Like Tree1Likes
Old 12-11-2015, 03:47 PM   #2446
(0000000000)'s Avatar
A kid should be able to build a tt01 fine with a phillips screwdriver, some time, and a little earned frustration.
First hop-up is a toss-up, between ball bearings or metal drive shafts & propeller shaft.
IMO: For a first time build, a TL01 is a bit more simple and bulletproof.
My Original USER ID was 0000000000. But now it doesn't seem to work.
(0000000000) is offline   Reply With Quote
Old 12-16-2015, 05:28 PM   #2447
Send a message via AIM to GuyIsDamGood
Default Suspension Ball Play Problem
Does anyone know a way to stop most of the play with the 5mm suspension balls? Will item # 54559(Low Friction Suspension Balls) be a better fit in the suspension arms?
GuyIsDamGood is offline   Reply With Quote
Old 12-27-2015, 09:07 PM   #2448
Originally Posted by djfourmoney View Post
Hugo, I just bought a used TT-01D Type E. It's missing quite for things (motor, motor mount, D parts, body post, motor pinion, turnbuckle wrench, esc) for $40US.
You sanded down the bevel gears in the diff?
Missing quite a few things is an understatement.
All total -
Parts Three A and D
A for the body post, D for the chassis brace that between the picture posted on CL and when I picked up the car it was missing.
Had I known I needed D I could have maybe just worked with the stock plastic motor mount. But I bought A before D so I got a 3 Racing Alum motor mount.
I needed a body and wheels/tires for regular grip on-road driving.
All total said and done with paint and ESC = $200
Not sure if it's the screaming bargain someone said on URC. Considering it's still not done (98% painted, mirrors, wing, light bucket painting and installation all left).
Especially when I wanted a to get a TT-02 RTR with old shocks and ball bearings for $217 from Japan. If I had known I could get a package from Japan in about 8-10 working days I would have done it.
I but I got lured into building and get more rather than purchasing already built and spending more to get less.
So I got -
TT-01D Type E roller (somewhat) - $40
XV-01 Gazoo GT86 kit - $112 ($126 shipped with tax)
TT-01 Type E Evo VII Japan kit (no ESC) - $112 free ship and no tax (Amazon).
Total - $538
None of the more advanced chassis are available RTR, so I would have to put together the XV-01 anyway. Maybe I should have waited a little longer, I see among Tamiya 2016 releases there's going to be a re-re of the Subaru WRX Monte Carlo rally car on the TT-02 chassis.
No pictures yet so I don't know which body they are planning to use.
Anyway enough of the complaining -
djfourmoney is offline   Reply With Quote
Old 01-03-2016, 06:04 AM   #2449
Old 02-20-2016, 02:51 PM   #2450
T.Wilks191's Avatar
Ive heard wrapping teflon around the balls can help remove it.
Tyrell (T-Unit)
Ballin' on a budget.
TVRCRC Off Road Track Director
Team Tekno
"Just gotta be kinda fast and break stuff last minute" -J.M.
T.Wilks191 is offline   Reply With Quote
Old 03-02-2016, 10:54 PM   #2451
Thanks T.Wilks191. Adding teflon to the suspension balls sounds like a bit too much. I've ordered item # 54559 - Low Friction Suspension Ball. I will see how they fit. I will get back to you.
Old 03-16-2016, 10:52 PM   #2452
Default Suspension Ball Fix
The TT-02 low friction suspension balls are a good fit in the TT-01. There's much much less play with the suspension in that area.
Old 05-23-2016, 10:55 AM   #2453
Hi all,
I'm a new proud owner of On-road car, using the TT-01E, meant for Bash\fun.. not for racing.
I've built the kit, as came in the box and I wish to upgrade it before using it for the first time.
Which oil should I use for the front\back differentials (from the kit)?
Which oil should I use in the shocks?
I was thinking:
- Order the Yeah Racing Aluminum Conversion Kit Ultimate Version (understood that the color don't have any performance different)
- Metal Motor Mount (#53666)
- Low Friction Suspension Ball (#54559, as suggested by GuyIsDamGood)
- TrackStar ROAR approved 1/10th Stock Class Brushless ESC and Motor Combo (13.5T)
- TrackStar™ TS-915 Digital 1/10 Touring Car/Buggy Steering Servo 10.1kg / 0.08sec / 45g
- I'll connect it with my Sanwa MT4 transmitter.
- Will drive it using ZIPPY 5000mAh 2S1P 30C Hardcase Pack (ROAR APPROVED)
Any thoughts, ideas, other recommendations I need to consider?
Thanks in advance!
CrAzYoNi is offline   Reply With Quote
Old 05-23-2016, 11:06 AM   #2454
funked1's Avatar
One thing I just realized, I think you will need a "stick pack" battery for this car, due to the shape of the battery enclosure.
http://www.hobbyking.com/hobbyking/s...ick_Pack_.html
XRAY T4 '17 VTA / Tamiya M07 / Tamiya Euro Semi / Speedworld Raceway
funked1 is offline   Reply With Quote
Old 06-15-2016, 10:52 AM   #2455
To CrAzYoNi
I don't think the TT-01-E has sealed differentials.
If it doesn't you can put Anti-wear Grease in the differentials (you can use any amount you need in each diff).
Old 06-15-2016, 01:15 PM   #2456
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Can someone recommend gearing for a 13.5T brushless motor? Will be running 13.5T for a short while, then probably run 21.5T.
Just picked up the one below for my son, I have a 13.5T combo I want to use for a short while.
Drift_Buggy is offline   Reply With Quote
Old 06-23-2016, 04:35 AM   #2457
Dobbs's Avatar
Trader Rating: 25 (100%+)
Our local hobbytown just got an order of the new team hahn semi kits. We are starting a brand new strictly box stock entry level carpet road course class and use these as the base models. Only allowed upgrade are bearings. Within a week they flew off the shelves. I did mine up as optimus prime and a buddy's in classic gulf livery
Founder/Driver/Co-pilot/Crew chief/Pit crew/CEO/CFO/VP/Executive assistant/Head of secret santa committee:
Punk-Ass Racing
https://www.facebook.com/punkassracing/
Dobbs is offline   Reply With Quote
Old 06-26-2016, 05:46 AM   #2458
Dobbs's Avatar
A short preview of our inaugural box stock semi run.
https://youtu.be/-099GfW1DHo
Punk-Ass Racing
Old 06-26-2016, 06:20 AM   #2459
longuylander's Avatar
That looks awesome! I love the way the front ends skip; it make it look like real semi trucks racing. Glad to see the TT01 still racing. I wish there were a stock class like that near me. ...I wish there was an on-road track near me.
longuylander is online now   Reply With Quote
Old 08-18-2016, 09:28 AM   #2460
I know how you feel. They closed the on-road track here in N.Y.C. I ran and raced(bashed) the TT-01 at the track. It's school-yard racing time.
Take Care
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
