Like Tree1Likes
Old 04-23-2007, 02:44 AM   #241
asw7576's Avatar
Originally Posted by imel24
good day i was just wondering, what's the most practical way to setup a tt-01 for rally???
I know for one that i'll be needing the rally block tires, after the tires what's next??? how do i increase the ride height suspension etc???
is there any particular tamiya model that i can swap parts from??? thanks in advance!!!
You need longer shocks, I think Tamiya Pink ( Alluminium ) Oil Damper Set should be good. Or Tamiya Black Oil Damper ( original oil damper from TA05, TB02 ).
Old 04-23-2007, 07:25 AM   #242
sosidge's Avatar
You won't get the TT-01 any higher than it is with the kit shocks, the suspension will only go down that far. Ride height is already substantial at 15+mm.
As it says on the TT-01 box - "On-road use only". Run it as a rally car if you like but don't expect it to run as well as one of the old TB-01 chassis which were designed for rally.
Old 04-23-2007, 11:20 AM   #243
Trader Rating: 30 (100%+)
One of our friends cut out the lower plate to allow more travel to the arms and then just put the longer lower shock eyelets on and ran it on our rally track. It ran really good. I would suggest making some kind of cover or trying to get the TB01 inner body set cover to fit.
wrxnfx is offline   Reply With Quote
Old 04-23-2007, 03:29 PM   #244
khanzie's Avatar
Talking spur and pinions
i was just wondering what spur i would need for the following:
23t
24t
25t
and can u get a 26t or higher
see ya later
thanks
khanzie is offline   Reply With Quote
Old 04-23-2007, 11:58 PM   #245
speedshock's Avatar
think this would help
speedshock is offline   Reply With Quote
Old 04-24-2007, 01:44 AM   #246
khanzie's Avatar
Default thanks
thanks for that
Old 04-24-2007, 03:32 AM   #247
khanzie's Avatar
Talking what chassis hop ups
what chassis hop ups would make my 18t
pinion
go faster than my friends 25t
without changings the gears
and we both have a tamiya sport tuned
would carbon fibre hop ups make it alot faster
Old 04-24-2007, 03:43 AM   #248
sosidge's Avatar
Chassis parts don't make the car any faster in a straight line and cost a lot more than a pinion gear and the spur set. Just get the same gearing as him.
Old 04-24-2007, 04:41 AM   #249
khanzie's Avatar
Talking thanks
so if i get the spurs and pinioin the same
will make the same speed
but is a lrp buggy special any faster than a sport tuned
would the hop ups like carbon fibre and stuff make it a bit better in corners
and what are the best tyres to buy for racing aat a rc car club
would i be able to make my tt-01 go faster than a ta-05 with a 540 in it
would gearing beat it
Old 04-24-2007, 05:00 AM   #250
RocketRacer's Avatar
to get the speed you need to work wih the gearing. 55Spur and 25 pinion in a TT01 will yield the best results with a 540 motor, even better with a Sport tuned. just make sure you monitor the motor temps though, you don't want the motor to run too hot.
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 04-24-2007, 06:10 PM   #251
khanzie's Avatar
Default what r the best tyres
whatar the best tyres u can buy for racing
i dont care how long they last but what give the best grip and good turning
Old 04-24-2007, 06:11 PM   #252
khanzie's Avatar
Default what about like a 26 27 28t pinion
how much more top speed would i get from 26t and pinion in it
Old 04-24-2007, 06:18 PM   #253
khanzie's Avatar
how more speed could i get out of my tt01 with a 26t and higher pinion in it
Old 04-24-2007, 10:22 PM   #254
speedshock's Avatar
u have to try on that dude. 25/55 is by far the best for sport tuned/540.
Old 04-25-2007, 02:49 AM   #255
khanzie's Avatar
Talking thanks for the help
soo what motor can i get without going above a 540 sized motor go faster than a sport tuned
like a lrp buggy special or something
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
