Like Tree1Likes
Old 06-17-2007, 11:36 AM   #361
kreamUNO's Avatar
1. mamba max esc with a 7700.
2. those are shrink wraps.
3. i think it's the stock one, i'm not sure, i'm at work, i'll check for it later.
4. futaba.
i hope that helps.
kreamUNO is offline   Reply With Quote
Old 06-18-2007, 09:41 AM   #362
vadersing's Avatar
How do I set up my TEU-101BK ESC to get maximum power for my TT01 stock racer?
vadersing is offline   Reply With Quote
Old 06-19-2007, 07:02 AM   #363
good day guys i'm trying to avoid the purchase of the aluminum steering assembly as much as possible, maybe you guys have tweaks on how to minimize slop?
imel24 is offline   Reply With Quote
Old 06-19-2007, 08:00 AM   #364
Don't think theres many tricks, fact is, plastic flexes, nothing you can do about that :P and the aluminum steering is only $15 on ebay :P
Havoxx is offline   Reply With Quote
Old 06-20-2007, 10:44 PM   #365
rough512's Avatar
Imel24 : the aluminum steering is really necessary as it eliminates side-to-side and up-and-down slop. That's a major reduction. There's a bushing that goes inside the steering arm bearings. You can sand these down to match the arm's bearing heigt to eliminate up and down play.
You can also sand down the bushings of the bridge that links the two steering cranks together, or just shim it to eliminate up and down play.
Another source of slop is the part of the front upright that goes into the pivot ball inside the upper and lower arm. The part that goes into the ball is sometimes too thin, you can wrap a layer of scotchtape to take up some of the looseness. You can either wrap enough tape and still let the front upright turn inside the ball or wrap more tape for tight fit with the ball; in this case the ball will start turning inside the cavity of the arms.
after the upright/arms become snug, use turnbuckles,ball studs and ball cups for the steering links and twist the steering links to take out any slop.
rough512 is offline   Reply With Quote
Old 06-21-2007, 08:32 AM   #366
mailboxck's Avatar
Originally Posted by Kruzer View Post
mailboxck.... did you ever find a solution to that camber slop of the TT-01?... I'm having the same problem right now... even with the stock front upper arms, when I used a camber gauge to measure the camber the left (driver side) camber is -1 which is what's it suppose to be... but the right (passenger side) camber is +1 which would make it 2 degrees off..... what could be causing this? can anyone help me?
Actually no, i simply used the stock upper arms and just didn't mind the problem. I just lived through it since i couldn't fix it.
mailboxck is offline   Reply With Quote
Old 06-21-2007, 02:55 PM   #367
I just ordered my 1st TT01 kit today + a full bearing kit. For parking lot bashing only, no racing. I have radio/rec/servo already. Should I upgrade anything else [oil dampers, aluminum shaft?] or is it pretty good as is? Thanks!
swannco is offline   Reply With Quote
Old 06-21-2007, 07:51 PM   #368
Thank you rough512 those were really helpful i'll try them out today.
Old 06-21-2007, 08:42 PM   #369
Heres my new TT-01R, got the turnbuckles, alum motor mount, and alum steering in the mail :P
Old 06-24-2007, 02:54 AM   #370
pole_position's Avatar
4. futaba.
i hope that helps.
Thanks for sharing your spec.
What is the final gear ratio you are running? 8.35:1 using 61/19?
With the power of MM7700, does it tear up your bevel and ring gear?
How was the car behaviour like in the corners?
I am keen to install a MM4600 into my TT-01 too.
Appreciate your comments...
pole_position is offline   Reply With Quote
Old 06-24-2007, 10:48 AM   #371
kreamUNO's Avatar
-no problem sir.
-i can't say what gear im running right now, ive been busy lately, but i'll pm you tonight when i get home.
-not that i know off, i've ran it twice and nothing really big has happened, maybe a little dirt or so, and that's about it.
-it's smooth jsut as long as you slow down
-put a 7700 on it sir, you'll love it, it really pulls..
Mugen MTX-4R-NINJA MR12TUNED-NINJA FLS || Kyosho v-one RRR evo.2-SirioXXX-Sirio 2611
Kyosho Inferno WC-JAMMIN' JP3 || Kyosho M3-Sirio CL7R-Novarossi
XRAY T3'-Novak 13.5/tekinR1 || Serpent S120-RP x11 3.5
Tamiya IFS-Novak17.5/SPX || Tamiya TT-01-LRP x11 17.5
Old 06-24-2007, 12:57 PM   #372
RC MARKET's Avatar
3 Racing have many new option parts onsale !
RC MARKET is offline   Reply With Quote
Old 06-24-2007, 11:44 PM   #373
-no problem sir.
Thanks for sharing!
The track I am running at now is low grip and very dusty. I had to trimmed all the MM5700 settings to their minimum to run my XRay T1 and it is really flying... I cant imagine a MM7700 on a TT-01 will be like ...
Old 06-25-2007, 07:05 PM   #374
I'm curious if anyone bought the TT-01R, does the GT tuned suck? or is it my imagination, my old sport tuned motor is tons faster.
Old 06-26-2007, 09:20 AM   #375
I agree.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
