Like Tree1Likes
Old 05-21-2008, 04:57 PM   #1036
The HPI gears may have a different pitch than the Tamiya 52T that is the untested bit. I am not sure if RaceBucks tried them out. In any case, you will not damage your car, you may strip your spur gear. If you go to post #835 and earlier you will see that a lot of testing was done. RaceBucks stayed with the bath tub chassis and Tamiya gears, I went with the carbon fibre chassis and standard gears which are more readily available. At the moment I am running 38x60 (FDR 4.11) with a silver can and easily keep up with more expensive racing cars.
It all depends what you are doing. Gearing is only one aspect of tuning and there are many others. Having a high top speed does not necessarily mean you win a race. You will have to try out a number of things (one at a time) to find your best set up for what you want to do.
brrrrm is offline   Reply With Quote
Old 05-21-2008, 05:11 PM   #1037
adrictan's Avatar
Hmm...so 4.11 you get more punch in torque but lose some time in top speed if you're at a long stretch. Correct?
adrictan is offline   Reply With Quote
Old 05-21-2008, 05:17 PM   #1038
adrictan's Avatar
1 more thing. The chart does not indicate how to set the motor mount to the motor as compared to 25T/55T. Without the correct hole (A,B,C,D), the Pinion/Spur might not be meshed well together, right?
Old 05-21-2008, 05:35 PM   #1039
The lower the FDR, the higher top speed and the less accelleration. Torque is something the motor puts out and accelleration is what you get. Basically the trade off is speed against accelleration. It is also important to know how your motor performs. A typical silver can (540 motor) has low rpm and high torque. Other motors, especially those with less turns have much higher rpm, but lower torque. You have to match the gears with the type of motor to get what you want. No one said it was easy!
The chart shows in brackets after the FDR what position to mount the motor (ABCD)
Old 05-21-2008, 05:45 PM   #1040
adrictan's Avatar
Dang...I kept thinking a lower FDR means a higher acceleration. I'm operating a 23T motor so I must actually go higher on my FDR to get more acceleration. Circuits in Singapore are not are big and wide as I see in the U.S.
Thus more acceleration is better for a tight circuit. More FDR?
Old 05-21-2008, 06:02 PM   #1041
adrictan's Avatar
Also, am using a 23T motor. So can my pinion be lower than 23T?
rcmart.com sells Tamiya Pinion lowest at 12T. But I don't think anyone has tried that low before?
Old 05-21-2008, 08:35 PM   #1042
The T in motors is for "Turns". The T in pinions and spurs is for "Teeth". The standard gears for the TT-01 is 19x61. With a 23T (Turns) motor that should give you plenty accelleration whilst still keeping reasonable top speed (more than the silver can anyway). The only way to find out is to try it and to time your laps.
12T pinions are usually used in combination with high rpm motors such as brushless.
Old 05-21-2008, 09:26 PM   #1043
adrictan's Avatar
ok. Will try the lower Pinion/Higher spur combos..
Old 05-28-2008, 05:34 PM   #1044
Hello everyone, newb here. Just bought my first RC about a week ago. TT-01r. I like it so far. My question is (I searched and can't find anything) what is the best gearing for a TRINITY KOMODO DRAGON, 19T PRO motor? I'm looking for more of a top speed setup. I don't really race, just play around on parking lots. I figured that lower my FDR is then the better, but I see that I need to put the RPM of the motor and temperature into play also. Currently I'm at 25T pinion and 58t Spur on the Z- Tuned motor. Can I keep the same setting or does anyone recommend something better.
maciek82 is offline   Reply With Quote
Old 05-29-2008, 11:42 AM   #1045
Mooshu Beef's Avatar
Hey Mac,
The gearing you have is one step away from the lowest drive combination of TT-01 spur and pinion gears. If you use the 55T, that will be the fastest gearing with the gears intended for the TT-01.
It's hard to gauge whether you are over-loading your motor in terms of temperature if you don't have a temp gun. However, I think something around a 22-25T with your spur should be fine.
I think some motors tell you the recommended FDR for the car...does this have one?
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
Old 05-29-2008, 11:43 AM   #1046
#88driver's Avatar
I have a question...
Has anyone tried running a 17.5 brushless in their TT-01 on an on road course? Where i run TT-01 is used as a spec class and you can only run the silver or black can motor. If you do run 17.5, how hard is it to control?
Colton Jaynes
*RC America*Hudy*Xray*Jaco*KO Propo*SMC*EA Motorsports*
rchobbiesstore.com
#88driver is offline   Reply With Quote
Old 05-29-2008, 12:00 PM   #1047
raffaelli's Avatar
I ran a 13.5 lipo foam on carpet with the base kit. Lots of fun, easy to drive but on the verge of out of control. Exactly where it should be.
24ITA
raffaelli is offline   Reply With Quote
Old 05-29-2008, 12:07 PM   #1048
#88driver's Avatar
is 13.5 slower or faster than 17.5
Colton Jaynes
rchobbiesstore.com
Old 05-29-2008, 03:06 PM   #1049
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
13.5 faster
rctouringracer is offline   Reply With Quote
Old 05-29-2008, 03:26 PM   #1050
vinsedprince's Avatar
Originally Posted by 88crewchief View Post
Comes stock w/ 61t spur and 19t pinion. 22t is standard hop up from tamiya.
so can you put 61t and 22t together???????
vinsedprince is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
