Like Tree1Likes
Old 09-15-2007, 10:23 PM   #571
cranky's Avatar
Originally Posted by Mooshu Beef View Post
They sell lots of diff grease. I found that the HPI heavy duty grease works well, but I haven't tried any other greases.
Try them out yourself, I don't know of any at home fixes.
Battlecat, yes I meant for my sig to be ironic . But glad you're enjoying those sushi tires... I actually want a set since mine were from the previous owner, and just chopped and the edges are all uneven and flat. Ugh.
Cobble stone will be very noisy... Have any tennis/basketball courts in your area you can try to drift in? More flat level surfaces are great for drifting.
thanks
cranky is offline   Reply With Quote
Old 09-16-2007, 12:50 AM   #572
kavadni's Avatar
Default Gear Diffs
Originally Posted by cranky View Post
.. how about the grease for gear diff. is it any oil can do?
Cranky, I assume you have gear diffs. The choice of grease will affect the stiffness of the diff. For example Tamiya ceramic grease will produce a free spinning diff, whereas the Tamiya anti-wear grease will produce a much stiffer result.
The more anti-wear grease you use, the stiffer it gets.
The HPI heavy duty grease produces a result somewhere between the ceramic grease and a light smear of anti-wear.
Kav
kavadni is offline   Reply With Quote
Old 09-16-2007, 02:02 AM   #573
kavadni's Avatar
Default Total Weight
I am curious about what weight people are running at, currently I am running at 1676 grams. It might be a bit boring if everyone posts with there total weight, so feel free to private message me, and I will summarize.
Tips on how to reduce weight also appreciated.
Kav
Old 09-16-2007, 04:12 AM   #574
Is yor weight include everything in there, body, battery..race ready?
Clangeddin is offline   Reply With Quote
Old 09-16-2007, 04:29 AM   #575
kavadni's Avatar
Yes
Old 09-16-2007, 06:29 AM   #576
Mooshu Beef's Avatar
Well I don't race competitively so it doesn't really matter to me. Plus I don't have a balance that measures mass...
The only thing coming to mind to lighten it is to remove the skid plates. Other than that, cutting anything out of the chassis will take away from the stiffness...
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
Old 09-16-2007, 11:48 AM   #577
Anyone feel that the gears seems a little stiff?
I have a TRF 415 and it seems the TRF 415 gears is much more smoother than TT-01. OR is that normal that TRF 415 gear is much smoother than TT-01?
Old 09-16-2007, 04:17 PM   #578
Well it might seem stiff if you don't have a good alignment of the pinion gear and spur. Otherwise I think the drivetrain is pretty good. Is the TRF another chassis?
Old 09-16-2007, 04:31 PM   #579
Send a message via MSN to TurboT
Lol. The TRF 415 is a wee bit higher end than than a TT-01 so, yes, the TRF 415 will be infinitely smoother than your TT-01.
Team Great Hobbies
Team Durango Canada
Exotek
TurboT is offline   Reply With Quote
Old 09-16-2007, 05:21 PM   #580
sportsracer-5's Avatar
Can anyone confirm that the TT-01 takes 64 pitch pinion gears?
sportsracer-5 is offline   Reply With Quote
Old 09-16-2007, 06:49 PM   #581
kavadni's Avatar
Default Gear Pitch
They are a metric 48 pitch.
Kav
Old 09-16-2007, 11:14 PM   #582
Kav
huh. interesting. thanks.
Old 09-17-2007, 07:46 AM   #583
radio_car_racer's Avatar
Silver Can Motor Tune
What works?
got it geared on 25/55 using GP37's
what's the internal ratio on these cars?
see some TT-01 video clips from my local club here
radio_car_racer is offline   Reply With Quote
Old 09-17-2007, 09:57 AM   #584
kavadni's Avatar
[QUOTE=radio_car_racer;3679337]
[QUOTE]
The internal ratio is 2.6
Old 09-17-2007, 11:06 AM   #585
mog ruith's Avatar
hi guys, my car goes more to the right n sumtimes to the left n not straight!
wats the problem with that? i adjust the steering trim lots of times but after a few turns it will turn more to the left or either right. i just change to the universal shaft n check my wheels seems to wobble, could that be the cause?
im sick of adjusting my steering trim!
mog ruith is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
