Old 05-29-2008, 05:52 PM   #1051
Originally Posted by Mooshu Beef View Post
Hey Mac,
The gearing you have is one step away from the lowest drive combination of TT-01 spur and pinion gears. If you use the 55T, that will be the fastest gearing with the gears intended for the TT-01.
It's hard to gauge whether you are over-loading your motor in terms of temperature if you don't have a temp gun. However, I think something around a 22-25T with your spur should be fine.
I think some motors tell you the recommended FDR for the car...does this have one?
Thanks for the info. Not sure about the spec sheet yet, I didn't get the motor yet. Should have it any day now. I was not even in the market for one, but I bought it used that about 20 minutes on it for $11, so I figure I try it out.
maciek82 is offline   Reply With Quote
Old 05-29-2008, 05:55 PM   #1052
#88driver's Avatar
Originally Posted by vinsedprince View Post
so can you put 61t and 22t together???????
yes you can put a 61t spur gear with a 22 tooth pinion gear
Colton Jaynes
*RC America*Hudy*Xray*Jaco*KO Propo*SMC*EA Motorsports*
rchobbiesstore.com
#88driver is offline   Reply With Quote
Old 05-30-2008, 05:05 AM   #1053
Martinst's Avatar
What sort of money are these cars worth second hand ?
I've got a shelf queen thats been only run a few times with every upgrade possible. The only origional parts are the cogs on the end of the centre layshaft and the rear body posts.
Its had a fortune spent on it, but I'm thinking its probably too good just to sit on the shelf and get dusty. I race a TRF TA05ms so don't need another racer.
Its got:
Full 3racing Carbon Chassis
Droop adjustable front and rear wishbones ( TT01E )
Adjustable upper front and rear wishbones
Front and rear alloy hubs ( rear 2deg )
Fully ball raced
Titanium centre drive cups
Alloy centre shaft
Tamiya steering set + adjustable tie rods
Titanium universal drive shafts
Front tamiya one way diff
Tamiya ball diff rear
Delrin spur gear
Front and rear tamiya stabalisers
Alloy hex drive caps
Alloy servo mounts
Tamiya TRF Blue Shocks
I'm sure theres many other parts, I just can't remember them. It was kind of an addiction to keep modding and now I've got every part replaced its too nice to get dirty and just sits on the shelf ?!!
Any ideas of value ? I would add up all the reciepts but I'd probably cry at the total
Martinst is offline   Reply With Quote
Old 06-01-2008, 07:47 AM   #1054
Mooshu Beef's Avatar
Depending on the condition it should be worth anywhere from $100-$190
That's a lot of parts in there... I'd like to get my hands on that
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
Old 06-01-2008, 09:08 AM   #1055
adrictan's Avatar
Hey MARTINST, post some pics and tell us where you r from...
adrictan is offline   Reply With Quote
Old 06-01-2008, 11:39 AM   #1056
Martinst's Avatar
I'm from the sunny Isle of Wight, England. Still hungover from a rather heavy stag doo last night
Heres my TT01 - Only run once since the chassis was added.
I have other TT01 cars that I use for bashing and car park entertainment so this one gets to sit on the shelf.
For proper racing I prefer to use my TA05ms pictured below:
Old 06-01-2008, 11:42 AM   #1057
adrictan's Avatar
Thumbs up
Very nice. Neat.
Old 06-01-2008, 06:31 PM   #1058
ford_racing's Avatar
Send a message via MSN to ford_racing
Does anyone know the release date of the
TT0E kit Golf GTI part 58410?
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 06-04-2008, 01:48 PM   #1059
32819toon's Avatar
Default aluminium outdrives
I'm looking for some aluminium outdrives for my TT01. Is this set any good, or does anyone know of something better ?
http://www.rcmart.com/catalog/produc...th=595_744_708
Thanks for your help,
32819toon
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 06-04-2008, 05:03 PM   #1060
If your running a brushless, no, i wouldnt bother because the alloy would just wear down way to quick. i would suggest steel outdrives, much stonger.
I run a brushless, 7.5, & ive gone through 2 sets of alloy prop shaft joints, 2 alloy prop shafts, 1 pair of tobee craft outdrives & i even managed to snap 1 pair of tobee craft universal joints! I now run tamiya universal joints, tamiya steel outdrives, & im about to purchase GPM titanium prop joints & a carbon prop shaft.
Drift Demon is offline   Reply With Quote
Old 06-04-2008, 06:22 PM   #1061
kavadni's Avatar
32819toon
If you run those, you will find that the steel pins in the dogbones will wear them away them very quickly.
Check out the way that the TRF 416 etc have a plastic protector around the steel pin to protect the aluminium.
I would suggest go the universal path, they use steel cups, and you can get aluminium dogbones for the rear.
Kevin
kavadni is offline   Reply With Quote
Old 06-05-2008, 09:33 AM   #1062
32819toon's Avatar
Kevin
I'm going to run them with Hot Racing Universals, will they be OK, or will they wear out. I'm not using a brushless, just either a 23T or a 19T double.
32819toon
Old 06-05-2008, 10:25 AM   #1063
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
I installed the 58 spur and 24 pinion in my TT-01 tub chassis car and it was so much faster in the silver can spec class that we run here in Portland.
The only bummer was that I managed to bend the aluminum steering knuckle that I have from 3Racing. I dont know how this happened in such a slow class. =(
Chirag
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 06-05-2008, 10:39 AM   #1064
adrictan's Avatar
24/58 will go faster than 25/55 in a 23T?
Old 06-05-2008, 10:50 AM   #1065
Will the carbon fiber top deck improve in car handling while racing?
Trug Lug is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
Tags
drift
