TT-01 Forum
#226
Originally Posted by nikkiesteban
If you want to lock it. Try using glue gun and inject glue stick inside the gear and cover it and wait until it dries. then try your new locked diff..
#227
A little help on TCS rules....
Any tire insert means and Tamiya insert or can I use an HPI insert?
#228
Hey will an Evo Iv prop shaft fit a TT01 thanks
#229
#230
Thanks Benny
#231
ahbock, the one-way cups for the universal shafts is from the TB01 part# 53590 as listed on Tamiya's website. You have to click on the TT01 one-way diff and in the description, it tells you to use this part number.
#232
hi guys
would like to know how u guys manage to encounter the freeplay @ streering link. ty
#233
IMO, race steering set is the way to go but it's expensive.. 30$+ at tower..
Asil
Asil
#235
Some shims will take a fair amount of play out of the steering, a selection of 4mm and 3mm ID shims are needed (I have Yokomo and Kyosho shims in the pitbox), but don't shim the horizontal link between the servo and the bellcranks as that needs to move back and forth.
#236
does any1 no if i can put a novak 3.5 turn brushless motor with matching esc into a tt01 without any hassles? if there are problems what should i replace to help make it suitable? thanks
#237
#238
#239
How many different threads did you actually post this question?
#240
good day i was just wondering, what's the most practical way to setup a tt-01 for rally???
I know for one that i'll be needing the rally block tires, after the tires what's next??? how do i increase the ride height suspension etc???
is there any particular tamiya model that i can swap parts from??? thanks in advance!!!
