16-2008, 11:08 PM   #1158
I see tamiya are busting out with some carbon damper stays for the TT01E, 54059 & 54060. If i want to fit these to a normal TT01, all i would need to do is cut off the suspension tower fixed to the bulkhead, right? Or would i need to use the front part bulkhead from TT01E A-parts?
I also found out 3Racing are coming out with a version 2 of the very popular CF conversion, that can fit both the TT01 & TT01E, the TT01 is getting alot more interesting now, better adjustability...
Drift Demon is offline   Reply With Quote
Old 08-17-2008, 05:43 AM   #1159
Yes, I know what you mean. The holes are too high right? You either have to file down the edges of the holes flush to the hole itself or get the 01E "upper suspension arm holder things" Once you have done that, it will be a nice fit. I know because I have done that.
If you want more info, you can download the 01E manual and reference it.
stocker is offline   Reply With Quote
Old 08-17-2008, 01:00 PM   #1160
do any of you doods use brushless? would it rip through plastic gears too fast or what? i say on you tube, some guy was using 1/18 brushless. mamba brushless systems are affordable enough, but i dont want to have to stock up on spur gears too much more than normal.
Old 08-17-2008, 01:03 PM   #1161
thanks stocker. a little filing, and everything went smoothly.
Old 08-17-2008, 03:52 PM   #1162
raffaelli's Avatar
novak 13.5 with tuned rotor. no problems
24ITA
raffaelli is offline   Reply With Quote
Old 08-17-2008, 04:23 PM   #1163
Mooshu Beef's Avatar
Don't get the 1/18 scale Mamba... the motor will be way too small! 1/10 is what you're looking for: the Mamba Max system or Sidewinder.
As long as you mesh it correctly the delrin holds up very well. Just don't crash! (I did and shattered both the left side knuckles and a dogbone right in half!)
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
Old 08-17-2008, 04:53 PM   #1164
RaceBucks's Avatar
Originally Posted by RaceBucks View Post
Raffaelli, we've bantered back and forth on the TCS and Silver Can thread before, sounds like we are doing similar stuff on opposite ends of the country. Are your running TCS? Which classes? Which events?
Originally Posted by raffaelli View Post
Over the summer I race in a TCS type class in GT-3 and GT-2. The GT-2 class is with the black motor instead of a 27t. We also run endurance racing with the F103. I plan on attending the TCS this year at RC Madness and Mt Laurel. I plan on running GT-3 with the base TT01, F103 and perhaps Mini.
Did you wind up running TCS? How did you do? How did your TT-01 do?
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
RaceBucks is offline   Reply With Quote
Old 08-17-2008, 05:46 PM   #1165
Blueshark's Avatar
I run the MM5700 combo, no problems at all. i love it!
Blueshark is offline   Reply With Quote
Old 08-17-2008, 06:12 PM   #1166
raffaelli's Avatar
I planned on being at the TCS in Enfield. However, the week prior while racing my 1:1 car, I blew the engine. So replacing that engine is my highest priority to be prepared for the next event. I spend the TCS weekend pulling out the detonated engine. So, no, regretfully I did not go. Thanks for remembering though! A few chassis which I have help setup did every well and would have done much better had the carpet not been involved. Although after watching the videos of the mains, it was a free for all anyway!
I am still racing the bone stock TT01. It is the dominate car at the track. In both silver can and black can racing, as well as the endurance class.
24ITA
Old 08-17-2008, 07:00 PM   #1167
just got a vodaphone mercedes tt01, any must have hop-ups besides bearings you people recomend?
MiniMike is offline   Reply With Quote
Old 08-17-2008, 08:39 PM   #1168
raffaelli's Avatar
For me the car does not need any hop ups.
But, the best upgrade (aside from wheel time) is shocks.
24ITA
Old 08-20-2008, 09:30 AM   #1169
What kind of gears do you guys use for sports tuned or silver can? The max 25/55 with FDR 5.77? This ratio looks about right for a 10.5 brushless too, isn't it? I am currently using Sports tune with 24/58, and it's not exactly the fastest around, but the motor gets quite hot after 15 mins play, around 180+!
Old 08-20-2008, 11:24 AM   #1170
reenmachine's Avatar
Trader Rating: 26 (100%+)
I don't have a TT01, but I race a TB02 in a silver can class and we like to run a FDR of about 6.5. It makes for great racing on our medium-sized asphalt track.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
