Like Tree1Likes
Old 05-03-2007, 11:02 PM   #271
asil's Avatar
Send a message via MSN to asil
546 miles!!! wow..
BTW, I have TT-01R and it has gear diffs and steel dogbones and axles. I bought ball diffs but they are designed to be used with stock plastic dogbons and axles. Do you have any idea how to use these ball diffs with tt-01r??
Asil
asil is offline   Reply With Quote
Old 05-03-2007, 11:42 PM   #272
hemi426's Avatar
Thanx Asil, this answered my second question, I think. Did you buy the Tamiya ball diffs 53663? Then I guess you'll need the part 53806 to use your universals with the ball diff. Maybe someone here could confirm that?
TRF 416, Cyclone S, TT-01E, Evo III SL, TamTech GT01, Slash, M18 Pro, M03-R
hemi426 is offline   Reply With Quote
Old 05-04-2007, 04:45 AM   #273
shan74's Avatar
if you have a tto1 and the shock springs have no preload on the shock body .i used some rubber o rings .just sit them on top of your spring when you put them back togethor and then your front end wont wobble as much.
i have tried a lot of gear ratios and found the spur/pinion gear ratio of 58/23 works real well without losing to much bottom end.
well hope this helps out other tto1 owners.
shan74 is offline   Reply With Quote
Old 05-04-2007, 07:02 AM   #274
Send a message via Yahoo to needrcspeed
This is correct. I bought my universals before buying part 53806 and they did not fit properly.
needrcspeed is offline   Reply With Quote
Old 05-04-2007, 07:09 AM   #275
asil's Avatar
the thing is I don't have universals.. I only have steel dogbones.. I think 53806 will solve my problem.. thanks..
Asil
Old 05-04-2007, 07:44 AM   #276
hemi426's Avatar
I can check if the universals look the same as the steel dogbones on the diff side. I have the TT01-R from the 24HR race here. It sucks in terms of durability mostly because of the aluminium turnbuckles that break far too easy. During the race all teams replaced the adjustable suspension with the normal suspension without aluminium turnbuckles.
Old 05-04-2007, 09:53 AM   #277
asil's Avatar
I appreciate that
Old 05-04-2007, 02:58 PM   #278
nivek's Avatar
nivek is offline   Reply With Quote
Old 05-04-2007, 11:53 PM   #279
rough512's Avatar
Do you guys think the 2degree rear toe blocks affect top speed on asphalt too much? Anybody compared them with the stock 0 toeblocks?
rough512 is offline   Reply With Quote
Old 05-05-2007, 02:02 AM   #280
hemi426's Avatar
@asil:The metal dogbones of the TT-01R and the 53792 TT01/TA04 Universal Drive Shaft habe pretty much the same end. So 53806 as diff outdrive should be ok for both.
Could you maybe figure out the weight of the ball diff? I am trying to get the weight of my car down. I will change my 9550 servo to a 9650. And replace my Spektrum HRS Receiver with the spektrum Micro receiver. ESC will be an iCube. Pretty much stock electronic, eh?
Old 05-05-2007, 02:04 AM   #281
asil's Avatar
thanks, you're great.. now I'm going to my LHS and buy two sets..
Regards..
Asil
Old 05-05-2007, 09:14 AM   #282
Default TT-01 Bodies
What bodies can I get that will fit the TT-01's? I'd really like to find a Corvette body. Any help?
Thanks,
Derrick
Team Hoagie is offline   Reply With Quote
Old 05-05-2007, 11:52 AM   #283
sosidge's Avatar
Proline and Tamiya have made Corvette bodies that I know of, maybe more too.
Old 05-05-2007, 06:40 PM   #284
volracer's Avatar
Send a message via ICQ to volracer
Cool
The proline body is 200 mm wide.
McAllister makes a corvette http://www.mcallisterracing.com/racing/page4.html
Tamiya corvette boddies include:
http://www.tamiyausa.com/product/ite...oduct-id=50915
http://www.tamiyausa.com/product/ite...oduct-id=49188
If you are in to Old School bodies:
http://www.bolink.com/touringbodies.html
volracer is offline   Reply With Quote
Old 05-05-2007, 11:30 PM   #285
Looking for a Body Kit (clear uncut body, wing and decals) for the 58323 - Schnitzer BMW M3 for the TT-01 chassis. I checked Tamiya's website and could not find one. Any idea if they make a body kit for this or do I have to buy the body, decals and wing all separate?
thanks.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
