Like Tree1Likes
Old 05-29-2007, 10:42 AM   #331
rays_tt's Avatar
Trader Rating: 26 (100%+)
Tamiya #53876
www.melbRC.org
rays_tt is offline   Reply With Quote
Old 05-29-2007, 04:20 PM   #332
do you have a part number for the turnbuckles for your upper arms? my rear turnbuckles on my upper arms have bent, hehehe!!
cairnsrc.com
REC'd Racing
What I have - Brushless Slash 4600kv, DX2S
What I need - Boss Motorsports 10.5, TRC LCG chassis, Ford F-150 SC body, Proline Protrac & a Brushless XXX-T CR MMP4600kv. Not alot!
Drift Demon is offline   Reply With Quote
Old 05-30-2007, 12:13 AM   #333
rays_tt's Avatar
No I don't have the part number for those, but they are 18mm turnbuckles.
www.melbRC.org
Old 05-31-2007, 07:20 AM   #334
Send a message via Yahoo to needrcspeed
Anyone tried a Mamba Max/5700 and 3 cell lipo in their TT-01?
I am seriously addicted to sucking speed out of my RC cars...and my TT-01 is next on the hit list. I have a Novak SS+/5800kv in it now and run a 6cell ni-mh. My Mamba Max arrives today and a 3-cell lipo is in the works.
needrcspeed is offline   Reply With Quote
Old 05-31-2007, 03:55 PM   #335
I had a 5700 on 6cell NIMH in mine, upgraded the drivetrain to STEEL universals and alloy propeller shaft and all new joints. It handled it extremely well, i though there was no way it would hold up with the 5700, but it held up awesome. Im about to shove a 3S into my 4600 now, so ill let u know how that goes!!
cairnsrc.com
REC'd Racing
Old 05-31-2007, 09:48 PM   #336
rough512's Avatar
@Demon
Do you have any fix to the propeller shaft's excessive vibration? Any hopup I can use?
rough512 is offline   Reply With Quote
Old 05-31-2007, 09:55 PM   #337
rays_tt's Avatar
Originally Posted by rough512
@Demon
Try putting some O-rings into the drive cups to reduce the movement of the shaft.
www.melbRC.org
Old 05-31-2007, 10:43 PM   #338
Frost's Avatar
Trader Rating: 56 (98%+)
Red face
u can try this... it solved the vibration problem on my tt-01
STD22SP
Toyota keeps Moving Forward
Nissan keep SHIFT_ing whatever they touch
Honda is still DREAMing until today
Frost is offline   Reply With Quote
Old 05-31-2007, 11:13 PM   #339
This will be my next propeller shaft i use, im currently using a tobee craft lightweight shaft and cup joints, hoping it would eliminate the play, but had no success, my cup joints have big marks in them from the prop shaft...
cairnsrc.com
REC'd Racing
Old 05-31-2007, 11:17 PM   #340
rays_tt's Avatar
STD22SP
I've thought about getting that, but I dont get much play, and its $30US so still deciding
www.melbRC.org
Old 06-03-2007, 09:06 PM   #341
bshookup's Avatar
Trader Rating: 18 (100%+)
Default TT01 Push
I'm trying to get a TT01 ready for the SPEC class at a TCS race, and I have not figured out how to get rid of a nasty on-power push. I have the adjustable upper arms, adjustable steering links, and oil filled shocks.
So far I have given the car more camber in the front than the rear, put in some toe-in, lighter oil in the front, and I tried to lower the front ride height and decrease the front droop by putting spacers inside the front shocks to limit shock travel. Any ideas from you experienced TT01 drivers?
bshookup is offline   Reply With Quote
Old 06-03-2007, 09:55 PM   #342
rough512's Avatar
Try stiffening the springs up while keeping it driveable. A 2deg toe in rear block can help minimize oversteer.
A one way diff or tight ball diff will also help.
Try running a touring body with a small, almost insignificant spoiler. . I tested an NSX body vs an Opel body yesterday and I like the slightly looser feel of touring body. I had to use the 2deg block to offset the absence of rear downforce.
Old 06-07-2007, 04:02 PM   #343
Default TT-01 Camber slop
mailboxck.... did you ever find a solution to that camber slop of the TT-01?... I'm having the same problem right now... even with the stock front upper arms, when I used a camber gauge to measure the camber the left (driver side) camber is -1 which is what's it suppose to be... but the right (passenger side) camber is +1 which would make it 2 degrees off..... what could be causing this? can anyone help me?
Kruzer is offline   Reply With Quote
Old 06-07-2007, 04:09 PM   #344
bshookup... you can try getting a front one way unit.... a toe-in rear upright can help you with stability... but for the fronts, if you want more oversteer, you need to toe it out... if you want more understeer, give it more toe-in... and as for shocks... you need more droop in front and less at the rear... but that shouldn't have too much of an effect
Old 06-07-2007, 04:24 PM   #345
bshookup... i forgot to mention.... it would be a good idea to have 0 degree camber in front and negative 1.5 or 2 degree camber in the rear....
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
