Like Tree1Likes
Old 01-03-2017, 12:57 PM   #2491
team green's Avatar
Originally Posted by vivo quevas View Post
o
Look great love the colors of your trucks. I was in Stockton over the weekend they had 5 trucks racing I didn't bring mine but this weekend I will race it.
[YOUTUBE]https://youtu.be/msy44eh9uL0[/YOUTUBE]
I'm thinking of heading down there too. Its just I don't get off work til 5a.m. Saturday morning. Then I have to drive to Stockton from San Jose. After driving 360 miles for work.
team green is offline   Reply With Quote
Old 02-07-2017, 11:36 AM   #2492
Send a message via AIM to GuyIsDamGood
Default TT-01 vs HPI RS4 Sport 3
Is the TT-01 better than the HPI RS4 Sport 3?
GuyIsDamGood is offline   Reply With Quote
Old 03-11-2017, 04:09 PM   #2493
GrandeGixxer's Avatar
I'm sure in the 167 pages of this thread it's been covered at least 16 times; but any build tips/tricks for the diffs and dampers?
Loco4G63T likes this.
GrandeGixxer is offline   Reply With Quote
Old 03-12-2017, 06:14 AM   #2494
Loco4G63T's Avatar
Trader Rating: 23 (100%+)
Trying to get a leg up on the competition huh? I like you style sir.
"D" TTRC - RCRNV and Mimi's "The TRACK".
OFF ROAD - B5M CE, TLR22T 2.0, and Mugen MBX7R Eco.
ON ROAD - 13' T4(VTA), 14' T4(MOD), 15' X1(21.5), CRC X10LE (WGT), Tamiya Euro Semi-Truck and Serpent 977e Evo 2.
Driving through hell and back! Phoenix Raceway, Afghanistan 10'-11'.
Loco4G63T is offline   Reply With Quote
Old 03-12-2017, 08:20 AM   #2495
Of course! As bad as I drive, I need all the help I can get!
Old 03-12-2017, 09:37 AM   #2496
ThePanda's Avatar
Trader Rating: 64 (100%+)
diffs are open. Use heavy grease like tamiya aw to give little less diff action. if you have friction dampers they are pretty basic. if you have the cva dampers they are simple, but can be tuned with different oil.
ThePanda is offline   Reply With Quote
Old 03-20-2017, 09:18 AM   #2497
Default Over - Oversteer
There's a lot of Mid-Corner Oversteer while being On and Off Power on a Sweeper.
-It'll Oversteer with the Stiff and Extra Stiff Springs installed.
I have experience finding the balance(Set-Up) on many high-end Racing level chassis. But; this TT-01(it is't high-end) is crazy.
-it's fun to bash-race with this chassis.
Old 03-22-2017, 06:30 AM   #2498
cartix's Avatar
Trader Rating: 33 (100%+)
Originally Posted by GuyIsDamGood View Post
I don't have a real track in my area. So we race in a school yard(I.S. 296 - Bushwick - Brooklyn, N.Y).
I built a new layout. It had 6 Sweepers, 6 semi-short Straights and 6 Hairpins. I tried to learn the track with the 2 chassis as quick as possible.
If you guys are going to run in the schoolyard this summer I'll come by. Let me know.
Cars and boats, lots!
cartix is offline   Reply With Quote
Old 03-23-2017, 09:55 AM   #2499
Thanks for taking interest in running/racing with us at/in the school yard this summer.
I'm changing(shrinking) the layout to 2/3 of last years size. Now it will have 4 turns and 4 sweepers.
We usually race/run out there in July or August and early November. - ONLY on Tuesdays or Wednesdays or Thursdays. - 7a.m. to 11:30a.m. or 12p.m.(we end it before the teachers/kids start using the school yard)
I just have to remember to post the race/run date(s). . .Ha Ha!
Take Care
Old 03-23-2017, 01:56 PM   #2500
Send a message via AIM to Nerobro
So I just got a wacky idea for using a TT01 for towing my kiddo on a trailer.
Some high turn brushed motor, a couple big 2s batteries. A bunch of extra weight, and a coupler.
... so what parts are going to fail first?
Nerobro is offline   Reply With Quote
Old 03-23-2017, 02:01 PM   #2501
I would slap a good set of bearings, buy the alum drive shaft so it does not snap crackle pop, go somewhere in the 7.xx FDR range with a 55 turn motor min lol.. Weight place evenly. How heavy is your kid? Make the trailer to most of the work and just have the Hahn be the torque monster to pull it
[Yokomo 16' BD7 17.5 Stock] [Yokomo 16' BD7 21.5 USGT] [Tamiya TT-01E Hahn Truck] [Tamiya TA06 Exo 17.5 Stock *Retired*]
DaSilva3525 is offline   Reply With Quote
Old 04-07-2017, 02:29 PM   #2502
Lopaka208's Avatar
Default ESC Recommendations
I bought a Hackmoto V2 13T motor for my TT01 Type E, but the stock esc does not support it. Can anyone recommend a brushed esc that will support the current draw on the Hackmoto? I'm having some difficulty determining which ones will and which ones won't. Thanks a bunch in advance!
Lopaka208 is offline   Reply With Quote
Old 04-10-2017, 11:32 PM   #2503
Hobbywing 1060?
soze is offline   Reply With Quote
Old 04-11-2017, 03:42 AM   #2504
Lopaka208's Avatar
Originally Posted by soze View Post
Hobbywing 1060?
That, or the Tritonic I believe will work.
Old 05-15-2017, 02:23 PM   #2505
sosidge's Avatar
Just wondering whether anyone else has experienced problems with the TT-01 "melting" the area around the rear spur gear.
I'm running a TT-01E in a vintage series called the Iconic Cup, but I am struggling with the above issue.
I made a bad effort at sliding the rear propellor joint through the spur gear during a rebuild. It looks like the pin didn't locate properly inside the spur, leaving me with a damaged spur and the spacer that goes over it. This probably cooked a motor as well.
I replaced the wrecked parts and although the propellor joint was worn, it seemed OK to re-use (this the the TT-01E hop-up part by the way). However the centre of the spur and spacer melted in the first run again.
Is it possible that the tub has been warped, or that there is some general issue with the TT-01E hop up propellor shaft? I had an original TT-01 a number of years ago and it had none of these problems.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
