Old 08-13-2014, 07:38 AM   #2386
Thanks for the info.
I am racing. 5 minute races.
Bonzai316 is offline   Reply With Quote
Old 08-13-2014, 07:44 AM   #2387
You'll be fine.
I've seen one of mine come off at close to 200 degrees and I think "did I just cook that motor?" but the next time out it runs fine. Still, try to keep it under 160.
Put a fan on it. One of the good 10g of thrust ones. R1 Works has one as does Yeah Racing (Tornado).
When I come off the track, I'll start to recharge the battery, but I'll hook up another battery to the ESC and leave it on so the fan continues to run. Those good fans really do blow.
.crispy is offline   Reply With Quote
Old 08-13-2014, 08:01 AM   #2388
KA2AEV's Avatar
Agreed you'll be fine
Like I said keep it clean and lubed and adding a heat sink and fan on it
would be a nice touch also
But I run mine without and haven't had any issues
Good Luck
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 08-30-2014, 02:03 PM   #2389
bigfatslob's Avatar
Wink Tamiya TT01 Carbon Fiber & Blue Alloy
OK, I know I've fallen into the "TT01 Trap" of spending more on one than the finest chassis made, but it's been fun, besides, I adore my 12 y.o. son After we already spent too much and the installation of a 9.5T motor we had this :
Then we acquired a Carbon Fiber conversion
Installed steel geared black Diff. with heavy duty SS Screws
Next was a Carbon Fiber drive shaft & a TT02 high speed gear set w/ adapter to allow us the use of almost any FDR.
Then we swapped out the 9.5T motor for a 5.5T motor and run a FDR of 7.5 : 1
Oh Yeah ! just have to do the electrics now.
Vintage is the way we roll : XXXS & TT01
bigfatslob is offline   Reply With Quote
Old 08-30-2014, 02:31 PM   #2390
You say you are using the TT02 high speed gear adapter set 54500. Do you (or anyone else) know if that TT02 high speed gear adapter set fits an unmodified TT01 and how low FDR is available with 64p gears? I'm trying to gear for 17.5 blinky, USGT (21.5) or VTA (25.5).
ic-racer is offline   Reply With Quote
Old 08-30-2014, 04:59 PM   #2391
bigfatslob's Avatar
Default Tamiya TT01 Carbon Fiber & Alloy
Well, I never tried it with the stock diff covers but I expect that it should fit. It fit perfectly in this iteration. Exactly like it was made for it. The benefit also being that I don't have to use Tamiya spur and pinion gear any longer. I cound use most true 48p or 64p spur gears and matching pinions.You may run into issues with the large diameter of the included spur gear clearing an upper deck ( if you have one ) but your free to use almost any spur gear for clearance sake. Well worth the minimal investment, even if you have to dremel a bit, but I don't think you'll have to
Old 08-31-2014, 12:33 AM   #2392
Hi,
I race my tt-01 in the Dutch Tamiya Cup. I still suck at it but I thoroughly enjoy it anyway. I do make an effort to optimize my car. In the past week I took it apart and rebuilt it to loose weight. It had become a bit of a parts stack... Everything on there is Tamiys produced, except for the servo, lipo, motor cooler and Tx, of course. Motors in the class are Carcon Cup Machine handouts. I have one, too, for practice:
This is the chassis as it stands, now:
Before:
After:
Now I am looking for more ways to loose weight, other tips are of course welcome too. I do not consider dropping 100 bucks on special screws to loose 10 grams, but would a light weight body make a big difference, for instance?
Thanks,
Hugo
HugoW is offline   Reply With Quote
Old 09-14-2014, 09:58 AM   #2393
KA2AEV's Avatar
Any special reason why your using the fan on the motor?
What sort of time frame do you run your car?
If you race in 5-9 minute races, you can drop the fan and keep the heat sink that should drop your 10g of weight your looking to loose
Mike
Oh and By The Way
Old 09-25-2014, 03:25 AM   #2394
Thanks for your input. I have the fan on the motor since this year's Deventer (city in the Netherlands) race. Many people cooked their motor, and many TEU105 BK ESCs bit the dust. I use the old 101 ESC (no BEC, high voltage electronics direct on 2S) and it survives everything. Also my motor is cool. On some tracks you are probably right, but this set-up is bullit proof and I like that safety.
Cheers,
Hugo
Old 09-25-2014, 11:34 PM   #2395
@bigfatslob - Your car looks amazing, drool factor! Well done. How is the handling after with all those parts?
I bought a TT-01E recently and did the neccessary upgrade, bearings, alu shaft, shocks and adj steering arms, not far off pase but battles with the steering into corners, the car runs very wide.
I have the red tamiya springs infront, yellow at the back, anti-wear grease in the front diff, waiting for my order of 500000 silicone oil. I thought of changing the rear springs to the blue ones and maybe remove the top plate to give it more flex. Any suggestions?
SRJRacing is offline   Reply With Quote
Old 09-26-2014, 05:29 AM   #2396
Usually you will want the softer springs in the rear.
Old 09-26-2014, 07:07 AM   #2397
Dont a softer back take steering away? Our local track is asphalt, medium grip, some guys suggested to make the back stiffer and this will increase the steering.
What body is best to use for the TT-01?
Old 09-26-2014, 08:08 AM   #2398
I run my 50746 dampers with 2 holes in the front, 3 in the rear, standard oil.
I ran with blue springs in the front and yellow in the rear when my car was 1.500 grams
I run with yellow springs in the front and red in the rear now my car is 1.300 grams
The car is understeered, but that might have to do with the fact that I keep pushing too hard into the corners, and my steering EPA should be reduced to the circuit's needs...
We run on asphalt with 51023 tires, no heating or adhesives.
The best bodies I know are the old Honda NSX, no longer available, the EBBRO (sold out mostly) and the Audi R8 LMS. I have the latter in light weight version but I have yet to drive it. It was advised in the Dutch Tamiya Top Stock class.
Cheers,
Hugo
Old 09-26-2014, 10:05 AM   #2399
longuylander's Avatar
I'm using white springs in front and blue in the rear. Car turns in great, though oversteers on power.
Running an old four slot silver can. Used a gps to clock it at 25mph when running 55/26 gearing with a 25c 2s lipo. Upped the gearing to 55/28, and unfortunately still got 25mph. I'd try the 27t pinion, but it's happily doing its service in my FF01 right now...
longuylander is offline   Reply With Quote
Old 09-26-2014, 11:05 AM   #2400
What does your car weigh ready-to-race?
I do 43 km/hr / 27mph on a Cup Machine with 25/55, the max allowed in the Cup.
Hugo
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
Tags
drift
SEO by vBSEO 3.5.0
