Like Tree1Likes
Old 12-08-2007, 12:41 AM   #661
depressedbunny's Avatar
TT-01 Front One-Way Unit
what does it do?
is it like a LSD?
TT-01 (with mods),
TB-02,
old skool
Tamiya hornet
FF
depressedbunny is offline   Reply With Quote
Old 12-08-2007, 07:34 AM   #662
joe of loath's Avatar
one way diffs are like normal gear/ball diffs, except they have a one way bearing on the shaft, so that you have 4wd when accelerating and 2wd when breaking and entering corners. i forgot what difference it made to the handling though
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 12-08-2007, 11:26 AM   #663
One way front is the way to go if you are road racing the car on a track with tighter corners. one way acts like having an e-brake on a rwd car. When on throttle all four wheels spins. When you come into a corner tap the brakes and the rear wheels will lock but the front will still spin making your car swing into turns faster.
Tamiya TT evo 1? all out drift, mamba max esc/ Tekin Redline 358
Tamiya TL-01 rally,mamba sidewinder 4600
Tamiya TB evo 5 drift attack, mamba max 6900
Dorkymk3 is offline   Reply With Quote
Old 12-11-2007, 05:59 AM   #664
thanks, i just ordered one and a rear ball diff too
TT-01 (with mods),
TB-02,
old skool
Tamiya hornet
FF
Old 12-11-2007, 07:27 PM   #665
Swift and Sleek's Avatar
Default front one way
what does it do?
is it like a LSD?
I used front one way unit and all I can say is that it will add up to the acceleration and its noticeable on straights!
"TEAM BAD BOYS"
FOR THE LOVE OF THE GAME
Swift and Sleek is offline   Reply With Quote
Old 12-19-2007, 02:39 PM   #666
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Thumbs up
I took you guys who suggested I upgrade my esc's advice and got an LRP Quantum Pro Reverse Esc. I went one step further and got a front one-way and ball diff for the rear as well and swapped out the stock dogbones and axles for metal light weight ones from the TG10. The differences are amazing from what I can hear when i pull the trigger on the transmitter. I also decided to direct solder my motor to the esc.
dfiantii is offline   Reply With Quote
Old 12-19-2007, 02:44 PM   #667
hmm, looks like many parts are interchangeable with parts on my E10...
Old 12-19-2007, 07:01 PM   #668
I SUGGEST THIS SET UP LESS FRICTION IN STEERING BECAUSE THE CONNECTIONS ARE ALIGNED TO THE SWAY OF THE SERVO AND USE A BALL CONNECTOR STOCK ALUMINUM OR TITANIUM FOR MORE EASE IN MOTION.
"TEAM BAD BOYS"
Old 12-19-2007, 11:19 PM   #669
dfiantii's Avatar
It works out pretty much the same but thankyou for the advice I will give it some thought.
Old 12-22-2007, 05:28 PM   #670
Trader Rating: 37 (100%+)
Send a message via MSN to slyts6
does anyone here run a TT01 with the 3racing graphite conversion kit?
once i sell my 415 im thinking about getting a TT01 with the CF kit but im unsure if the motor mount allows the motor to slide across to achieve lower ratios. does anyone know if it can?
anthony
Axial Wraith -- Scratch Built -- Vanquish -- Motoworx -- Rc4wd
Axial XR10 -- Hitec 7955tg -- Vanquish -- Airtronics -- Tekin FXR's
If it's got wheels or tits, you'll have trouble with it.
slyts6 is offline   Reply With Quote
Old 12-24-2007, 11:18 AM   #671
I run 28/55 without any problems and I think it would even fit 28/52.
brrrrm is offline   Reply With Quote
Old 12-24-2007, 06:08 PM   #672
is that on the standard style motor mount? a 28/52 works out to be a 4.83FDR....i would like to run a lower one if possible...i was running a 3.9fdr at my local track.
Old 12-25-2007, 02:31 PM   #673
The CF chassis does not use the Tamiya standard motor mount. Unlike the Tamiya mount, you don't rotate the motor to get the correct spur-pinion spacing. It has two slots, one at the top and one at the bottom where you fit the bolts that hold the motor. You slide the motor towards the spur gear until the teeth mesh then tighten the bolts. Have a look at http://www.rc-area.co.uk/blog/?p=1435. With 28/55 the bolts are about in the centre of the slots and there is at least another 1- 2 mm to go either way.
What spur/pinion combo are you planning on running, because I am not sure you can get beyond 28/52 with the TT-01. Maybe someone else has more experience with that.
Old 01-05-2008, 06:00 PM   #674
i am currently making a custom alloy spur gear holder for on of my TT01's. i plan on using any pitch that will give me a low 4fdr...as long as it fits in the plastic chassis and motor cover. so far it is going to plan an i will post pics of it to show you guys.
i bought the 3racing chassis the other day and fitted it to my other TT01. the motor mount does allow the motor to slide, but i have to work out a way of making another spur gear holder so i can use other pitches to achieve my desired FDR. i weighed the car this morning: RTR with a 101bk, servo, reciever, silvercan, 3600mah ladder pack and tamiya focus shell, it weighed in at 1489grams!!! the car has bearings, tie rod turnbuckels and alloy shaft. i have never owned such a light chassis!
i plan to remove the upper arms on the car and replace them with tie rods so camber can be adjusted on front and rear also
Old 01-05-2008, 06:44 PM   #675
Mooshu Beef's Avatar
So it looks like you can mount the spur gear on and pinion independent from the chassis so the meshing can be looked at better. Or you you have to adjust the meshing when the mount is on the chassis?
I look at my beat up tub chassis... and I cry on the inside. But my next upgrade is my ESC--and I am waiting for someone to buy the sidewinder and sell it used
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
