Like Tree1Likes
Old 07-12-2007, 09:56 PM   #376
My Buddy has a TT-01 on the way, I can't wait for him to get it!
What HOP-UPS should he start with to keep pace with my XXX-S G+? I told him we can run 19T Spec motors to keep things fair.
So far he plans to get some bearings ( which brand ?) some Oil shocks.... should he get the TRF ones or is there a better set?
+ some Ball diffs ( who makes them? )
Also what the diff between the TT-01 & TT-01R?
Any info would be awsome..... I have to admitt though I haven't read through the pages on this post, so I guess I'm kind of looking for the easy way out.
Jay
pyro18t is offline   Reply With Quote
Old 07-12-2007, 10:29 PM   #377
If your going to be running 19t the aluminum propeller shaft is a must the old ones wobbles under acceleration and high rpms, dont't forget the ball bearings as well, trf shocks are really good though i like the yokomo shocks better on the tt-01 they seem to hug the track better, thats just me though.
But for it to be able to rub shoulders with the xxx-s g+ i suggest he buys all the hop ups of the car
imel24 is offline   Reply With Quote
Old 07-13-2007, 05:44 AM   #378
Sounds good bro, what do you recomend in way of companies?
For bearings I told him to go with ACER, but he said they are like $80, and that's just to much for him.
and what about the ball diffs.
Jay
Old 07-13-2007, 06:35 AM   #379
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
Why would you buy the bearing from ACER for like $80.00 when Tamiya sells a full ball bearing set for only $21.50 full retail?
Tamiya part number 53497....
rctouringracer is offline   Reply With Quote
Old 07-13-2007, 06:59 AM   #380
Because ACER make some of the best bearings, and at the time I didin't know they were 80 bucks for the set.
I just got off the phone with him, he got his car, but his wife isn't going to let him have it till Monday ( his B-Day )
Does anyone have any good building tips?
Jay
Old 07-15-2007, 01:28 AM   #381
AussieSamurai's Avatar
Default Just married
I just bought an Esso Ultraflow Supra TT-01 Kit yesterday and I love it. I got the bearing set as well so its all smooth. I also want to get some blue neons going. Only problem is I didn't get the aluminum propeller shaft at first and now if I do get it I have to take nearly the whole car apart to install it (I think). Is there an easier way to install the shaft? And also is it worth it to get a sport tuned motor? And last of all does anyone know of any tracks around Melbourne in Australia? That would be great if you do.
Aussie Samurai
P.S. Pics below (if it works)
[img=http://img264.imageshack.us/img264/4171/img0458xj1.th.jpg]
[img=http://img186.imageshack.us/img186/465/img0461ih8.th.jpg]
[img=http://img507.imageshack.us/img507/1739/img0460od8.th.jpg]
AussieSamurai is offline   Reply With Quote
Old 07-15-2007, 02:11 AM   #382
hemi426's Avatar
That's no big deal, you have to open the rear diffcase and take out the diff (my tip: simply pull off the complete rear suspension with diffcover and diff as one unit with the upper and lower arms still in the diff cover). Pull of the small bevel gear and the bearing. Take the main gear cover off as well, now it should be possible to take out the main shaft. This is also the way to change the main gear. Thats 13 screws in total.
TRF 416, Cyclone S, TT-01E, Evo III SL, TamTech GT01, Slash, M18 Pro, M03-R
hemi426 is offline   Reply With Quote
Old 07-15-2007, 02:22 AM   #383
hemi426's Avatar
Now it's official. This years 24 hour race will take place at the new Motodrom Andernach Track in Germany September 8th/9th. So far 22 teams applied. 7 drivers per team makes a total of 154 drivers!
22 cars on the track at the same tiime and this one is smaller than last years track (Sinzig/Germany)!
Chassis will be the normal TT-01 hopped up with bearings, oil-filled dampers, alloy main shaft, alloy motor mount and speed gear. Motors will be Carson Cup Machines. Each teams gets the car, motor (Cup Machine), 2 tire sets and 8 battery packs at the track. So everyone has the same material. We still don't know what bodies we will get. Light on the car is mandatory!
Old 07-15-2007, 03:23 AM   #384
Aussie Samurai
what i do to remove the shaft is i open the motor case 4 screws i think then just lift the spur gear and you can basically slide off the prop shaft from there. the sport tuned is also a good motor big difference from the mabuchi silver can best of all it's cheap too. i highly suggest that you get the speed tuned gears as well, i usually run 25 pinion 55 spur on the silvercan and sport tuned motors and it's almost as fast as my 23 turn motors
Old 07-15-2007, 04:41 PM   #385
Thanks for the tips. I was also wondering about how much difference the carbon upper frame made?
one other thing. What sort of hop-ups should I get? I plan to get a motor, alum prop shaft, alum steering set and possibly carbon upper frame. Any tips? And btw what do the (T)'s at the end of motor names mean? E.g. GT-Tuned motor (25T)
Old 07-16-2007, 04:51 AM   #386
Default Setup Tips
My local club has just started a touring car class exclusively for the TT01 running with a standard 540 kit motor and rubber tyres.
The only hop-ups allowed are
Alloy Propshaft
Oil filled Shocks
Sports gear set.
Bearings
I have added all the permitted hop-ups to my car, but I want more performance. What can I do to the transmission, diffs etc to increase performance?
Does anyone fill their diffs with oil?
Any other tips
simon_allen is offline   Reply With Quote
Old 07-16-2007, 07:37 AM   #387
hemi426's Avatar
T means Turns or the number of windings an electrical motor has. The lower the number of windings, the higher the current and the power of the motor. That's the very short explanation.
My recommendation for beginners: Start with something like a 23T or more turns.
Old 07-16-2007, 09:59 AM   #388
retsilla's Avatar
my tamiya series car
electronics: futaba9550, airtronics RX431, tamiya teu101bk esc.
retsilla is offline   Reply With Quote
Old 07-16-2007, 03:02 PM   #389
Thanks Hemi I'd been puzzling over that for a while. I think I also know what hop ups I'm going get cos I found a club and they allow any hop-ups or any whatever you want in the electric touring class. I'm gonna get the Alum prop shaft, alum steering set, sport tuned motor, new gearing and thats it for starters but I plan to get a lot more including neons!
Old 07-17-2007, 05:49 AM   #390
Blueshark's Avatar
Have been toying around with that idea for a while now since i got my MM5700...i have been running with 11T and sometimes it does strip my spur and pinion gear...too much torque...i think the MM will probably kill the gears...have you tried your MM7700 on the TT-01 yet? I think i'd need to gear it 61/19...and hope the gear holds..
Originally Posted by pole_position View Post
Thanks for sharing your spec.
What is the final gear ratio you are running? 8.35:1 using 61/19?
With the power of MM7700, does it tear up your bevel and ring gear?
How was the car behaviour like in the corners?
I am keen to install a MM4600 into my TT-01 too.
Appreciate your comments...
Blueshark is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
