Like Tree1Likes
Old 08-01-2007, 03:23 PM   #421
Hey guys, well i though id post a shot of my beast, brushless of course. Ill post more shots soon aswell
Its a pure drift machine, she drifts like a dream. Ive got her loaded with a few goodies that ill also post later on, with a Spektrum DX2.0 on the way. More to come...
Drift Demon is offline   Reply With Quote
Old 08-03-2007, 07:14 AM   #422
squad car's Avatar
nice car you have!
Who am I? You sure you want to know? The story of my life is not for the faint of heart. If somebody said it was a happy little tale... if somebody told you I was just your average ordinary guy, not a care in the world... somebody lied.
squad car is offline   Reply With Quote
Old 08-03-2007, 09:15 AM   #423
doriftu's Avatar
hi guys,
i just bought 25/55 pinion and spur gears. however, i have used my all the anti-wear grease supplied in the kit.
so my question is can i use normal grease for those gears? any specific grease to use?? stick to AW grease?
can i use normal grease for car/automotive applications? pls advise... i cant wait to test out the new gear ratio...
doriftu is offline   Reply With Quote
Old 08-03-2007, 09:59 AM   #424
squad car's Avatar
Originally Posted by doriftu View Post
hi guys,
hi doriftu,
what normal grease do you have?
is it liquid or paste like grease?
but for me, the best thing you can do is to go to the nearest LHS and buy "Tamiya Ceramic Grease" rather than to wait for an answer to your question.
Old 08-03-2007, 10:07 AM   #425
doriftu's Avatar
Originally Posted by squad car View Post
hi doriftu,
just the regular tamiya grease. the paste type. just a lil' bit left in the tube. whats the difference between Ceramic, molybdenum etc grease. im kinda new to the hobby... looks like i have to wait for a new tube of grease b4 changing my gears....
thanks!!
Old 08-03-2007, 10:26 AM   #426
squad car's Avatar
thanks!!
the ceramic grease use for gears, plastic & metal bearings.
if you cant wait for your next tube of grease, cut the grease tube in two 2 and use everything you can get. that will be enuf for a while, you can add grease if you get a new 1.
Old 08-03-2007, 10:26 AM   #427
asil's Avatar
Send a message via MSN to asil
it's the ceramic grease for gears.. put a little on the pinion and give it a couple of turns..it's OK.. moblydenum grease is somewhat sticky then ceramic I think.. I work in a automotive service and normal grease is too much sticky for our cars
Asil
asil is offline   Reply With Quote
Old 08-03-2007, 07:54 PM   #428
squad car's Avatar
its written in the tube
Old 08-03-2007, 10:06 PM   #429
doriftu's Avatar
thanks guys!! will get a tube of ceramic grease then
wanna see how much difference does a lower ratio makes to a Tamiya sports tune motor... hehehe... has yet to get my hands on a 23T motor...
Old 08-04-2007, 10:25 AM   #430
squad car's Avatar
happy racing,
Old 08-04-2007, 02:45 PM   #431
i tried a set of tamiya drift tires w/ a stock kit; the thing bounces and jumps like a kangaroo on crack. is there something to tame it down, or is that the nature of drifting??? it has stock friction dampers; r oil dampers w/ thin oil necessary?
swannco is offline   Reply With Quote
Old 08-04-2007, 05:56 PM   #432
Mooshu Beef's Avatar
Tamiya Drift tires are rubber right? Even hard rubber compounds I think are reserved for high speed drifting. I have stock springs a Co 27 Pro stock motor and BB's and this thing is drifting wonderfully with ABS. Of course, I need practice, but the setup I have is real nice.
So no, stock springs and dampers are fine. But getting oil dampers will help you adjust the dampening speed, and springs would adjust how much your body rolls.
Give some more details about your setup, and we'll be able to help you out.
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
Old 08-04-2007, 11:50 PM   #433
Yes, the tamiya drift tires are hard rubber not ABS, so they have some grip at lower speeds. Maybe the parking lot is just too rough because the car just jumps and chatters. A smoother surface would probably be the ticket. The set up is bone stock TT-01 right now. The only upgrade is a full bearings packet. Maybe drifting just ain't my thing, but I was curious to see what it was like. I don't have anyplace smoother to try unfortunately; bummer.
Old 08-05-2007, 12:22 AM   #434
By the way, any tips for repairing cracked bodies? My best friend drove my beautiful new ferrari straight into a secret curb at full throttle. He panicked and tried to e-brake, but just pulled the throttle harder. LOL. He felt really bad, but we've all done the same thing at least once, I'm sure. I'm hoping there is some way to minimize the damage, or at least keep it from getting worse.
Old 08-05-2007, 01:48 AM   #435
doriftu's Avatar
tamiya tires are difficult to drift with unless u are on a really smooth surface such as tiles etc. you can start off my DIY-ing ABS tires with 2" ABS pipes. that will make your car skating on ice
if u are getting serious on drifting, the best drifting tires would b ethe yokomo single rings it has great combination of speed and can initiate drifts easily.
btw, its ok to have a stock TT01 for drifting... u can hop up it as u move along...
cheers!
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
Tags
drift
