Like Tree1Likes
Old 10-21-2014, 06:50 AM   #2416
yeah, I know what you mean, I have them on my car.
Are you just looking to buy?
53792 is available here:
http://www.tqrcracing.com/shop/produ....asp?p_id=8838
.crispy is offline   Reply With Quote
Old 11-12-2014, 09:57 PM   #2417
Is there a difference in performance when using the Johnson motor between the 101/2/3/4/5 esc, as supplied in the kit? An then when using a Novak GTX esc, will there be a difference vs the 101 esc?
SRJRacing is offline   Reply With Quote
Old 11-13-2014, 12:00 AM   #2418
No, there is no noticable difference. The Johnson doesn't ask for much power, all of them can easily provide that. 'Bigger' motors might need bigger amp ESCs.
Hugo
HugoW is offline   Reply With Quote
Old 12-31-2014, 06:35 AM   #2419
Sport tuned motor work well with my tt01. What other brushed motors are people using for rc drift?
rudeboy03 is offline   Reply With Quote
Old 01-07-2015, 01:16 AM   #2420
Hi,
did anyone ever succesfully fit a ebbro 350r body to a TT-01 chassis? I have found one but the add says it will only fit IFS-chassis. It is low, but it doesn't seem that low in the front... Input from expecience (pics!) is appreciated!
Cheers,
Hugo
Old 01-20-2015, 02:46 AM   #2421
Well, bussy topic, this one. To answer my own question I took the plunge and tried it:
With the chassis at race hight and the wheels centered in the wheel well, there is about half a millimeter clearance between the body and the shock towers. So yes, it does fit. If you raise the car to street bashing levels, the shock towers will be too high.
Hugo
Old 01-20-2015, 07:58 AM   #2422
is there a new motor mount like the tt02 Yeah Racing Aluminum Adjustable Motor for the tt01e?
do the speed gears work from tt02?
TeamThibault is offline   Reply With Quote
Old 01-20-2015, 11:04 AM   #2423
I too have searched for such a mount, but not found. And if google cann't find it... What are you after? You can run a lot of FDs in a TT-01:
Hugo
Old 01-20-2015, 09:14 PM   #2424
What kind of oil you guys using on your bearings to free it up as much as possible?
Old 01-21-2015, 12:56 AM   #2425
I degrease them, dry them and used PTFE spray in the past. This season I use a very thin oil by Kroon Oil, Dutch brand, which is sold as 'bicycle oil'. You do need to re-oil every two or three races, as the oil get lost.
Hugo
Old 01-21-2015, 09:22 PM   #2426
Is this the dry chain lube you use? Do you find they have a less friction than your rc bearing oils? Will you use this on your silvercan's bushes as well? In our class here you have to try and squeeze every bit out of the car to be up there in the top 3
Old 01-21-2015, 10:21 PM   #2427
Here's what I did, posted a few pages back:
TT-01 Forum
Also good springs and dampers (84318) make a difference, though not in rolling resistance.
I don't use a silver can but close; a Cup Machine is mandatory in the class I drive. I degrease the motor using brake cleaner and compressed air, and relube with a few drops of the same oil on the bushes. A squirt of WD40 inside on the brushes will also help marginally.
Hugo
Old 02-15-2015, 10:28 PM   #2428
GRIMREAPER's Avatar
Send a message via AIM to GRIMREAPER
Hey guys i just picked up a tt01e has a few upgrades has a LRP 7.5 motor and esc combo.
is there any must do upgrades and if anyone knows if they make a 70-80s chevy c10 pick up body that wil fit
TEAM 213 /Clodzilla Crawler/AX-10/SCXC10/8ight T e 2.0 MM2/Tekno 8ight 2.0/TT01-E/100mph Rustler/RC8e
GRIMREAPER is offline   Reply With Quote
Old 02-16-2015, 12:11 AM   #2429
It looks like you have the basics covered, shocks, alu centre axle. Check (I almost guarantee) ball bearings are fitted.
Proline has a C10:
http://www3.towerhobbies.com/cgi-bin...?&I=LXSTB0&P=7
Don't know about the wheel base, though.
Good luck,
Hugo
Old 02-16-2015, 08:00 AM   #2430
GRIMREAPER's Avatar
Proline has a C10:
Good luck,
Hugo
thank you for info
what would i need to do to setit up for drifting.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
