Like Tree1Likes
Old 07-05-2008, 09:56 AM   #1126
kavadni's Avatar
Originally Posted by stocker View Post
How about the 49240, since I only need the soft?
Do the 53163 fit the TRF shocks as well?
I don't have 49240, I have been told they are the reds from 53440.
53163 are the same length as 53440.
Kevin
kavadni is offline   Reply With Quote
Old 07-06-2008, 08:12 PM   #1127
Mooshu Beef's Avatar
Well... after much contemplation I have decided I should go with a TA-05, and I believe I have a decent deal at hand. The thing that factored in was that, I can't many many purchases, so I really have to do the best I can with each. And I feel like I would eventually reach a point where I'd want a TA-05, and would do the best with one, so I might as well get it now...
If anyone is looking for a rolling chassis, check this out!
TT-01R - TRF Shocks - Universals - TCS Legal
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
Old 07-06-2008, 09:30 PM   #1128
I'm considering the aluminium steering linkages and connectors (53864 and 53670) as my stock steering seem to have a lot of play, probably because they are getting old and worn. I already have the turnbuckle tie rods and am thinking of replacing the ends with the greyish low friction ones from the high-spec kits. Is this a wise thing to do?
stocker is offline   Reply With Quote
Old 07-06-2008, 09:41 PM   #1129
The steering play bothered me the most on this chassis. The BB steering would definitely help there.
The low friction ball ends would be a great addition, I think. I mean, you have nothing to lose and more to gain
Old 07-07-2008, 01:09 AM   #1130
Martinst's Avatar
The steering on the TT01 is pretty poor to be fair. The steering set and turnbuckles help greatly, but the whole setup is let down by the front hub pivots. I've got the all alloy upgrade setup on one car which is good for strength but even with the upgrade metal pivot balls top and bottom of the hubs its very tricky to get the steering smooth. Fully tightened the steering won't move and slackened off you induce play. I've eventually got the screws slackened off and threadlocked, but its a poor design. Has anyone come up with a resolve for this ? My other TT01 has the plastic hubs and at least slackened off the screws don't move.
My TA05 MS in comparison is so much smoother and theres no messing with loosening off screws to get optimum movement.
Martinst is offline   Reply With Quote
Old 07-07-2008, 01:50 AM   #1131
I wonder if another option is the TT01E design? The tamiyausa site says it's a TA-05 inspired design, supported top and bottom. But you gotta get the plastic top plate as well.
link to TT01E
http://www.tamiyausa.com/product/ite...oduct-id=58402
Old 07-07-2008, 02:15 AM   #1132
kavadni's Avatar
Martin,
I have 3Racing aluminium uprights and Square-rc Flourine coated delrin pivot balls. It's better, but has updown freeplay in the arms. The arms wear.
My next action will be to try the 3Racing upper arms, castor and made of delrin. I'll let you know.
What pivot balls are you using?
Kevin
Old 07-07-2008, 09:30 AM   #1133
raffaelli's Avatar
link to TT01E
The only real differences are that the shock towers are separate for the diff case, it comes with a plastic upper plate. In my opinion, neither are needed.
24ITA
raffaelli is offline   Reply With Quote
Old 07-07-2008, 10:09 AM   #1134
It might help with some of the up and down slop, but not by much. Does anyone actually have this chassis?
Apparently they also changed some of the material too...
Old 07-07-2008, 11:06 AM   #1135
kavadni's Avatar
I have always felt that the chassis flex of standard TT-01 is a failing, as are the flexy shock towers.
I think the E is a great improvement, plastic stiffener will help with no added expense, and the separate shock towers open the possibility of carbon upgrades.
I believe that some of the new mouldings (diff covers) are fibre reinforced.
Kevin
Old 07-07-2008, 01:47 PM   #1136
raffaelli's Avatar
I racer at my track has one with the Gt Cup body. Nice looking body. No change in performance over the regualr TT01
24ITA
Old 07-07-2008, 06:09 PM   #1137
Originally Posted by kavadni View Post
Gear it lower, you want wheel spin
And it will run cooler.
Kevin
I switched from a 25/55 to a 25/58 ans just that little change gave me more wheel spin and longer run times and it's cooler! i got to fool around with it tonight for the first time and ran a few packs through it. I like drifting!
jamesban is offline   Reply With Quote
Old 07-07-2008, 07:42 PM   #1138
hi. i have a tt-01 love it. i got into the trans-am vintage racing. that is a lot of fun. does any one know where i can find a 25t pinion? trying to get the gearing to 5.4-5.7. running right mow 24t pinion 55t spure. close. the 25t pinion would put me right there. i searched & searched.this is running off of a 4cell 4600. will post up a pic soon. thanks lewis
lewis2000 is offline   Reply With Quote
Old 07-07-2008, 08:06 PM   #1139
kavadni's Avatar
There has been lots of discussion of what brands you can use, search this forum for 'Robinson' or 'kawada' or '25T' or 'metric' or '0.6'. Read around those posts. There has been lots of debate as to what works and what does not.
I've never needed one, as I race stock 27 on small tracks, and gear in the 7 to 10 range depending on the motor & track.
Kevin
PS Actually, it's Tamiya 50477
Old 07-07-2008, 08:30 PM   #1140
Tamiya has their own pitch... It's a little taller than 48, actually.
You have to get the tamiya 24 and 25t pinion pack.
http://www3.towerhobbies.com/cgi-bin...?&I=LXGF72&P=7
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
