Like Tree1Likes
Old 05-20-2008, 02:34 PM   #1021
adrictan's Avatar
Is 25T/55T gear ratio the best I can do for a 23T Hot Bodies S46 motor and Futaba 330CR ESC?
adrictan is offline   Reply With Quote
Old 05-20-2008, 04:47 PM   #1022
a few pages back, brrrrm made a 52t spur from a F201 (i think) fit the tt01. look back a few pages & all the info should be there...
Drift Demon is offline   Reply With Quote
Old 05-20-2008, 05:01 PM   #1023
adrictan's Avatar
Running on 25T/55T FDR, I'll get 5.72. So 19T/61T I get higher FDR, I get higher torque but lower top speed?
Old 05-20-2008, 08:36 PM   #1024
Mooshu Beef's Avatar
You are correct sir.
Again, try the car out on the track. The can might just have enough torque to push that final drive safely. But in general, over gearing might have a better top speed, but you might never see that speed due to lack of torque/grip/no area straight enough.
adrictan...are you racing in a club? If so, is it possible for you to make runs with a certain gearing, keep track of lap times and more importantly WRITE DOWN HOW THE CAR DRIVES. The qualitative observations you make, I believe, can be more important than the numbers.
I mean, if the car drives well and feels like it has a good amount of torque coming out of corners, and can still kick up the speed in the straights, that's what you're aiming for. However if you don't remember how a certain gearing compares to the other, you've gotten nowhere fast.
I would stick to the TT-01 gears for now. Once you figure out what you're looking for, if it needs to be taller or shorter gearing, you can look into modifying the chassis and drivetrain to get there.
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
Old 05-20-2008, 09:49 PM   #1025
adrictan's Avatar
Thanks. I get the pic. Will order the pinions & Spurs to try out the best combos.
Old 05-20-2008, 10:22 PM   #1026
Sweet, man.
let us know how it goes.
Old 05-20-2008, 10:26 PM   #1027
adrictan's Avatar
No prob. U just have to wait cause am a newbie and not even know the skills yet. Have to master it before recording lap times. Hee.....
Don't know how to insert image. Keep error.
Find my pics here. Don't flame me pls.
http://www.file-upload.net/en/view-8..._0259.JPG.html
http://www.file-upload.net/en/view-8..._0260.JPG.html
Old 05-21-2008, 04:36 AM   #1028
Those pics look good! You have a really good setup to start with.
However, it looks like you have toe in in the rear, and toe out in the front. For racing this might hurt your times. I believe toe in in the rear and toe out in the front are good for stabilizing the car at higher speeds, at the expense of extra tire wear and performance.
Toe in in the rear means that the tires are pointing towards the chassis, or "in" and toe out in the front means your tires are pointing "out" away from the chassis. All of these directions are easy to see from the top view of your chassis.
Do you have regular toe rear blocks? Maybe I am just seeing things. Also I see adjustable turnbuckles up front. I would try 0 degrees toe (pointing straight forward)
I am not a racer, but this is something I've sorta picked up from lots of reading. I believe brrrrm described earlier in the thread how he does not use toe due to the slower performance that comes with it. It is slight, but still makes a difference.
Old 05-21-2008, 08:12 AM   #1029
adrictan's Avatar
I was told to be better during the drift, adjusting the camber for the front is more impt thus my front tires are this way. Rear tires are needed for stability so 0 camber.
Old 05-21-2008, 02:11 PM   #1030
im running with my wheels cambered in so that they fit under the bodyshell because im running offset rims. if your rockin' plastic pipe tyres (ABS/PE/etc.) then camber really dont matter. But the other tyres may require other techniques. i have never used anything else but PE tyres, wouldnt mind giving abs a go...
Old 05-21-2008, 02:14 PM   #1031
Originally Posted by vinsedprince View Post
if you check the chart.. and the motor mount... 25 / 55 is the max...
yeah, put in a 22T pinion and it should not be able to touch the spur...
28/55 is the max, not 22 / 55
spid3r1987 is offline   Reply With Quote
Old 05-21-2008, 05:34 PM   #1032
adrictan's Avatar
28/55 for higher top speed but lesser torque than the rest right?
Old 05-21-2008, 05:40 PM   #1033
You can go as far as 31x52 (FDR 4.36). See attached picture (courtesy of RaceBucks). With a CF chassis you can go as far as 40x60 (FDR 3.9). See post #835 and earlier for more info.
brrrrm is offline   Reply With Quote
Old 05-21-2008, 05:41 PM   #1034
You are right
Old 05-21-2008, 05:47 PM   #1035
adrictan's Avatar
Tamiya only has up to 25T Pinion and according to the chart, the HPIs are untested. Afraid it'll damage my car....
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
Tags
drift
